CapXon
  • CapacitorUser
    • Oct 2008
    • 11
    CapXon
    My Dell lcd monitor went dead on me out of nowhere. I thought the button broke but on further inspection I found that 3 of the capacitors on the power board were bulging. The middle capacitor had much more yellow junk on it but I brushed it off by accident. I want to replace the capacitors so I don't have to buy a new monitor. Can anyone tell me which capacitors I need to get? There are so many on the market.
    The caps are rated:
    1000 uF
    10 V
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: CapXon
    Hi CapacitorUser
    Welcome to the Forum!
    You need to know the capacitor "series" as well as the voltage and rating.
    The Series is a 2-letter code and for CapXon Power Supply caps might be: "GL", "KF", "KZ", "GF" or "LZ".
    For example, a CapXon KF series is considered a "Low Impedance" capacitor suitable for use in Power Supplies.
    Once you find the series, go to CapXon's website and look up the specific capacitor that you need.
    You're interested in:
    Mounting - Radial Leads
    Series
    Voltage
    Capacitance in microfarads (μf)
    Size, especially Diameter in mm
    Ripple Current in milliamps (ma)
    ESR or Impedance in ohms (Ω)
    Next, you need to find a suitable replacement from a better manufacturer.
    Badcaps.net offers Rubycon and Samxon brands.
    Other well-regarded brands are: Nichicon, Panasonic, United/Nippon Chemi-con... along with others that you may notice mentioned in the forum.
    My personal guess would be something like a Nichicon PW or a United Chemi-con (UCC) KY with about 1000ma Ripple Current and maybe .060Ω Impedance. You can usually be a little off on Capacitance, ESR or Ripple Current but never go low on the Voltage.
    You can buy suitable capacitors right here at BadCaps.net, at eBay, Digi-Key or other electronics suppliers. Radio Shack only carries General Purpose capacitors not usually suited for use in a power supply.
    Keep reading,
    Have fun!
    Keri
    The More You Learn The Less You Know!
    • Newbie2
      • Sep 2005
      • 885
      Re: CapXon
      I'm not sure if it's the same in the USA, but in Canada at The Source (used to be known as RadioShack in Canada in the past) the capacitors in the capacitor value packs are from some "TREC" brand:
      I've had no experience with this brand, but I'm guessing that it isn't a high quality capacitor manufacturer.
      I'm guessing RadioShack radial aluminum electrolytic capacitors of 1000uf can be used if they fit, but at best they're a temporary repair until better low impedance capacitors are available to you.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • CapacitorUser
        • Oct 2008
        • 11
        Re: CapXon
        I found the model number of the capacitors. Its CapXon P544 VENT. I could not find the specs on CapXon website.
        However I was wondering if this capacitor that I found on digikey will work.
        http://www.digikey.com/scripts/DkSea...name=P10224-ND
        • Newbie2
          • Sep 2005
          • 885
          Re: CapXon
          That capacitor will work perfectly for your monitor.
          If there are any other CapXon capacitors in your monitor with different values, you might also want to purchase replacement capacitors for those too to avoid a future problem with capacitors.
          My gaming PC:
          • etnietering
            • Apr 2009
            • 379
            Re: CapXon
            looks to be exactly the same dell monitor that I repaired over in this thread. If I were you I'd replace the other 5 fatter caps while you're at it. If the little ones went, they won't be far off...
            In addition to the pieces of information mentioned by KeriJane, you'll need to know the lead spacing (distance between the leads, so that it will fit), and the height, so that you'll be able to put everything back together afterwards.
            If you'd like I can get you the exact part numbers from digikey for what you'll need. They fit perfectly and the monitor has been running for 2 months without problems.
            • CapacitorUser
              • Oct 2008
              • 11
              Re: CapXon
              I would greatly appreciate if you gave me the exact part numbers. Thanks.
              • CapacitorUser
                • Oct 2008
                • 11
                Re: CapXon
                Thanks to everyone for their input. My monitor is working again!!! Sorry for the late update. Here is the pic of the new Panasonic caps on the power board. Don't know if its interesting but I took apart one of the culprits and pictures are provided. When I tried to open the cap there was a big hiss like when you puncture a aerosol can. The metal strip looked blackened.
