samsung LE40B551A6W black screen with sound
  • andrewblueboy
    • Feb 2017
    • 47
    • uk
    Re: samsung LE40B551A6W black screen with sound
    ok pin 23 4.107 ON
    0000 OFF
    pin 25 EPWN 0.786 OFF
    OL ON
    pin 27 5v 0.707 OFF
    OL ON
    • andrewblueboy
      • Feb 2017
      • 47
      • uk
      Originally posted by dick_barton
      It's the dc voltages at the pin 23 & 25 being asked for. With the black lead on the chassis and red meter lead on Pin 23 (Inverter On/Off), power on the set and give the voltage the meter reads. Repeat for pin 25 (Det_5V)
      With the set off and using your meter set to ohms do all the "A" connect together and all the "B"
      you say measure in ohms A connecto together and B together.
      ive seen the A and B ost you have put on pic do you want the measure beteen the two post on each of the transfmores with tv off . have got this right
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Pin 23 Inverter On/ Off 4.17V, so the inverter is switched on
        Pin 25 Det_5V = 5V, There is an inverter or lamp error. I would think a lamp error.
        Resistance (ohms) is always measured with the power off.
        • andrewblueboy
          • Feb 2017
          • 47
          • uk
          the A post 0.2 then drop to 0.1
          B post 0.2 then drop to 0.1 aswell
          ive had the tv apart again bulbs seem ok
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Can you explain the comment "bulbs seem oK"
            • andrewblueboy
              • Feb 2017
              • 47
              • uk
              #26
              I have a lcd bulb tester which I connect to both sides or the bulb to light up . I use it to test laptop screen working aswell
              Or is there a away I should be using a muti meter to test
              Thankyou
              • nomoresonys
                • 12331
                • U.S.
                #27
                Bud said "Det_5V is normally HIGH (it is active low, LOW = PROBLEM in backlights circuit)." So does 5v on pin 25 mean inv. or lamp error or does low equal problem? low is less than 5v correct?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Have you soldered all the pins of each of the transformer as suggested in an earlier post.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    If the BD9893 drive IC stops either due to being faulty, or an error being returned from the Inverter circuit via OVP then it disables the inverter IC.
                    When the IC stops then DET_5V error occurs and is pulled low ie 0V
                    The video pointed to in an earlier thread showed a way to overcome the protection to check if there were any tubes failing to light.
                    • andrewblueboy
                      • Feb 2017
                      • 47
                      • uk
                      #30
                      Yes heated up pins and added it bit of fresh solder. It's becoming a bit of a task trying to sort it. I'm pleased I'm getting advice on this
                      • andrewblueboy
                        • Feb 2017
                        • 47
                        • uk
                        #31
                        The video pointed to in an earlier thread showed a way to overcome the protection.
                        This video of the protection would it be worth me trying this and see what happens or could I be asking for more trouble as I'm only a learner at this
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          There's no reason why you should be asking for trouble. The component he lifted is a small surface mount 0 ohm resistor (used as a link) so you need to be careful not to lose it, reference JR860
                          If the tubes do not light up then the problem is elsewhere.
                          Watch the video and take your time and don't rush it.
                          • nomoresonys
                            • 12331
                            • U.S.
                            #33
                            Can also check youtube, there's some good videos on transformer testing.
                            • andrewblueboy
                              • Feb 2017
                              • 47
                              • uk
                              #34
                              hi there well progress so far. ive gone over my solder joints on the transformer again and also lifeted the JR860. now the tv is ON. no dark areas as if a tube is out, so what do it do now then do i leave it or reconnect the JR860
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                It's not advisable to run anything with the protection circuits disconnected otherwise there would be no need for them.
                                Can you post a nice sharp and well focused picture of the underside of the board so that the component references can be read.
                                • andrewblueboy
                                  • Feb 2017
                                  • 47
                                  • uk
                                  #36
                                  here are some
                                  • andrewblueboy
                                    • Feb 2017
                                    • 47
                                    • uk
                                    #37
                                    here some more
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      Can you replace the jumper JR860.
                                      I can't think of a simple way to isolate the fault other than knowing that there is an error being generated by the lamp circuitry.
                                      If you feel confident then there are a number of diodes DI8106 to DI812.
                                      Can you carefully lift pin 3 of DI806 and switch on. Do the backlights stay on?
                                      If not reconnect pin 3 and move on to DI807 and switch on. Do they stay on.
                                      If not reconnect pin 3 and move to the next diode..
                                      Repeat until the backlights stay on and report the diode number.
                                      If anyone else can think of an easier way then I'd like to hear.
                                      • Mgiffune
                                        by Mgiffune
                                        06-09-2024, 10:28 AM
                                      • Audeze
                                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                        by Audeze
                                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                        Does...
                                        10-06-2024, 08:54 PM
                                      • HTR-Informatique
                                        Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                        by HTR-Informatique
                                        YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                        I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                        On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                        I also changed the screen because the PC fell and the screen was broken.
                                        I changed the battery with a new and original battery.
                                        I also had corrosion/oxidation on the...
                                        02-09-2025, 06:51 AM
                                      • totof
                                        LG 43UF640V backlight good but black screen and no sound
                                        by totof
                                        Good morning.
                                        I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                                        I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                                        In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                                        HVDD : 7,28...
                                        04-13-2024, 11:37 PM
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
