LG 42LN5400 backlight issue, double-check my troubleshooting
  • gustagen
    • May 2011
    • 86
    Hi everyone! I am 3 for 3 in repairing a monitor and two TVs with this forum's help. I've also been able to repair a few without the forum's help.
    I'm back today with an LG 42LN5400 that has a backlight issue. It was rescued from the curb.
    During power up, the backlight flashes briefly. I can see the on-screen display using a flashlight.
    During power down, the backlight flashes quicker and dimmer.
    I understand that failing LEDs are common with this model, but I want to verify my testing before proceeding.
    I've followed along with the troubleshooting steps in this thread and have found the following:
    at connector P201:
    Pin - Standby, Power Up
    GND - 0V, 0V
    12V - 0, 12
    12V - 0, 12
    GND - 0, 0
    24V - 0, 24
    GND - 0, 0
    3.5V - 3.5, 3.5
    3.5V - 3.5, 3.5
    PWR ON - 0, 3.3
    GND - 0V, 0V
    NC - 0, 0
    12V - 0, 12
    GND - 0, 0
    24V - 0, 24
    GND - 0, 0
    PDIM2 - 0, 1.1
    PDIM1 - 0, 1.1
    DRV ON - 0, 3.3
    at P801, cable connected, black lead to chassis ground:
    Pin - Peak At Power Up, After 10 Seconds
    Pin 1 - 114V, 27V
    Pin 3 - 75, 66
    Pin 5 - 0.5, 0.6
    Pin 7 - 172, 90
    When Pin 1 of P801 is disconnected, the backlight does NOT flash at power up.
    Attached are photos of the power supply PCB and the chassis label.
    Do my measurements indicate a working power supply and faulty LEDs?
    Thanks for any help you can provide!
    Re: LG 42LN5400 backlight issue, double-check my troubleshooting
    It indicate you have open circuit in one of the two LED strings. That is why the Voltage went up to 172V.
    Pin 5 - 0.5, 0.6
    Pin 7 - 172, 90
    • gustagen
      • May 2011
      • 86
      Thanks, budm. I suppose the next step is removing the panel.
      I have another question. In the other thread dhoff024 reported these readings at P201 on power up, which you indicated were on the low side:
      PDIM2 - 0.8V
      PDIM1 - 0.8V
      DRV ON - 2.8V
      My measurements are:
      PDIM2 - 1.1V
      PDIM1 - 1.1V
      DRV ON - 3.3V
      Are my measurements in range? What should those pins read?
      I will proceed with removing the panel and report back. I plan to record a slow-motion video during power up to see which LEDs aren't lighting.
      • gustagen
        • May 2011
        • 86
        I successfully removed the panel and was able to use my phone to make a video of the emitters flashing during power up. I've attached a screenshot.
        Only the top and bottom LED strips are flashing during power up. The middle three rows remain off.
        I connected three 9-volt batteries in series and tested each row individually at the contacts nearest the PCB.
        Rows 1, 3, and 5 lit up fully with my test rig.
        Row 2 partially lit up, but its 4th emitter did not. I removed the optic and found it was shorted.
        Row 4 did not light at all. I applied power to just the left half of the row, and those five emitters did light.
        I tested row 4's five right-side emitters with my DMM in continuity mode and found one that was faulty.
        I swapped the left sides of rows 2 and 4, which are both labeled L2. Now I have four fully working strips, with row 4 needing just two emitters.
        Is it worth the effort to simply reflow two new emitters, or is it inevitable that more LEDs on these strips will fail?
        Am I better off replacing all of the strips with a new 10-piece kit?
          You may be better of replacing the whole set instead of taking a chance of taking the delicate panel apart more than once. When done you need to turn down the backlights level (not Brightness) to may be 50% to help extend the LED's life.
          • gustagen
            • May 2011
            • 86
            That's good advice, budm. Saving a few dollars now might result in a cracked panel later!
            In addition to lowering the backlight level, I've read that a firmware update is also advised when replacing these backlight strips. Apparently the new firmware doesn't drive the emitters quite so hard.
            I'll order the parts today and report back when they arrive. Thanks again!
              Update to latest FW will probably help but I still think the LED's are still driven hard with the FW update. Just make sure to lower the backlights on all input any way.
              • neilc6
                • Nov 2015
                • 1550
                If you are going to be doing more tv repairs, you should invest in a backlight tester. Bonus is that you get a pair of sharp probes you can use with your multimeter.
                https://www.aliexpress.com/store/pro...909018049.html
                • gustagen
                  • May 2011
                  • 86
                  Success!
                  The replacement LED strips arrived and the TV is working great.
                  I turned the backlight level down to 60% to help these emitters last a bit longer. I'll do the firmware update, too.
                  Thanks, everyone!
                    Thanks for the follow-up on the repair.
                    Can you please provide the link to the seller you got the replacement strips from so it will help other people as well? Thanks
                    • gustagen
                      • May 2011
                      • 86
                      I found the lowest price for replacement LED strips on eBay by searching for "LC420DUE" which was on the chassis label indicating the panel model.
                      I was sure to order NEW strips, not used. My set was about $33, including shipping from/to the USA.
                        Do you still have that seller name and link? Most of EBAY sellers sell used strips.
                        • neilc6
                          • Nov 2015
                          • 1550
                          I've purchased both new and used strips from Chinese ebay seller meihua361000 with no issues. Quick epacket shipping (1-2 weeks) and packaged securely.
                          https://www.ebay.com/str/meihua361000
                            Thanks, I like to keep the good sellers in my list.
                            • gustagen
                              • May 2011
                              • 86
                              I purchased mine from eBay seller 'luckyelectronic'.
                              https://www.ebay.com/itm/Replacement...E/222996774308
                                Thanks!
                                • justice171
                                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                  by justice171
                                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                  1. Verified that all critical voltages are present:
                                    • 3.3V and 5V are always present if DC is plugged.
                                    • 1.8V on the BIOS chip is present.
                                  2. Checked the power button functionality:
                                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                    • Confirmed connectivity is intact, ruling out issues
                                  11-26-2024, 12:39 AM
                                • boyseth
                                  Troubleshooting guide for Macbook m2 A2681 - No power issue
                                  by boyseth
                                  hello mates,, need help im a new tech here.. any tips or idea on important testpoint in repairing a no power Macbook m2 A2681? Thank you in advance..
                                  08-14-2025, 01:28 AM
                                • rounin
                                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                  by rounin
                                  Hi everyone,
                                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                  🛠 Original Issue
                                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                  Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
                                  I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
                                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                  04-19-2025, 01:18 AM
                                • ugamazing
                                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                  by ugamazing
                                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                  12-17-2024, 07:05 PM
                                • shahnld
                                  Lenovo legion 5 pro startup issue
                                  by shahnld
                                  Good day Experts
                                  I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                  A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                  And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                  Yesterday, 12:31 PM
