Dell Ultrasharp success!
  • etnietering
    • Apr 2009
    • 379
    This past weekend, I get a message from my buddy saying he found a non working dell ultrasharp 19 inch LCD monitor in his basement (don't ask for the part number, I don't remember it), and took the back off and lo and behold, leaking caps on the power supply!
    The troublesome caps were all CapXon brand. Three had leaked brown poop out the top, and a few of the others were bulged. Neither of us had any premium caps sitting around to replace them with, but I dug through my bin of power supplies and found one with suitable replacements for the leaking caps. (it was an LIC "400W" one...hahahahahahaha) anyway, we were able to replace the three leaking CapXon KF series (i think) with 2 'low ESR' H.Q. brand caps, and one 'low ESR' ASIA`X, all 1000uf / 10v. This brought the monitor back to life, but I told him to not run it until these could be replaced with something decent, knowing that these are from absolute sh1t brands. So we ordered some good caps from digikey, and the replacements went as followed:
    3x CapXon 1000uF 10v -> Panasonic FM 1000uF 10v
    1x CapXon 1000uF 25v -> Panasonic FM 1000uF 25v
    4x CapXon 470uF 35v -> Nichicon HE 470uF 35v
    2x Su'scon 220uF 50v -> Panasonic FM 220uF 50v
    Here's the before picture - with my temporary H.Q. and ASIA`X caps (the little ones), and the bulging 25v ones. When we took them off we found that 3 of them had vented through the bottom.
    Here's the after picture - lovely panasonic T vents all over The 2x 220uF ones went in the inverters, which weren't visible in the previous picture
    The monitor works with all the new caps, and should for a good long time. After doing this recap, as well as my router, I have more confidence to work on power supplies and maybe motherboards, should I encounter one that needs help.
    Thanks to everybody here, I found out all I needed to know without even asking!
    Eric
  • yanz
    • Nov 2004
    • 910
    Re: Dell Ultrasharp success!
    Panasonic FM and Nichicon HE. Good choices!
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Congrats!
      And I agree. - Good choices.
      Mann-Made Global Warming.
      - Dr Seuss
      • MrVik
        • Apr 2009
        • 18
        Thanks for the verification of the parts list (LOL). I have a Dell 1707FPVt dumpster find with the seemingly exact power supply board, except mine had one leaker and two bulgers. This is the first time I've found Su'scon. I was looking them up when I found your post. Good job.
        Why throw it away? I might need it in the next 40 years. Duh!
        • etnietering
          • Apr 2009
          • 379
          Good luck with the recap! Let us know how it goes
          • MrVik
            • Apr 2009
            • 18
            My wife is gone to Oklahoma with both my digial cameras so I can't show before and after pictures, but......It looks great!
            Guess which ones were bad. The bulged ones read 1.2 and 1.3 on my blue meter.
            • Akhlz001
              Dell Pro 13 Plus PB13250 Bios Unlock
              by Akhlz001
              Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
              09-20-2025, 07:15 PM
            • master3112
              Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
              by master3112
              I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
              Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
              The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
              07-29-2025, 01:55 PM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
            • diamon
              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
              by diamon
              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
              Pictures of these boards:
              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
              Dell...
              02-28-2024, 12:51 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
