Fluke 187 corroded battery terminals - how to clean?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Fluke 187 corroded battery terminals - how to clean?
    Here is Martin doing the low batt testing on the Fluke 177 (is starts at 11:16 minutes)
    http://www.youtube.com/watch?v=qm3Zv...ure=plpp_video
    --- begin sig file ---
    --- end sig file ---
      Thanks Retiredcaps. That is really good, almost half the batteries and it still functions, good video.
      • retiredcaps
        • Apr 2010
        • 9271
        If you think that is good, check the UEI multimeter in episode 99 (Dave Jones' eevblog $100 multimeter shootout) below
        http://www.youtube.com/watch?v=3-_dU...feature=relmfu
        Start 31:15 into program for the UEI (9V battery). The Fluke 87V shows the DC variable power output voltage. The Gossen Metrahit shows the current usage of the DUT multimeter.
        I wish ALL electronics would use up every last drop of the batteries rather than cutting off at 1.2V (for 1.5V batteryl).
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          Originally posted by retiredcaps
          Yes, I saw that when your site came alive. Congrats on the new site.
          I have been a very long time nimh battery user.
          Thank you retiredcaps,
          it is true that I am an dedicated explorer of multimeters.
          Your hot welcoming will force me to buy one small Canadian flag for my office.
          About the multimeters and NiMH, slowly the manufacturers they start to understand how important are the rechargeable s.
          The new Agilent U1273A haves one special setting about adjusting the battery indicator for use with alkaline, or for use with NiMH.
          Everything is a mater of design.
          In few weeks from now, my review about it will make widely known those fresh technical details.
          The one set of those latest eneloop AA is for my FLUKE 28II.
          And those AAA for the Agilent U1272A & U1273A .
          http://img69.*************/img69/355...romgermany.jpg
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
            09-14-2023, 11:10 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • ferah831208
            Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
            by ferah831208
            Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
            03-18-2025, 01:18 AM
