IPIBL-LB loses BIOS settings after power off
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Had this a while, and recently decided to use for a build
    Was working fine, until froze up in the final stages of a Win7 update
    Since then, most obvious problem is every time started after power off, comes up with message:
    "Default BIOS settings have been loaded due to BIOS update or checksum issue"
    Please don't suggest battery - first thing to be replaced
    Then I convinced myself its KZGs must be the culprit, so replaced them with recycled MBZ and, for sharp-eyed, newer KZG in VRM input - all tested OK on ESR meter
    Made no difference
    I've tried different processors, different memory, different battery - nada
    Any insight or suggestions? - my gut feeling is flakey CMOS memory, but isn't that built into Southbridge now?
  • Sparkey55
    • Jan 2010
    • 1523
    Re: IPIBL-LB loses BIOS settings after power off
    Did you update the BIOS and if so can you go back to any previous version?
    • Sparkey55
      • Jan 2010
      • 1523
      Do you have an HP BIOS on it or an ASUS BIOS. (checksum error)?
      Googling on it shows some people say board not compatible with 7.
      Can you load Vista or XP on it to see if the same problem occurs?
      More info please.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        1. Yes, to 5.43
        2. Yes, retained 5.17, could revert
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          More info please.
          HP BIOS - 5.43
          Tried loading XP recently, for another reason
          Left it alone for the tedious early stage, came back to a blue (only) screen and frozen
          Ctrl-Alt-Del didn't work, nor did shorting reset pins on Front Panel header - had to power off, thus back to BIOS settings
          Board was working perfectly with Win7
          Had loaded it up, installed drivers, activated, installed KB3020369, and then it froze during install of KB3125574
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Update:
            Reverted BIOS to 5.17, then clean installed XP SP3
            After power off, same problem
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              I doubt this is the issue, but... I notice in the uploaded pictures above that one of the memory modules may not be completely in the RAM slot, judging by the slightly unlocked RAM lock lever.
              Aside from that, I wonder if this motherboard's issues have something related to the common "Chassis Intruded" problem seen on other ASUS motherboards.
              What's a bit unsettling is that I also have an HP PC with an IPIBL-LB mobo that's been a bit finicky. Namely, when I got the board, at first it wouldn't always boot, then sometimes it would interpret the power button as a reset button, and it also manage to freeze on me a few times. But after using it for a while, the issue went away? And now it's fully working. (Though we all know the saying about issue that fix themselves, right? ).
              Anyways, I know this isn't quite helpful. That said, going with your gut feeling about the flakey CMOS RAM also sounds plausible to me. As for whether CMOS RAM is in SB or not... I'm not sure, but you can check the small ICs on the board. I think many boards of that era still used separate chips for storing CMOS.
              • on/off
                • Oct 2016
                • 333
                • Indonesia
                Also I'm notice " a jumper".
                Is it on correct set position?
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  That jumper is related to SPI BIOS recovery
                  It is correct, and required, according to SPI Header section of https://support.hp.com/au-en/document/c01324212
                  Board won't power on if jumper is removed
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    ICH9 has "256-byte battery-backed CMOS RAM" according to attached
                    Hmmm, this P.O.S. is getting dangerously closing to joining its colleague the GA-Z77H-D3H - https://www.badcaps.net/forum/showthread.php?t=74364
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Ah. :\
                      I'd still check for any external CMOS chips, though. Maybe ASUS didn't use the one in the NB? (On second thoughts, I need to pull my IPIBL-LB from storage and remove its CMOS battery, as I will be moving it into deeper storage soon and don't want its battery to go bad in there. Could concurrently check with you if there is such a chip then.)
                      Let's hope not.
                      BTW, did you look into the possibly partially seated RAM, as I mentioned in my previous post? I know it's something you wouldn't miss... but it would be almost nice if the problem was a simple issue like that.
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        Sort of - in that I'm currently trying it with a single 2GB DDR2-6400U
                        I usually make sure latches are pushed in, can only assume that one moved when it was having its picture taken
                        • Sparkey55
                          • Jan 2010
                          • 1523
                          HP BIOS - 5.43
                          Do you mind sharing what the BSOD message was?
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            Another thing to check.
                            You say HP BIOS update, might be a hidden BIOS menu.
                            Worth looking into.
                            F2, F10, F11?
                            • Sparkey55
                              • Jan 2010
                              • 1523
                              https://retrohelix.com/2012/09/how-t...-hp-computers/
                              Found this, might help getting into the advanced BIOS settings menu.
                              If your CPU fan is turning below a certain RPM or stalls at some point in the boot process the BIOS CPU protection sensors maybe shutting you down. In that case you need to disable CPU FAN MONITOR DETECTION.
                              • pfrcom
                                Oldbie
                                • Jun 2006
                                • 1230
                                Unfortunately what I meant by "blue (only)" screen was there was no message, just a blue screen
                                • pfrcom
                                  Oldbie
                                  • Jun 2006
                                  • 1230
                                  I've been trying it with a fan connected to System header, to forestall error message
                                  Have tried Ctrl-F10/F11/Ctrl-F11 a few times, but succeeded only once in getting the Advanced menu
                                  With wisdom of hindsight, I should have disabled fans detection then
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    Most recent attempt was replacing the last remaining KZG (capacitor racism), a 470uf 16v, with a new KY
                                    At the same time removed, cleaned and replaced the battery holder, underneath which looked a bit grotty
                                    Didn't make any difference
                                    • pfrcom
                                      Oldbie
                                      • Jun 2006
                                      • 1230
                                      FWIW, other weird behaviour is, if I short Reset pins on Front Panel header, more often than not there's a delay, then it powers off
                                      At that point just shorting the Pwr pins won't start it - I have to switch power off & on before it will start again
                                      So I need to remember to use Ctrl-Alt-Del for reset
                                      Something fundamental seems to have gone wrong with its electronics - reckon I'm
                                      • Sparkey55
                                        • Jan 2010
                                        • 1523
                                        Check to see if you have the switches connected in the correct pins on the header.
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                                          by cr4zychriss
                                          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                                          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                                          • Barebone / Chassis: TongFang GK7MRFR
                                          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • YG007
                                          Asus BIOS How To Reset To Default Settings?
                                          by YG007
                                          Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                                          I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                                          06-05-2023, 08:22 PM
