Toshiba 48L5463DN no picture, backlight on
  • Stigsolbjerg
    • Mar 2020
    • 33
    • Danmark
    As title says, its a vestel inside. power led flikering red and green 12 times. Backlights comes on at nr 9 red. Nothing burnt or swollen caps. Tried switching to a second hand t-con board from china. Same thing.
    Its my first in depth lcd tv repair. So need to figure out what is wrong? Is it the main board?
  • Stigsolbjerg
    • Mar 2020
    • 33
    • Danmark
    Re: Toshiba 48L5463DN no picture, backlight on
    Anyone have an idea of what i should mesure to out rule something?
    Should i bye a main board, just can't find one from the exact same tv?
    Or just give up, since its a vestel, just aint my style!!!
      Do you have 12VDC at both ends of the SMD fuse on the T-CON board with ref to GND when TV is turned on?
      • Stigsolbjerg
        • Mar 2020
        • 33
        • Danmark
        Yep, if you mean the white fuse that has gold ends, 12 volts at both ends. Is there testpoints i should do more mesuring on?
        • yokoono
          • Apr 2010
          • 510
          Vgh (von), vgl(voff) ?.
          Unplug the 2 ribbons that lead to the panel one by one and see if a picture appears on a half screen. Do not switch off with the TV on.
          • Stigsolbjerg
            • Mar 2020
            • 33
            • Danmark
            Vgh (von), vgl(voff) i dont understand.
            I unpluged the two cables one at a time, and i got picture on half the screen, but just on one them.
            Vcc_1,2=0,00
            Vcc_1,8=0,17
            Vcc_3,3=0,98
            Vone=0,00
            Voffe=0,10
            Hvin_12=0,0
            Vin_12=12
            Havdd=0,0
            Avdd=0,0
            hope you can use this to outrule some defects? Or is t-con or mainboard ok?
            • Stigsolbjerg
              • Mar 2020
              • 33
              • Danmark
              Picture off screen, one cable off.
              • yokoono
                • Apr 2010
                • 510
                Almost all measured voltages are incorrect.
                Ex: vcc1-2= 1,2v; vcc1-8= 1.8v ; vcc3-3 = 3,3v ; Vone= aprox. 17v ; Voffe = aprox minus 5v.
                Disconnect both ribbons and measure again. Part of the screen on which the image does not appear is defective. As it looks you have problems with the panel. If you are lucky, a smd capacitor may be defective.
                • budwich
                  • Jul 2015
                  • 3097
                  Vcc_1,2=0,00
                  Vcc_1,8=0,17
                  Vcc_3,3=0,98
                  Vone=0,00
                  Voffe=0,10
                  Hvin_12=0,0
                  Vin_12=12
                  Havdd=0,0
                  Avdd=0,0
                  input a better signal into the tv when you do this test (test pattern like smpte color bars or such), post that resulting picture so we can see the result. It is likely that you have some form of panel issue on the side that when plugged in gave no picture. To get around the problem, people use the "tape cutoff method" which involves using a small piece on tape to mask part of the contact pins on the cable going from the tcon to panel on the bad side. It cutoffs of some of the signals going to the side of the panel which has "in panel drivers" that are causing a problem. Once done correctly, your tv and display will probably provide a "good picture".
                  • Stigsolbjerg
                    • Mar 2020
                    • 33
                    • Danmark
                    Godmorning, here are the new results, with both cables to screen disconnected.
                    Vcc_1,2=1,2
                    Vcc_1,8=1,8
                    Vcc_3,3=3,25
                    Vone=30,9
                    Voffe=11,35
                    Hvin_12=11,96
                    Vin_12=11,96
                    Havdd=8,36
                    Avdd=16,43
                    This must look a hole lot better.
                    Now you a talking about a bad smd capacitator on the panel board, right?
                    • Stigsolbjerg
                      • Mar 2020
                      • 33
                      • Danmark
                      Now i have mesured the caps on the panelboard, there is six on each panel in groups of two. The side that does not show image, all six is about 28 ohms. The other panel is 10 megaohms and dropping.
                      • yokoono
                        • Apr 2010
                        • 510
                        Now we can say that T-con is good. If you connect a ribbon and the voltages disappear there is the problem. Left or right. IF YOU ARE LUCKY a smd capacitor may be in short supply. Most of the time on VONE. Measure the resistance to the table and see what you find.
                        L.E. You will need to detach the smd capacitors and measure them separately. If they are good there are problems in the panel.
                        • Stigsolbjerg
                          • Mar 2020
                          • 33
                          • Danmark
                          Now i have been doing some mesurements, when i use the Vone testpoints on t-con board to gnd the resitance is25,3 kiloohms with both panels or one of the sides. But with Avdd there is only 24,3 ohms when the left side is plugged in. So where do i go from here? Is it the small components on the panelboard where there is written Avdd?.
                          What does L.E. mean?
                            Start removing the suspected caps one a time since some of them may be connected in parallel and see if the low resistance reading goes away when the suspect cap/s is removed.
                            Also show us the pictures of the tab bonding (panel board).
                            • Stigsolbjerg
                              • Mar 2020
                              • 33
                              • Danmark
                              Oh that picture, i did attatch it yesterday but here i try again
                              • Stigsolbjerg
                                • Mar 2020
                                • 33
                                • Danmark
                                Is the suspected caps those in the picture from last post?
                                Hmm just googled tabs bonding! U mean the three flat cables from panelboard to screen?
                                  Tab bonding boards are the long green circuit boards that the LCD's flexible circuit boards are bonded to, as you can see lots of SMD MLCC (Multi Layer Ceramic Capacitor) are on that board in your picture.
                                  So which is/are the caps for the suspected bad caps that show low Ohm readings, the 3 MLCC connected in parallel to the AVDD? If they are then you need to remove one at a time to find out which one is bad.
                                  The designaotrs for those 3 MLCC for the AVDD are CA3, CA2, and CA1
                                  • Stigsolbjerg
                                    • Mar 2020
                                    • 33
                                    • Danmark
                                    I desoldered this thre components (look at picture), none of them had a resistance near 24 ohms, its more like 1 megaohm and incrising to 20 mohm. And measuring at the Avdd testpoint on the t-con board, there is.still 24 ohms even when the componts is removed from the board.
                                    Now what?
                                    • Stigsolbjerg
                                      • Mar 2020
                                      • 33
                                      • Danmark
                                      Panelboard nr
                                      • yokoono
                                        • Apr 2010
                                        • 510
                                        It seems that the defect is in the panel and is irreparable for you. It would be a chance if the panel has side drivers (some "ears" on the edge of the screen).
                                        And if the short is not in the top driver.
                                        Ex.:
                                        https://www.youtube.com/watch?v=YDxghCYcZXA
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • willis6732
                                          Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                                          by willis6732
                                          This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                                          Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                                          The Driver board looked pretty toasty in the LED Driver Area.
                                          So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                                          12-17-2024, 04:09 PM
                                        • jaifraic
                                          Toshiba 49U6763DA (Mainboard: Vestel 17MB120) Powers on, backlight ok, no picture
                                          by jaifraic
                                          I have a Toshiba 49U6763DA TV that shows no picture. It turns on, the backlight works, but nothing else. I don't have a remote at the moment to check if this is working.
                                          I have opened the unit, every plug is connected, nothing seems to get hot and all caps look ok. I checked the small caps on the tcon board and the two boards that sit between the tcon and the panel (I don't know what they are called). None of the caps are shorted. The tcon board gets 12V (actually 12.5V) and the fuses are fine.
                                          So I'm thinking that the motherboard is defective...
                                          06-15-2021, 09:27 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
