Please Use a Fume Extractor and a Mask
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear Forum Members,
    There are very nice members in this forum who help others. I have never seen such kind experts.
    But I noticed many forum members do not use any fume extractor while they do soldering. Flux is extremely dangerous if it reaches our eyes, or if we breathe it in, or if it stays on our hands.
    Therefore, I ask all the forum members to follow these recommendations while soldering:
    1- Use a cheap surgical mask to avoid entering the flux fume into your respiratory system.
    2- Keep your eyes away from the flux fumes.
    3- Wash your hands for a long duration if they got fluxy.
    4- Use a fume extractor.
    You may say that a fume extractor bothers you by taking the space on your table. this can be solved by installing the fume extractor a bit above the table. In the picture, I demonstrated where to install the fume extractor.
    You can buy a fume extractor or make it yourself. For example, search on youtube for "fume extractor" to watch how to make one.
    I made a good fume extractor for me. I used a flexible pipe and installed two computer case fans at the two sides of it. I connected a 12v power adapter to both the two fans. One fan breathes the air in the pipe and the other fan blows the air out of the pipe.
    A good characteristic of this design is that I placed the output side of the pipe out of the window of my room. So the fumes get out of my room.
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Re: Please Use a Fume Extractor and a Mask
    What's with the flux flumes?
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      I do this for a living... The mask is overkill. So is venting outside. Seriously, just pump it though a carbon canister.
      Follow the white rabbit.
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I have a Purex fume extractor unit, looks like a small vacuum cleaner on the bench that I would not be without, It was intended to be used as a solder tip fume extractor but I reamed out and use a larger connecting hose and funnel now with it. Its a real nice unit but now listed as discontinued
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          I do not know how much harmful it is to release flux fumes into the outdoor air where nobody breathes them in. Standard fume extractors absorb the flux fumes using a filter. I do not know which one is safer for the environment.
          • R_J
            • Jun 2012
            • 9627
            With all the fighting etc. going on in your area of the world, your worried about some solder flux fumes entering the enviroment?
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              I think the metallic fumes is the hazard here and not so much the flux fumes.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                Breathing flux fumes in will lead to respiratory problems in short term and will lead to cancer in long term.
                I have a mechanic friend. he is exposed to dust in his repair center sometimes. Although it is just dust, he has got respiratory problems and continuous coughing after 5 years of working. Now think if it be a dangerous chemical such as flux fumes instead of dust.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8713
                  The amount of rosin volatilized by soldering is so low and virtually none is actually burning so that it's much safer than tobacco smoke or wacky tobacky smoke in which one is actually trying to suck up.
                  Car mechanics have to worry about powdered asbestos which has been shown to be a problem, else maids breathing regular dust when cleaning houses would also be an occupational hazard.
                  ... at least I would assume people here are mostly dealing with either repair or one-off assembly. All bets off if you're doing 24/7 hand assembly with rosin flux...
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Or just blow it away from your face when you solder.
                    That's what I do now. (Yes, seriously. ) If the weather is nice, I open the windows in my room too. Of course, this is only applicable to when I do hand-soldering (which mostly comes down to recapping these days).
                    If I do any "reflows" on my stove in the kitchen, I open all of the house windows afterwards, as that creates quite a bit of "PCB stink", even if I don't use any flux (and lately, I don't, because I've found that most GPU failures are between the GPU substrate and GPU die - i.e. nothing that flux can help with, so I don't even bother with it.)
                    It all depends on the quantity of "pollutants". A small repair shop doing a few boards a day hardly releases more toxins in the air than maybe 2-3 cigarettes. An exception to that would be perhaps those who do chip reflows/rework, as that releases a significantly higher amount of fumes... but still nowhere enough to be considered harmful for the environment. Though it is probably enough that it can be dangerous to breathe it constantly throughout the day. So in those cases, using a filter or venting the fumes out of the room would be a good idea.
                    Exactly.
                    Regular house dust (from linens and such, not silica dust from cement or similar materials) usually causes asthma and/or increased sensitivity to dust and/or allergies over time.
                    Exactly! x2
                    If you're basically doing soldering work only once in a while, with that mostly being the occasional soldering/desoldering of a few components, I don't think you have that much to worry about. But if you're doing it for 8+ hours a day in a room full of flux fumes (or sleeping in the same room where you've been soldering all day), of course that's going to be different.
                    • chth96
                      Is it good to use chemistronic flux off es835b for flux remover?
                      by chth96
                      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                      11-17-2023, 07:25 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • myth77
                      UV solder mask - high temp resistent, recomendation?
                      by myth77
                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                      Is there any solder mask...
                      03-28-2022, 04:04 AM
                      Multifix 425-01 and 450-01 Rework Flux Datasheet
                      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                      - No Clean Formulations
                      - Low residue
                      - Range of activity to deal with different component solderability
                      - Halide free
                      - Suitable for dispensing
                      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                      Both products are supplied in syringes or cartridges for application by dispensing....
                      10-07-2024, 06:02 AM
                    • mikay786
                      Scope and Fume Extractor
                      by mikay786
                      Can anyone recommend a decent microscope and fume extractor on the cheap don't mind Chinese stuff if it does the job. UK here so anything eBay / amazon would be ideal.
                      Got my first hot air station the other day so might as well go the whole hog. Working on a couple of MacBook with backlight issues so above will be helpful.
                      09-04-2020, 02:05 PM
