Power source with loud noise and does not work well (FDPS-100N-R5)
  • SoporteHR
    • Sep 2018
    • 80
    • Venezuela
    Hi all.
    Receive a warm greeting.
    I am writing for the following.
    I have a power source for CCTV system.
    The plate indicates model: FDPS-100N-R5
    They delivered it to me without igniting, I checked the fuse and it was well, visibly two condensers in the exit bulky.
    It has an area near the integrated TL494 obscured on the PCB.
    Initially look for components in short circuit or open and I did not find them (Photo with green marks these components are verified)
    I connected power through the 100W series and the bulb did not turn on. The dead source, check if there is voltage to the IC and it does not.
    I check the high voltage part and I have 155vdc at the output of capacitors C5 and C6.
    But at the exit of T2, I have nothing, I dismantle it to verify continuity in the coils and they are fine, the transistors Q1 and Q2 are heated.
    I remove the PCB Q1 and Q2, I measure them and I find one of them in flight. replace the two.
    I connect the source and it starts but the transformer T1 starts zoning as if it had a relet inside (RRRRRrrrrrRRRRrrrrRRR)
    At the output of the source I have 10vdc, but in the pins 12 vcc and 7 GND of IC1 I have no voltage, in all that sector there are 0.40 to 0.63vdc.
    Please can you give me some ideas of what else to review or if someone has an outline of this source.
    Annex photos with the mediated obtained from voltages
    Thanks in advance.
  • R_J
    • Jun 2012
    • 9606
    Re: Power source with loud noise and does not work well (FDPS-100N-R5)
    If you are getting 10vdc I would replace the small electrolytic capacitors in the primary like C9, C17, C13 etc.
    The power supply is working but is not regulating properly
    I found these diagrams that might help.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      look at these little capacitors that are close to a heat source (where the circuit boart turned color to brown). Probably that PSU could stand to have all of the 6 little caps changed.
        • 31246
        check the voltage switch - that's a lot of corrosion on it!
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Is that still with the 100W light bulb connected or not?
          If it is with the 100W light bulb, then add another 100W bulb in parallel to it. Some PSUs simply don't like to have a light bulb on the input and might oscillate like that.
          Also, check/replace all the small electrolytic caps, as the others have suggested.
          • SoporteHR
            • Sep 2018
            • 80
            • Venezuela
            Thanks for your answers, today I will try replacing all the small electrolytic capacitors.
            If I thought the series was the problem, so I connected it directly to the 110vac line, the noise persisted.
            I will notify you of the results.
            • SoporteHR
              • Sep 2018
              • 80
              • Venezuela
              Thanks for schematics R_J
              • SoporteHR
                • Sep 2018
                • 80
                • Venezuela
                Hi all.
                Make the change of small capacitors, C11 and C10 did nothing. regarding the sound or voltage failure in the secondary of T2.
                C13 and C17, C18, did nothing either.
                When I changed C9, I already got a voltage of 16 vdc first, then low and stabilized at 7.6vdc.
                Replace C22, ceramic condenser, since I saw it darkened.
                However, on pin 12 of IC1 I have no tension.
                I attach images of the tensions that I am already getting. and the video with the sound generated by the PSU before the change of capacitors.
                The output of T2 I already have 7vdc.
                Replace C5 and C6, original 220uf x 250v, replacement 330uf x 200vdc. (line voltage 110vac).
                Probe C6 with the tester (Diode function) and did not load.
                The noise became faster and sharper. but it was not removed.
                The output voltage at the source went up to 14 vdc
                Removed IC1 to check for pins in short circuit and found the following.
                Tester in function Diode test / continuity
                Pin 7 (GND) with Pin 13 (Output Control) = 0,32ohm
                Pin 7 with pins 10 (E2) and 11 (C2) = 0.10 ohm
                Pin 7 with pin 1 = 617 ohm
                Pin 7 with pin 2 = 617 ohm
                Pin 2 with pin 13 = 632ohm
                Pin 3 with pin 11 = 615ohm
                Pin 7 with pin 4 = 625 ohm
                Pin 4 with pin 11 = 625ohm
                Pin 5 with pin 6 = 753 ohm
                Pin 7 with pin 5 = 592 ohm
                Pin 12 (VCC) no reading regarding the other pins
                I do not have that replacement IC to change or test.
                Thank you.
                  • 31246
                  if the switch is bad it will expect 220v and only see half the required voltage.
                  • SoporteHR
                    • Sep 2018
                    • 80
                    • Venezuela
                    Hi, STJ,
                    That Switch was one of the first that I checked, because of the corrosion I saw, so I made a bridge with tin in its pins.
                      • 31246
                      o.k.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        220V=If an old transformer, IIRC, when we used to only be 110V.
                        These days, 110V is considered a brownout, L O L
                        Chronologically, it likely went like this in the U.S.:
                        110,115,117,120
                        With the pre-120V-rated ones likely being transformers that contained PCBs, if not also from the still-leaded gasoline and still-leaded paint era...
                        Even though, GMP seems to consider 123-125V defacto. Even when I once thought that they're possibly changing it to 127V.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • SoporteHR
                          • Sep 2018
                          • 80
                          • Venezuela
                          Re: Power source with loud noise and does not work well (FDPS-100N-R5) Case Closed
                          Hi all.
