Kdl-70w830b sim in middle of picture after backlight repair
  • jeffer76
    • Sep 2011
    • 76
    • US
    I am working on a Sony Kdl-70w830b that had bad led backlights. TV was shutting down with the standby light blinking red four times. I replaced the bad LED strips. (Whole metal frame)
    Now I am getting a picture that is bright on the right and left side but dim in the middle. I am curious if anybody else has experienced the symptom after working on an edge lit led tv?
    I can only assume that the plastic sheet that is supposed to glow from the LEDs has a problem. I'm wondering if it's because when I removed the thick plastic sheet it bowed in the middle Causing the light to not flow through it properly. Do you think that is possible?
  • jeffer76
    • Sep 2011
    • 76
    • US
    Re: Kdl-70w830b sim in middle of picture after backlight repair
    Anyone experienced this problem before on an led edge lit led tv?
    It's as if the light is not traveling through the plastic sheet.
    Let me know please.
    • dkneyle
      • Dec 2013
      • 441
      I reckon you are probably on the money about having a sheet that is bowed. Logically it is about the only thing it could be. Having done this type of job a few times it would be very easy to have a bow occur. I know it's a pain, but strip it down and try again!
      • jeffer76
        • Sep 2011
        • 76
        • US
        I have tried everything I can think of. Adjusting the strips closer. Pressing it flat. The light just won't travel through the plastic. I'm guessing there are cells inside the plastic that the light travels through and when removing the plastic sheet the bow fractured those cells. Not sure.
        • dkneyle
          • Dec 2013
          • 441
          Mmmm. Have you done some internet research on how edge-lit LED panels work to confirm if such cells do exist? I've got nothing else of offer. Hopefully someone with more knowledge than me has an answer for you.
          • budwich
            • Jul 2015
            • 3097
            what exactly is being shown with the second picture in your initial post? is that the before, after, or otherwise? are the edge leds only on the sides or all the way around?
            Likely all the way around... if so, the next question is what type of leds did you replace with? EXACTLY the same? Maybe there is an issue with output / dimming of the top and bottom versus sides?
            • jjanssen7
              • Nov 2012
              • 252
              Even in edge lit TVs, there are still usually multiple sheets... any chance you mixed up the order?
              • jeffer76
                • Sep 2011
                • 76
                • US
                Second picture is one of the test photos built into the tv. Harder to see the bright edges in this photo. This is an after photo. The edge leds are only on the two sides of the set. The leds are exactly the same part number but do have a slight variation in color.
                • jeffer76
                  • Sep 2011
                  • 76
                  • US
                  No. I am very careful about taking the tv apart in a special order so as to prevent that from happening. Also I believe the image on the screen would not look correct if they were in the wrong order.
                  I was thinking that maybe as a result of pulling back the final white paper sheet, the one taped to the frame, somehow changed the way the light is reflected. You have to pull back that one to gain access to the led strips. I didn't remove it completely. Just pulled it back far enough to gain access to the light bar assembly and replaced the whole assembly.
                  • neilc6
                    • Nov 2015
                    • 1550
                    From optics, light travels though tbe sheet using total internal reflection. Same as light travelling through a fibre optic cable. Looks like bowing the sheet damaged it enough for the light to not pass through like kinking a fibre optic cable.
                    • jeffer76
                      • Sep 2011
                      • 76
                      • US
                      That is what I was thinking. It's the only logical conclusion I can come up with. Do you think that it could be a brightness problem? Not enough light to pass all the way through the sheet? I hate to just give up on this.
                      Thanks for all the reply's. All opinions are appreciated
                      • budwich
                        • Jul 2015
                        • 3097
                        ok.... but there is something "funny" with the second picture.... why is there brightness across the bottom at different places. This brightness doesn't appear to "agree" with your other pictures.
                        • R_J
                          • Jun 2012
                          • 9588
                          You say: "I replaced the bad LED strips. (Whole metal frame)" was this from the same model panel? It looks like there is quite a gap between the led's and the diffuser sheet
                          • jeffer76
                            • Sep 2011
                            • 76
                            • US
                            So I thought the same thing. The metal plate that the led strips are attached to can be adjusted so I slid it closer to the diffuser sheet. The leds were practically touching the edge of the sheet. No change.
                            • jeffer76
                              • Sep 2011
                              • 76
                              • US
                              That brightness that you are seeing is a reflection from our over head lights.
                                So are the LED assemblies exactly the same as the original one and matched the LCD panel model number? I did not see the answer that was asked in post #13.
                                What is the LCD panel model number?
                                What are the P/N of the old LED assemblies?
                                What are the P/N of the replacement LED assemblies?
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  Was it put back as smooth as it was taken off ?
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    If it has the same properties on both sides of the sheet take it out and flip it over. If you bowed it in one direction flipping it over might help to restore its properties.
                                    Are there any plastic spacers beneath the sheet to keep that layer from sagging ?
                                    • jeffer76
                                      • Sep 2011
                                      • 76
                                      • US
                                      The led assembly came out of a kdl-70w850b model. They appeared to be the exact same part. Shape, size, numbers. I have since put the tv back together and given up on it. This tv was a monster to take apart and put back together and I don't want to open it again.
                                      • jeffer76
                                        • Sep 2011
                                        • 76
                                        • US
                                        For the most part yes. The white sheet that's taped to the frame got a few wrinkle marks from pulling it back. They used very sticky tape on this model.
                                        • burbutsalos
                                          LG 55sk8000 plb ..snow in the middle of screen but can see that picture exists there
                                          by burbutsalos
                                          Hello everyone.
                                          I have this TV set which has this issue. It shows a vertical bar im the middle of the screen.
                                          The panel has 12 cofs and the problem seems to be on the territory of the first cof on the right side.
                                          The tv fires up and you can see a good picture exept that vertical part where multicoloured pixels exist.
                                          The strange thing there is that you can see behind that snow that it shows picture but as if there are these pixels in front so you cannot see clearly.
                                          The effect is there even on a completely black screen.
                                          The screen...
                                          10-21-2023, 02:57 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
