flux
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    flux
    so i've been using this for a while
    I haven't used it in a long time, since finally got my hakko tip yesterday, I started using it and found it solidified and the alcahol evaporated in it, all the resin and denser chemicals floated to the bottom, and will not remix. I also have a refill bottle which has done the same thing
    anyone has suggestions on flux? I keep seeing these youtube videos on youtube with this clear paste in a syringe used to remove chips, is that the best stuff? what stuff do you guys use, what is the best stuff, cause this other shit an't going to fly anymore, besides this liquid stuff is messy, and has spilled before leaving a sticky soft drink-like film thats hard to clean up
  • smason
    • 1652
    Re: flux
    I only use flux for tricky jobs (SMD mostly) but I use the Kester stuff in the tube from Digikey, it has a felt applicaor kinda like a highligter. Seems to work well.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Re: flux
      come on! out of everybody, I only get one response?! this is a topic plenty of people here can help me with, especially the senior members (not citizens, but they might be one in the same)
        master hoarder
        • May 2008
        • 12175
        Re: flux
        How long?
        I just checked my 100 ml bottle that I bought about 8 months ago and it's still fine, but I'm guessing yours is older than that.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Re: flux
          I dunno, I've never used good flux.
          I simply used solder with a flux core, it works just fine for 99% of what I do.
          It gets a bit tricky to solder SMD components with it though, here flux would help
          So I would also be interested in
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: flux
            Same as Per Hansson.
            Although I picked some up a few days ago because I want to try fluxing my solder braid next time.
            It's supposedly fluxed already but it isn't acting like it. Maybe it got too old.
            Mann-Made Global Warming.
            - Dr Seuss
            • digge
              • Apr 2006
              • 296
              Re: flux
              Flux ages, so if you didn't buy it recently or it sits for long on a shelf it will go bad. Exactly how bad flux works depends on the brand i guess.
              I bought some noname flux on syringe, don't use it very often but can be good sometimes.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Re: flux
                you can make your own flux using colophony (colophonium?)
                read the reviews there
                http://www.dealextreme.com/p/just-wo...ing-paste-4697
                if you get the mixture right (somewhere between "runny as water" and "gooey mess"), you could just use a syringe to suck it up and put it wherever you want it
                works quite well.
                you can also change the consistency by either adding more colophony (thicker) or IPA (more runny). if you have a block like the one in the link, crush it into smaller pieces to speed the dissolving process up..
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5039
                  • New Zealand
                  Re: flux
                  I won\bought some of this: http://www.sparkfun.com/products/8967 for SMD work (Thank you Free Day!)
                  Practiced with it on some old motherboards a bit, seems to work well.
                  Wish they didn't use big cardboard boxes to send stuff though, I'm pretty sure a padded envelope (like the one they stuck the whole box in!) would have done just fine, and cut down on costs...
                  Other than that, I've only ever used the rosin flux from my solder...
                  -David VanHorn
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    Re: flux
                    this is just what I picked up today
                    after months of using the liquid stuff for desolering, this stuff works about 50% better and on boards that have the most difficult solder, it makes it just as easy
                    the bad thing though, is the smell is much more prevalent, and there is more smoke...the neighbors in the apartment next to me might think i'm making meth
                    edit: I just realized the picture above was poorly edited lol
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Re: flux
                      This stuff works just as well and is a lot cheaper I think:
                      I've used it in tons of jobs. I know it's made for plumbers, but it works just as good for electronics. Nasty fumes though like you mentioned.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: flux
                        Acid flux is a no no on electronics.
                        I've never seen flux with a Sunscreen rating before...
                        - Dr Seuss
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5039
                          • New Zealand
                          Re: flux
                          As far as I know you're not supposed to use acid flux for electronics...
                          Edit: PCBONEZ has beat me to it... but isn't sunscreen rating SPF though?
                          -David VanHorn
                          • mockingbird
                            • Dec 2008
                            • 5484
                            Re: flux
                            It's only ate away at a PCB layer once. I was recapping an A8N motherboard and I was trying to fit some 10mm caps in the 8mm VRM holes. I tried to move the coils a bit to squeeze in the caps but they were absorbing all the heat so I put a lot of it on and then neglected the motherboard a bit. In general I did a really sloppy job on that motherboard at that time, it's not my best work.
                            The paste ate away at the etching and it exposed the thin copper layer underneath - but this was only because I left it on there for a ridiculously long time, and Asus was really cheap with the outer layer on this model.
                            In the end I ended up mangling one of the capacitor holes (Usually my work is immaculate - this was something I just wasn't paying attention to) but luckily there was an unpopulated spot in the VRM so I put the cap there instead and the motherboard works great.
                            All in all - except for this incident - I have never had a problem with this acid paste. The tins used to be blue and I have two tins that are probably around 30 years old and the stuff still works great.
                            • severach
                              • Aug 2007
                              • 1055
                              Re: flux
                              You can use acid flux on electronics but you must clean it off real well. I'd use it on anything that was very corroded where I could scrape it with a razor. It's often needed on old car wiring. PC boards are much cleaner so I find rosin flux sufficient.
                              sig files are for morons
                              • Evil Lurker
                                Warranty Voider
                                • Feb 2011
                                • 454
                                Re: flux
                                Not to mention the fact that you can just about watch your tip getting eaten away with acid flux...
                                • smason
                                  • 1652
                                  Re: flux
                                  Ouch, sounds painful.
                                  • chth96
                                    Is it good to use chemistronic flux off es835b for flux remover?
                                    by chth96
                                    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                    11-17-2023, 07:25 AM
                                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                    - No Clean Formulations
                                    - Low residue
                                    - Range of activity to deal with different component solderability
                                    - Halide free
                                    - Suitable for dispensing
                                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                    Both products are supplied in syringes or cartridges for application by dispensing....
                                    10-07-2024, 06:02 AM
                                  • evilkitty
                                    Flux causing high resistance short?
                                    by evilkitty
                                    Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                                    Temp is on the left humidity is on the right
                                    i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                                    The pin out looking down from the top is (note this is common cathode)...
                                    07-17-2024, 09:38 AM
                                  • chth96
                                    How can I remove flux with the smallest rubbing?
                                    by chth96
                                    I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                                    Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                                    Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                                    Is there any way to remove flux with the smallest rubbing or without any rubbing?
                                    Any reply would be appreciated.
                                    11-24-2023, 05:22 PM
                                  • shamaltech
                                    Asus Laptop Restart when loading YouTube !
                                    by shamaltech
                                    I have an Asus X510UN laptop.
                                    It has a weird problem that it restart everytime while I'm loading the YouTube.
                                    This happens only when the laptop plugged into charger.
                                    When using battery power,it works fine and YouTube works without restarting.
                                    Tried with Installing new Windows,changing SSD and also Flashing the BIOS.
                                    Any help?
                                    03-05-2025, 02:30 PM
