Scope and Fume Extractor
  • mikay786
    • Aug 2014
    • 765
    Can anyone recommend a decent microscope and fume extractor on the cheap don't mind Chinese stuff if it does the job. UK here so anything eBay / amazon would be ideal.
    Got my first hot air station the other day so might as well go the whole hog. Working on a couple of MacBook with backlight issues so above will be helpful.
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: Scope and Fume Extractor
    Hello
    For an scope you can look into Amscope and fume extractor an FEK-01
    • diif
      • Feb 2014
      • 6978
      • England
      If you're only doing a bit of soldering you can rig up a 12v PC fan to suck the fumes away.
      It leaves more money for a stereo microscope.
      Amscope seem to be the microscopes people buy new, I bought a used Kyowa off ebay.
      Just remember to check the zoom before you buy, IIRC the cheaper Amscopes have a bit too much.
      • dellxps15
        • Feb 2014
        • 1591
        • italy
        for fume extractor i use ah hakko or similar for 45€ new.
        for scope it really depends on how much often u will use it. i went for a cheaper amscope priced 220€new and i regret it as the most expensive 500-700€version boomstand is much much better... the are u can look after the zoom is really bigger... with my scope if i zoom a 128 pin ec, i can only look some part of it and not the whole chip and zome so work is just not as much perfect. in addition to that when i use the scope.... i need 2 bags under my ass because u cant be normally sit and look through the scope....
        • mikay786
          • Aug 2014
          • 765
          Cheers for the recommendations, amscopes seem good ones but a bit pricey. Im only a dabbler and will rarely use, just the odd bit here and there. Been reading around and for a fume extractor
          https://www.ebay.co.uk/itm/220V-FA-4...72.m2749.l2649
          and for a scope from a review on here
          Andonstar ADSM302 - https://www.badcaps.net/forum/showthread.php?t=87617
          https://www.banggood.com/Andonstar-A...r_warehouse=UK
          Will these be decent enough?
          • diif
            • Feb 2014
            • 6978
            • England
            They will do the job but in a very uneconomical manner. A flat 2D image on a screen is no comparison to looking through a stereo microscope that gives proper depth of field and a second hand stereo microscope can be bought much cheaper.
            • mikay786
              • Aug 2014
              • 765
              Thanks ill take a look at second hand stereo ones then.
              • caspian
                Please Use a Fume Extractor and a Mask
                by caspian
                Dear Forum Members,
                There are very nice members in this forum who help others. I have never seen such kind experts.
                But I noticed many forum members do not use any fume extractor while they do soldering. Flux is extremely dangerous if it reaches our eyes, or if we breathe it in, or if it stays on our hands.
                Therefore, I ask all the forum members to follow these recommendations while soldering:
                1- Use a cheap surgical mask to avoid entering the flux fume into your respiratory system.
                2- Keep your eyes away from the flux fumes.
                3- Wash your hands...
                12-08-2018, 03:10 AM
              • dicky96
                Solder fume extractor - recommendations?
                by dicky96
                Hi guys
                I figured I'm gonna have to add a fume extractor to my shopping list.
                To be honest I don't currently have one.
                Starting as a hobbyist in the 70s, and then all through the 80s and into the 90s when I worked full time in electronics repair, in large workshops with 100+ repair engineers, I never even saw or heard of such as thing as a solder fume extractor. And that was leaded solder of course. To be honest I think you were breathing in more crap from the other engineers who smoked than you ever would from the soldering iron. In fact I kinda like the...
                11-20-2019, 12:45 PM
              • chegueva
                My Andonstar ADSM201 Microscope Review
                by chegueva
                Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
                About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
                So i had a choice between a binocular & camera , i wanted...
                08-14-2020, 11:08 AM
              • repair-it
                Need advice testing a samsung power supply board with scope
                by repair-it
                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                07-12-2025, 11:00 AM
              • lcdcaps1
                INSKAM Microscope USB port issue
                by lcdcaps1
                Hi
                All
                Does anyone have a INSKAM 7 inch LCD digital microscope
                I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
                The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
                I have tried different cables and different USB power adapters
                I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another...
                04-18-2025, 04:16 AM
