swollen or not? can you tell?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Hi! New to forum..
    I have a Macron Power psu MPT-301 and it seems to me that the primary caps are swollen. But before trying to recap them (I have no experience in this) I need to be sure that they need to be replaced.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: swollen or not? can you tell?
    Looks like it's bulging no way I'd leave it in there in any case.
    I had a UCC counterfeit cap on a variable power supply that looked the same way when I removed the plastic cap it had some brown goop under it. The can didn't look bulged but I gutted the counterfeit anyways.
    • POM_MJ
      • Aug 2009
      • 228
      It's look similar to my Enlight VP-300 in this post ==> https://www.badcaps.net/forum/showpo...3&postcount=95
      same caps brand used, on my vp-300 secondary side caps had leakaged then caused very damage to other components.
      I'd recommended to replace caps on both primary and secondary side.
      | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
      | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
      | 2xWD7500AYYS | 2xHD322GJ Raid0 |
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        I like the Y cap wedged under that X cap. Really good manufacturing processes there.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          this psu is simply EPIC FAIL. dang, it takes effort to blow primaries, even bad ones.
          sigpic
          (Insert witty quote here)
          • Krankshaft
            • Jan 2007
            • 2328
            It's got a primary side choke though I'll give them credit for that.
            • berniedd
              • Mar 2007
              • 119
              I've had a PSU line cap that looked like that. I pried off the plastic round bulging top, and saw the only thing bulging was the plastic. The bare aluminum top of the capacitor was oK. Needless to say, I left it there, didn't replace it. I have yet to see a Line capacitor go bad, even after 17 years of being in the computer hobby.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Thanx for the replies
                It seems really difficult for me to change all the psu caps... I don't trust my hands :P
                If I knew anyone in my region who could do this I would have him recap them.
                The psu caps are cs (as the bulging primary caps) and 3xjp and 2 jee caps. None is bulging or leaking except primaries. The psu works fine in P3 system but can't boot a pentium 4 1,5GHZ, intel 845 motherboard with sdram support.
                Voltages are close to nominal values, only 12v is a bit low (11,7-11,8v).
                I was impressed by the high capacity of the primaries (680uf), all other psus I ve seen had 470uf or even 330uf.
                One more question please.. the primary caps specs are 680uF 200wv vent85c. What does Wv mean? Is it different from 200V? Sorry, if it is a stupid question...
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  *and 3xjp and 2 jee caps ---> and 3xJPce 1uF 50v and 2xJPce 220uF 16v caps, sorry...
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    My nichicon 200v, 680uf caps say that too. It's basically just volts.
                    If you want someone to recap it, location would help.
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      Greece
                      • Toasty
                        • Jul 2007
                        • 4171
                        WV = Working Volts
                        >>If I knew anyone in my region who could do this I would have him recap them.<<
                        You don't show your region in your profile... Perhaps if you did....?
                        veritas odium parit
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3113
                          Greece
                          Lol. Maybe willawake, I believe he is in greece. Still, soldering on a single layer cheap power supply like this is a snap. Heat one lead up, pull it out. Heat the other up, pull it out. Cap plops right out. New cap-check polarity, put in holes. I usually just heat the holes real quick on the other side to just slide it in over the old solder, holds it in place until I get more solder into it.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            see if you can push the plastic down pn top. if you can, the caps are probably OK, if you can't, they're toast. it's common for the plastic disc to dome but the top of the cap to be flat.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              I did push it with fingers,nails etc but it didn't move at all. remained bulged... So I guess I have no option but try and change them. Wish me good luck!
                                Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                                by momaka
                                This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                                Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                                Macron Power Technology Co. LTD.
                                Let’s look at the PSU itself.
                                The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                                06-02-2021, 10:05 PM
                              • dicky96
                                Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
                                by dicky96
                                Hi guys
                                I have a faulty Xilence ATX PSU here
                                The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
                                There is another smaller transistor on the primary side C3866 which tests ok
                                The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
                                There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
                                05-11-2021, 07:55 AM
                              • Curious808
                                Swollen power bank
                                by Curious808
                                Rechargeable power bank for cellphone etc has swollen up and broke open the plastic case. It's expanded so that I can't press the sides of the shell together. There's no leakage. It was in a fabric pouch, so easy to tell. No warmth or heat.
                                Pressing the test button lights up the charge indicator lights. Seems to be fully charged.
                                I've had it for maybe five years. Used only a couple of times. Kept charged. Last checked within the last two months.
                                Any idea what happened? Is it dangerous, getting ready to explode?...
                                09-23-2022, 04:31 PM
                              • japlytic
                                Could all new PC motherboards only require a primary 12V rail?
                                by japlytic
                                This is a possibility, but future PC motherboards could only require a single 12V primary rail with +3.3V/+5V (-12V is only required for PCI slots (and certain cards thereof) but not PCI Express slots) switching regulator circuitry (which is now quite compact for their high output) on the motherboard with SATA power output connectors on the motherboard.
                                Most newer ATX (and related counterpart) power supplies over a certain wattage typically have a single primary rail of +12V which is then connected to independent +3.3V/+5V/-12V switching regulator modules; also, many hot swap server PSUs...
                                07-10-2020, 12:58 AM
                              • hinisa
                                Xiaomi router freezes at boot after re-capping
                                by hinisa
                                I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                07-08-2023, 05:58 AM
