GA-Z77M-D3H starts, then stops
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Thinking it might be a BIOS problem, I bought this from an ethics-deficient person who described it as starts but won't POST
    Well, it does start but turns off after about one revolution of the CPU and power supply fans
    Is this a problem anyone is familiar with fixing?
    If so, hand-holding please
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: GA-Z77M-D3H starts, then stops
    There are others that probably know more that me but I want to throw this out there. if the board was working fine before it could be weak caps despite being all solid. My zotac h67 1155 board will turn on 1 sec fan spin then off and over and over, however if I put a space heater infront of the board and warm it up for about 10 minutes I will start every-time after that.
    Just a suggestion to try.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      thats not a cap problem. thats a problem with bad bga solder joints.
      • piernov
        • Jan 2016
        • 4439
        • France
        Does it stay on with the P4 CPU power connector disconnected?
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          It does not - exhibits same behaviour, whether 12V ATX is connected or not
          All testing done with a G630 in the socket
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Try forcing the motherboard on by shorting the PS_ON signal to ground directly on the PSU's connector (keep the PS_ON shorted the whole time). Do this once with the 4-pin CPU power connector unplugged and again with it plugged in. Does the PSU turn On and shut down or does it stay On. If it shuts down, you likely have a short-circuit somewhere on the board. If it doesn't shut down and runs okay, try pressing the power button on the motherboard/PC case (with the PS_ON still jumpered to ground on the PSU connector.) Does the PSU continue to work or does it shut down. If it continues to run, then likely there aren't any shorted components, at least. In which case, I suggest inspecting the CPU socket carefully for bent pins, and also trying to flex the motherboard around the CPU socket and chipsets while trying to power on - it could be bad BGA. Also check if the ethernet chip is getting hot or not. And try re-seating the RAM several times, as well as trying different sticks (and preferably only 1 or 2 sticks at a time, max).
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              With PS_ON shorted to GND (bit of thin solder wire bridging Green & Black on ATX connector):
              PSU stays On, regardless whether 4-pin connected
              When 4-pin connected:
              Three keyboard LEDs light briefly
              CPU fan races, then slows down - giving impression it's going to POST
              Doesn't shut down if I short PW+ & PW- on Front Panel Header (testing board on wooden surface, connected to PSU having its own On/Off switch)
              And still works the same way if I jumper PW+ & PW- before switching power on
              They look good to me - and I tried cleaning socket & pins by squirting with IPA before reinstalling CPU (G645 this time instead of G630, with different HSF)
              Atheros IC feels normal, as does VIA codec and ITE Super IO
              Although did have some power glitches when I was feeling around that area, but couldn't reproduce symptoms readily
              Still a work-in-progress - at least didn't release the magic smoke with shorted PS_ON & GND
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                That means issue is not a bad/shorted MOSFET.
                And depending on how the motherboard is configured for POST, the blinking of they keyboard LEDs could mean all power rails are up and running properly.
                Right. As long as your manually shorting the PSU's PS_ON signal, the motherboard won't turn off from the power switch.
                So that rules out the power-up circuitry too.
                Try flexing the motherboard around the CPU socket then. Have the motherboard flat and do the flexing with and without tightening the CPU heatsink (this can be a bit tricky, so be careful).
                Try the same with the chipset heatsink too (but do *not* try it with the heatsink unmounted/loose from the board.)
                No, of course it won't.
                ... not unless you have a really high-power PSU and a partially-shorted MOSFET. Then things can get a bit more "interesting". - Seen that on a high-end graphics card. Some of the MLCCs on the card literally zapped and sparked like firecrackers. PSU was a 1 kW behemoth, though, with no or very high 12V rail limits. So that's why it didn't shut down and kept going.
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  Thanks everyone, especially Momaka, for trying to help
                  Have tried the flexing a bit, albeit with trepidation
                  No success, so, have scrapped the board
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Sorry to hear that it still didn't work. But I guess that's just luck sometimes. :\
                    • Caimano
                      Asus P2520L starts and stops ok but no display
                      by Caimano
                      Model Asus P2520L
                      MB P552LA_LJ Rev 2.1 with soldered I3 5010U processor
                      The laptop charges battery and seem to react to power on, power off, reset regularly, but nothing appears on screen or HDMI or VGA monitor.
                      Same behaviour when running on battery only, on mains only or on both.
                      Battery charges fine. RTC battery ok at 3.025V.
                      When powered on the power on led lits, after a short while the HDD led flashes, but no video. All voltages seem present. ALL_SYSTEM_PWRGD is present, BUFF_PLT_RST# goes high. CPU warms up and fan starts and stop from time to time....
                      03-29-2023, 03:05 AM
                    • Cornito
                      Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                      by Cornito
                      Hello Team,
                      I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                      Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                      Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                      08-08-2024, 08:09 AM
                    • chaos-theory
                      Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                      by chaos-theory
                      I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                      Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                      03-14-2025, 05:37 PM
                    • dannobyte
                      HP-D2402E0 PSU starts then stops
                      by dannobyte
                      PSU with a model number HP-D2402E0
                      Fault: When the start button on the desktop is pressed the fan briefly (1 or 2 seconds) starts spinning and then stops. Sometimes it will continue starting and stopping, other times it will cycle once and then stop.
                      Tests conducted: I removed the PSU from the desktop case and plugged it in to the mains. I then shorted the green wire to earth and the fan spun up normally So when the PSU is connected to the motherboard it fails but when it is disconnected from the motherboard it works as normal.
                      Possible conclusion:...
                      09-30-2021, 10:13 PM
                    • Info13
                      Dell H235P-00 Power Supply Failure
                      by Info13
                      Hi everyone,
                      A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
                      After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
                      ➡️ First test:
                      The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
                      A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
                      I then followed the advice from the forum and replaced...
                      10-22-2025, 01:52 PM
