How does this analog ESR meter work?
  • TheLaw
    • Jan 2011
    • 477
    Okay the title isn't exactly what I wanted to say, but I didn't want to make it too long.
    http://members.shaw.ca/swstuff/esrmeter.html
    Perhaps some of you have seen this meter. I'd like to build it because the part cost is very low, and hopefully will give me a general idea about the condition of caps etc. Thought it might be fun to build/have.
    So...I'm looking at the finished product in the enclosure. The analog gauge: Why are there no numbers on it? It just says bad or good? Also, why does it say 1uF in the middle of the good section?
    So is this meter strictly made to test whether it is good or bad? How does it really know? ESR can differ from cap to cap...
    Has anyone made one? Did you put numbers on it?
    Thanks.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: How does this analog ESR meter work?
    That kind of tester isn't of much use for low ESR caps. There are no numbers because he didn't bother to calibrate it, it's likely that he just measured several caps and made the gauge based on that.
    A working TV? How boring!
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Agree.
      Those are intended for testing GP caps.
      The range doesn't go low enough for low ESR caps.
      Useful tool, just not for Low ESR caps.
      Mann-Made Global Warming.
      - Dr Seuss
      • jsog
        • Feb 2011
        • 220
        The knob is a zero adjust. So short the probes and adjust it for full scale before testing caps.
        Accuracy... well, I've built that one and used to to find bad low-ESR caps. It gives a relative value, not a number. The printed scale is probably a mistake, it's all relative. For positives, it has input protection, which is lacking on some ESR meters. It's easy to build, too.
        • TheLaw
          • Jan 2011
          • 477
          I never did anything with analog meters. What is zero adjust....
          So if I want to actually see the ESR, do I have to plug it into my DMM or something? Is it possible to get an ESR readout on the analog display?
          Is that possible? I'm not sure exactly how this one works..
          Thanks!
          • ipman
            • Jul 2011
            • 159
            Analog meters have a "zero adjust" potentiometer which adjust the needle deflection to the precise end of scale point. If not set properly, the needle can overshoot or even not reach the end of scale.
            Yes, it is possible to read ESR in ohms, but needs to be calibrated against a known meter. This is not so easy because analog meters have a logarithmic scale.
            • Toasty
              • Jul 2007
              • 4171
              In order for that meter to be of any value, where the needle sits in the picture would have to be 0.10Ω and at the word "Good" would have to be 0.01Ω. It is not.
              Save your pennies, buy the Blue ESR meter by Bob Parker. Worth every cent.
              veritas odium parit
              • TheLaw
                • Jan 2011
                • 477
                So I can't just get a 0.001ohm resistor and hook it up and see where it lands?
                This is going to sound dumb also, but there's no way I can get ESR readout by inputing into the resistance function on a DMM right?
                So this is mostly just a "good" or "bad" meter..which I guess serve's it's purpose.
                • Toasty
                  • Jul 2007
                  • 4171
                  Yes you can use a low ohms resistor to "see where it lands", but you're not going to be able to tell a reading of 0.06Ω (fail) from 0.02Ω (good). The scale is not "fine" enough.
                  ESR meters generate a frequency to test the cap. They are not "really" ohmmeters like you are thinking.
                  You'll not be able to distinguish between a good or bad unless it's -really- bad.
                  veritas odium parit
                  • TheLaw
                    • Jan 2011
                    • 477
                    Hmmph. I see. Well I can probably make one for like $20, so I might just try it for the heck of it. I guess a digital one would be better in the end...but as a project, this seems pretty interesting.
                    • Toasty
                      • Jul 2007
                      • 4171
                      NJ
                      What Exit?
                      I'm TP #3
                      veritas odium parit
                      • jsog
                        • Feb 2011
                        • 220
                        The schematic shows pretty well what is going on. You could replace the meter with a DMM set to DC volts, but would have to calculate backwards from calibration values to get ohms.
                        • TheLaw
                          • Jan 2011
                          • 477
                          NJ
                          What Exit?
                          I'm TP #3
                          Exit 16.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            It takes a certain amount of current to get the needle to move.
                            To get a usable range for low ESR caps with that kind of meter you would have to drive the meter with an amp which would create more error than what you are trying to measure in the first place.
                            In a digital meter the current is measured by an IC so not much is needed.
                            The measurement is then digitized and sent to the display.
                            The display itself is not part of the measurement circuit.
                            - Dr Seuss
                            • TheLaw
                              • Jan 2011
                              • 477
                              Ohhhh I get it now.
                              Alright. Well I can build one for like $20, so I might just try it for poops and giggles.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                That'll be $20 well spent. Not only will you learn this and that, but this kind of meter actually works when you're hunting for bad caps, because in a piece of equipment that has failed due to bad caps, they're gonna be bad enough to register on such a meter. Just don't expect to distinguish fake caps from genuine ones, or the difference between 0.06 and 0.1 ohm ESR, coz you're not gonna get it.
                                • TheLaw
                                  • Jan 2011
                                  • 477
                                  Yeah I don't exactly require exact ESR measurements...but it would be handy to see which are dead or not.
                                  • resistor83
                                    lenovo 330s-15ikb, led num lock key always on and numbers don't work
                                    by resistor83
                                    hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                                    I tried updating the bios but the problem remains
                                    https://s...
                                    05-29-2025, 08:06 AM
                                  • eccerr0r
                                    lowest current galvanometer/analog meter (passively powered!)
                                    by eccerr0r
                                    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                    04-16-2025, 12:41 AM
                                  • jorpec
                                    by jorpec
                                    Hi
                                    Thnaks
                                    01-23-2023, 10:37 AM
                                  • chth96
                                    by chth96
                                    03-09-2024, 10:03 PM
                                  • hollox123
                                    ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                    by hollox123
                                    Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                    1. Laptop keyboard doesn't work
                                    2. The backlight on the laptop keyboard doesn't work
                                    3. The x2 side LEDs (red) on the laptop don't work
                                    The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                    I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                    But I am strongly aiming that it is somehow a BIOS-related problem,...
                                    05-11-2025, 08:05 AM
