samsung LE40B551A6W black screen with sound
  • andrewblueboy
    • Feb 2017
    • 47
    • uk
    hi all
    i have a samsung LE40B551A6W black screen with sound, when i got it i new a bulb needed changing, (my mistake took bulb holder off and broke tube) then tested all bulbs and all worked fine. now ive put it all together.
    so now this is how i got the tv no picture but with sound. iive taken the in power inverter board off and checkedthe transformers and come a cross a difference in the readings.
    heres a pic to explain
    the one on the right has different readings, could this be the cause or is it normal as this one has a different letter with black edgeing tape
    any infor appricated
    thankyou
  • R_J
    • Jun 2012
    • 9535
    Re: samsung LE40B551A6W black screen with sound
    That transformer on the right is different as it only has to drive 2 lamps, the others each drive 4 lamps. both secodaries on that check the same so it is likely ok.
    Do you at least get a quick flash of the backlights when first turned on?
    If you disconnect the plug going to the main board do the backlights come on?
    On the first 3 transformers primaries you show OL, that is not right, it should be low around 1 Ω or less
    Also on the first 3 transformers the two secondaries are not connected together, on the third one they do connect the secondaries together at the 2 center pins. this is normal
    Another item to check is CI817 (square white cap) If it looks slightly bulged it is bad
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I am not sure but I think the transformers should carry the same numbers and the odd numbered one seems to be bad one. Wait on others to chime in before deciding.
      • R_J
        • Jun 2012
        • 9535
        You may want to check the connections on the circuit side of the board, all the transformer primaries should be connected in parallel, so if TI804 measures 1395, that is wrong, it should be very low, like a short.
        • andrewblueboy
          • Feb 2017
          • 47
          • uk
          the meter i use is a fluke 113 so i used the ohms as auto, i shall try the manual range and see if it measures 1 or less.
          i shall try in the morning and see how i get on
          thanks for your input
          • andrewblueboy
            • Feb 2017
            • 47
            • uk
            ive the measurement in the different range and the only one that seems diff is the one on the right on pic its 0.2 as it jumps from 0.2 to 0.1 and
            CI187 0.435 v one way and OL differenr direction.
            in ohms its 3265 one way OL different location and not swollen
            • andrewblueboy
              • Feb 2017
              • 47
              • uk
              hi all
              ive taken readings with tv on and standby hopefully it will help out as to how the tv is at the momment. when on tv blank but you can see the snow effect on tv channel with a torch. so for some reason the back light is going off after 2 seconds
              • R_J
                • Jun 2012
                • 9535
                If the backlights come on for 2 seconds, I suspect the inverter board is ok, and there is a bad ccfl lamp in the panel.
                The backlight will shut off if it sees an error on one of the ccfl's ie: it did'nt light. It could be hard to isolate as you can't just disconnect a single lamp output and it can be hard to see if all the lamps light for 2 sec without opening the panel.
                as for CI187, it must be ok if you get the 2 sec.of backlight, also it can't be checked with a multimeter unless it has a capacitor test function.
                • R_J
                  • Jun 2012
                  • 9535
                  I was just over at another repair shop and noticed the same board sitting around, he said he had 3 tv's and all had bad ccfl's and the boards were all good, so it is a good bet a ccfl is bad in your tv.
                  • andrewblueboy
                    • Feb 2017
                    • 47
                    • uk
                    thankyou for comments about the ccfl, looks light this will be the next job taking it apart again and test those bulbs.
                    • andrewblueboy
                      • Feb 2017
                      • 47
                      • uk
                      right this time i used my light tester and all re working but yet the tv stays on, no green light or anything just has if the tv was off . with torch still snow haze and with sound. im now stuck on this now never seem to get any further.
                      • R_J
                        • Jun 2012
                        • 9535
                        How are you testing the ccfl tubes? check the lamp contacts, they sometimes go bad
                        • andrewblueboy
                          • Feb 2017
                          • 47
                          • uk
                          just switched the main board with another and still the same problem
                          • andrewblueboy
                            • Feb 2017
                            • 47
                            • uk
                            hi
                            i have a ccfl tube tester i took inverter boar off and place neg on back panel and postive in the slot that the invertor board slides into and i can see the tube light up thro the holes in back panel
                            when i first got tv had i had tv stripped down and tested them on both ends and they were fine.
                            now they come on 2 secounds give a little buzz then off
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Where did you get the replacement tube from. Perhaps it's not to the same specification as the ones you already have in the set and may be causing an error signal.
                              On the prmary side of each CCFL transformers, have you checked (using you meter set to ohms) that pin1 of each of the transformers are connect together and also all the pin 2's are all connect together. As suggested by RJ in post #4
                              When you power up what voltage do you have at DET_5V?. If it's low then there is an error.
                              What voltage do you have at the Inverter On/OFF pin when you power up?
                              • andrewblueboy
                                • Feb 2017
                                • 47
                                • uk
                                the tube was from ebay same model of tv. i shall be dismantling the tv again tomorrow checking bulbs and connectors incase anything loose causing a short.
                                if i take front off down to the tubes can i attach power invertor board and power up. would this be safe to see what happens or is this a NO leaving the tubes exposed
                                thankyou for your input and also to others who have given me advice on this tv
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  You can do all the checks mentioned before stripping down the set.
                                  Also worth viewing the following youtube video
                                  • andrewblueboy
                                    • Feb 2017
                                    • 47
                                    • uk
                                    the inverter on /off as far as i can rember no reading as that why i left it blank on my picture i added
                                    the 5v det when on showed OL, think im going after recheck these readings
                                    you mentioned the primary pin 1 and 2 primary , im not sure how you mean with this .
                                    still a huge learning curve this for me and very greatfull with the infor. im determind to get this working even tho its a challange
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      It's the dc voltages at the pin 23 & 25 being asked for. With the black lead on the chassis and red meter lead on Pin 23 (Inverter On/Off), power on the set and give the voltage the meter reads. Repeat for pin 25 (Det_5V)
                                      With the set off and using your meter set to ohms do all the "A" connect together and all the "B"
                                        Most CCFL tester does not have detection/.protection circuit to detect lamp over current draw, bad worn out lamp (which draw more current than normal) will still light up with tester so keep that in mind.
                                        Det_5V is normally HIGH (it is active low, LOW = PROBLEM in backlights circuit).
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • totof
                                          LG 43UF640V backlight good but black screen and no sound
                                          by totof
                                          Good morning.
                                          I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                          I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                          In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                          HVDD : 7,28...
                                          04-13-2024, 11:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
