High melting point solders used on PCBs...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8678
    I've noticed some boards are a pain to desolder, and others the solder melts quite readily. This is of course already considering large ground planes that will suck up all the heat from the joint. This by itself is a pain (do people just keep on applying heat to desolder caps on large ground planes or have some other tricks?)
    Take for instance my Antec SP400 PSU, the solder on the board took forever to melt. After I doped the solder on the board with some fresh eutectic 63/37 (or some high tin solder) it melted much more readily than before.
    Is it ROHS solder that's doing this? anyone know the exact formulation of common high melting point solder (metal ratios?)
    Then if you encounter this stuff, do you just use a really high watt iron to melt through it, or use a moderate iron and let it sit there till it melts (and for both, ever cause damage to board or components?)
    I have a spool of ROHS solder from Harbor Freight which I believe is mostly tin with a little copper in it, and has rosin core. This stuff melts more readily than the SP400 solder... (Then the other question is if the HFT ROHS solder is really lead free or not...) Also cheap 60/40 solder seems to melt faster than the SP400 solder... *shrug*
  • mariushm
    • May 2011
    • 3799
    Re: High melting point solders used on PCBs...
    http://en.wikipedia.org/wiki/Solder#Solder_alloys
    The chart lists the melting temperature in the description for almost each alloy.
    Most solder used in hardware is tin with a percent or more silver and/or copper. Silver helps with surface mounted components.
    Usual temperatures are 217-225c in comparison with 60/40 solder that melts at about 180c or 63/37 that does it at 183c
    So yeah, you need to use 300c or more to desolder, and you usually add a bit of leaded solder to lower the melting temperature.
    Anything on a spool will melt faster than something already applied on pcb with big copper traces that could absorb heat.
    • digge
      • Apr 2006
      • 296
      For boards with big ground planes i usually use my "beefy" 100W iron. That gives loads less stress on the board since its loads quicker and usually means you don't heat it too much. Perfect for scavenging components from boards. My 50W just wont cut it, i can sit there and heat it until its all black and charred.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        I came across a Biostar motherboard where none of the joints would melt...My iron got all the way up to 510C and none of the joints would melt at all, not even where the tip was. Tip was clean too...I just tossed the board
        • diodo49
          • Dec 2012
          • 17
          I use my heat gun to pre-heat the area then my 65w iron, it works.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8678
            There are so many different kinds of solder alloys so I was wonder which one was most common for the high melting point solder. The solder can't be very expensive either, after all, it's mass produced...
            I started to use my 100/140W solder gun to melt a couple of these but the tip is just way too big when dealing with motherboards... that's the other concern with the big guns...
            I've never tried using a heat gun to preheat, that seems like an idea to try...
            • Alikurnis
              • United states
              I have never used the gun for the melting purpose but used the motherboard. Its nice but it takes some time to get melt. The advantage of using gun is it does not taker that much time compared to motherboard.
              The prix achat maison i.e the price of the house at the time of buying must be known before dealing with it.
              • bianchi77
                • Jun 2016
                • 1121
                will 80W soldering iron be enough ? I put the temperature to 420 but it's still hard on unsoldering the caps....any other tricks ?
                  • 30944
                  it's the tip used and speed the iron reacts to temp loss as much as anything.
                  a T12 tip will be worlds ahead of most other irons.
                    master hoarder
                    • May 2008
                    • 12164
                    Exactly!
                    This:
                    https://www.circuitspecialists.com/l...l-display.html
                    https://www.circuitspecialists.com/lf-52d.html
                    haven't had a motherboard I couldn't recap or remove a MOSFET from. Makes my life so much easier!
                    • myth77
                      UV solder mask - high temp resistent, recomendation?
                      by myth77
                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                      Is there any solder mask...
                      03-28-2022, 04:04 AM
                    • Biruslapio
                      Samsung's AU series "high quality" panel internally melting
                      by Biruslapio
                      I got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
                      I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time....
                      07-12-2024, 10:08 AM
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                    • corrize
                      Soldering plastic low profile FPC close camera CMOS sensor ?
                      by corrize
                      Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
                      CMOS sensor seems resist to high temps.
                      But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
                      I have low melting point solder.
                      I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
                      07-12-2024, 02:21 PM
                    • petemanuk
                      BGA solder balls not connecting - help pls
                      by petemanuk
                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                      11-16-2022, 05:21 AM