                          Finally, I managed to find the problem of noise at the source (RrRRRRrrrrr) and the poor voltage output on the secondary.
                          I removed the IC TL494 and replaced it with another that I extracted as a test of an ATX PSU. Immediately the source stopped ringing and the voltage on the PIN 12 stabilized at 17.55vdc and on pins 13 and 14 I got the reference voltage of 4.94 vdc. (5vdc nominal)
                          So this was the whole problem, the failure of the IC affects the operation of both the primary and the secondary.
                          Now it's time to locate the new replacement components, since it uses pieces extracted from other equipment as a test.
                          Attached for future reference, image with the voltages measured when the source is operating correctly.
                          It was impossible for me to measure the voltage on the primary pins of T2, the multimeter goes crazy.
                          Thank you all for the comments and help provided
                          Case closed.
                          • R_J
                            • Jun 2012
                            • 9606
                            Good to here you found the problem, Some meters do not like the high frequency pulses, that is likely why your meter has problems measuring the primary voltages.
                            I have an LG meter that goes overload when checking the Vs voltage on some plasma tv's (fluke checks them ok)
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8340
                              Happy you solved this problem. Usually IC's either work, or they don't. I guess in this rare case, the IC was at fault. There was nothing much more left to check on that board.
                              • R_J
                                • Jun 2012
                                • 9606
                                I just had a closer look at your Goldstar DM-311 meter and it is the same as the LG DM-311 I have on the bench. They just don't like checking dc if there is a high frequency pulse also present like in smps and and ysus boards.
                                • SoporteHR
                                  • Sep 2018
                                  • 80
                                  • Venezuela
                                  Hi R_J
                                  What a coincidence, if the screen really turns on all the decimal points of the display or shows very fast erratic readings.
                                  So nothing, impossible to measure anything with it in the primary.
                                  Thank you all for your comments.
                                  Greetings.
                                    • 31246
                                    LG = Goldstar.
                                    the original comany name back when i was buying 5¼ floppy disks from them was "Lucky Goldstar"
                                    so now you know what "LG" stands for!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Ah, I missed the replies.
                                      Good to hear you got the PSU fixed, though. (And all by your own troubleshooting work too. )
                                      I'm surprised no one saw these readings as problematic, particularly the short-circuit between C2 and E2. In fact, this is most likely causing the buzzing you heard and the reason for the partial voltage. After all, pins 10/11 are used for the output drive, along with pins 8 and 9 (C1 and E1). In a half-bridge PSU, all of these are used. But with C2 and E2 being shorted, one of the transistors on the primary side will never be driven to turn On... and hence why the PSU couldn't come up to full output voltage.
                                      All the other readings are problematic too, as some pins are pretty much heavily insulated from each other.
                                      It should be fairly easy to find a replacement IC like that. Just about every older cheaper/gutless/crap half-bridge ATX PSU has it. So just go around a few computer shops and ask if they have old broken AT/ATX PSUs.
                                      As for the IC itself (TL494)... you can actually use any of the following:
                                      DBL494
                                      KA7500
                                      The KA7500 is basically pin-compatible replacement for the 494. That said, some very old socket 462 motherboards also used a 494/7500 chip for the CPU VRM (mostly cheaper ones like ECS and PC-chips). If you have a dead one from that era, have a look. It may just have this IC.
                                      • SoporteHR
                                        • Sep 2018
                                        • 80
                                        • Venezuela
                                        Hello STj, thanks for the info, if you knew that change of name from Lucky GoldStar to LG.
                                        Momaka, thanks for your comments, it was a challenge and it helped me to solve it was when I decided to change IC1. After that the source began to work perfectly and zero noise.
                                        The components as you comment, use them from a PSU ATX that had no use.
                                        It's a pity that the client found the repair very expensive, now in Venezuela, the cost of repairing has exceeded the cost of purchasing a new unit.
                                        Finally one of the primary capacitors of 250v x 220uf does not indicate reading with the tester or with the ESR meter that I built. Then the total of components to change is 17.
                                        So, I only had the experience and learning. (which is important)
                                        Thank you all.
                                        • eliemgh
                                          lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
                                          by eliemgh
                                          lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
                                          09-27-2024, 02:40 AM
                                        • justice171
                                          Lenovo E15 Gen 2 Keeps Beeping Loud Noise
                                          by justice171
                                          Hello Badcaps Members,
                                          I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
                                          I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
                                          When I use Lenovo PC Diagnostics App I get results as 01000
                                          Here are the details:
                                          • Model: Lenovo ThinkPad E15 Gen 2
                                          • Board Numbe
                                          10-01-2024, 09:19 PM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • dicky96
                                          DynAudio DBM50 Monitor Speaker - loud hissing noise
                                          by dicky96
                                          Hi guys
                                          I have a DynAudio DBM50 here - it makes a loud hissing noise.
                                          It sounds just like an FM radio with no antenna (or tuned off-station). The volume of the hissing fades up and down, sometimes drops to almost nothing then comes back loud. It occasionally makes a loud bump noise too.
                                          It does this even with nothing connected to the audio input XLR
                                          Any suggestions?...
                                          11-09-2020, 08:45 AM
                                        • Lvsitano
                                          Asus X532FL 3.2V at source and gate
                                          by Lvsitano
                                          I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                          First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                          I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                          First...
                                          06-26-2024, 02:13 PM