                • etnietering
                  • Apr 2009
                  • 379
                  Re: CapXon
                  Congrats man! Glad you got it working
                  • Dasutin
                    • Oct 2009
                    • 1
                    Re: CapXon
                    Does anyone know what I can use to replace the 4 transistors on this board? I replaced all of the capacitors and I found that the transistors are bad but I can't find any information on them. They are just labeled U402.
                    • Kelte
                      • Jul 2009
                      • 15
                      Re: CapXon
                      Just a bit surprise that an important brand like Dell use CapXon capacitors in its PC.... I would guess that, as their PC are used by professional, Dell would select more carefully its supplier...
                      • Kurogane
                        • 1
                        Re: CapXon
                        Had the same thing happen, ordered the same caps from digikey. Problem solved, thanks for the post.
                        • ipo3nk
                          • Mar 2011
                          • 16
                          Re: CapXon
                          capxon = the only brand i found to be fail / dried / zero capacity / SHORT in APFC part of psu..
                          • Scenic
                            o.O
                            • Sep 2007
                            • 2642
                            Re: CapXon
                            you forgot fuhjyyu
                            • LuSiD
                              Research addict
                              • Mar 2011
                              • 16
                              • Greece
                              Re: CapXon
                              Capxon caps were the culprits for my Viewsonic monitor too (All 4 of them!). After replacing them, the monitor came to life again! Don't know if there is a "good series" in Capxon caps but as far as it goes for me, i will never buy them... And this is just my humble opinion.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Re: CapXon
                                Well, i've found good CapXon capacitors in quite a few monitors and some (quite old) PSUs. They aren't "bad", they just have a short service life. And the companies know about this. Planned obsolescence. A few people doing TV repairs here use CapXon as replacement caps (makes you wonder what other no-name brand are they replacing, if they aren't actually replacing the same type of cap), a major electronics store here carries them... that's just the way it is.
                                A working TV? How boring!
                                • Rulycat
                                  • Apr 2010
                                  • 724
                                  • United Kingdom
                                  Re: CapXon
                                  Being right next to a hot heatsink does them no favours either, on some monitors the heatsink reaches over the caps to make sure they're extra toasty...
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Re: CapXon
                                    Well, electrical design rules tell you that the caps should be located as close to the device powered by that rail as possible. Thermal design rules tell you that the caps should be located as far away from the heatsink as possible. Monitor designs violate both rules - the caps are located right next to the diodes' heatsinks, while the inverter is on the other edge of the board.
                                    • Rulycat
                                      • Apr 2010
                                      • 724
                                      • United Kingdom
                                      Re: CapXon
                                      Planned obsolesence at it's finest! In PSUs I see CapXons either in those FSPs with the god awful "heatsinks" where it's just a slab of aluminium, or really crowded low efficiency PSUs. I make a point to disable the fan controller now, which seems to make them last.
                                      • dragon3x
                                        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                        by dragon3x
                                        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                        power on.
                                        Here are some examples :
                                        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                        switching supply area).
                                        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                        than 6.3 V.)
                                        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                        I replaced capacitors with aluminum-polymer.
                                        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                        03-21-2025, 02:46 PM
                                      • ADV
                                        Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                                        by ADV
                                        Good day everybody
                                        I hope I'm posting in the right section - I am new to this awesome forum.
                                        I have received an ACER Ferrari F-20" LCD Monitor to repair.
                                        It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                                        For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                                        I opened the external 18V power supply and see no bulged capacitors...
                                        11-02-2021, 09:32 AM
                                        Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                        by sam_sam_sam
                                        I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                        This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                        After all of...
                                        07-13-2024, 08:14 PM
                                      • Ady2017
                                        Are there any datasheets available for Elna RJG capacitors?
                                        by Ady2017
                                        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                        05-25-2025, 02:19 PM
                                      • ctroxtell
                                        Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                        by ctroxtell
                                        I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                        01-03-2025, 08:57 PM
