Having a problem with this power supply I think I have narrowed it down to the transformer. When I connect just the primary side it blows the fuse. Removed its ok. Cant find any info on this Chinese Transformer. Is there any chance on repairing this power supply without a schematic or OEM parts?
Magnavox DRV power supply SMPS
Re: Magnavox DRV power supply SMPS
Are you sure that the transformer is the main cause..?
if it's true, this is mean disaster.
Because the hardest part to find the replacement is the transformer, except you pull out from the identical board.
Have you already check all component in primary side..?
Try with light bulb trick. not directly from the wall. -
This is really a puzzler. All of the caps are ok including the polys. Diodes are fine including ones on bottom. The mosfet was bad and I replaced it. I checked the small to92 transistor on the primary side (I assume that controls the mosfet ) and its ok. Xfrm out its ok, primary side connected only it blows. There are 5 connections on the primary xfmr. 2 are connected and the other 3 are. So I was going to put a scope on those connections. I am guessing the signal would be a pseudo AC because its already rectified. Any thoughts?Attached Filesif you find these attachements useful please consider making a small donation to the site
If the power MOSFET that drives the primary winding is stuck fully on instead of switching and off 50~60,000 times a second, that will cause the fuse to blow.
Are you sure that the new MOSFET is not shorted out again?
This is one of those Philips two-Transistor switching power supply, so you have to check ALL the devices in both primary and secondary side really well.
What is the model number of this DVR unit?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
Its a Magnavox mdr557h/F7. Its not that old. Do I have to unsolder the mosfet to really check it correctly. I used a mosfet machine to check it originally but I don't really want to remove it. So what could be taking out the mosfet if its bad. There really are not that many parts on top of the board. There are a bunch of micro components on the bottom that I have not checked. A schematic would be golden.Comment
Transformer winding will show very low DC resistance, you need a transformer ringer tester to test it.Never stop learning
Yup, you cannot test smps transformer with traditional multimeter (analog or digital)
In many design, it's shows continuity. Seems shorted, but it's not.
Like budm said, you need ring tester to check it.Attached Filesif you find these attachements useful please consider making a small donation to the site
Nope, the circuit use one of the transformer winding to create the positive feeding so the circuit will oscillate.
Same topology as used in this circuit. PDF.Attached Filesif you find these attachements useful please consider making a small donation to the site
Replace the fuse with a light bulb. It will limit the current, letting you run tests.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Can anyone tell me exactly what type of tests I can run while current limited? Without a schematic its like making love in a canoe. I also have a variac which I could use in conjunction with the bulb. Wish there was a SMPS step by step diagnostic chart.Comment
Try this schematic, it looks like the same power supply. If the original fet had a short from drain to gate I suspect parts in the drive circuit are damaged.Attached Filesif you find these attachements useful please consider making a small donation to the site
Assuming...7 Photos -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
Channel: Troubleshooting Audio Equipment
by sam_sam_samI have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
Dose anymore known if there is such a module and where would I find some
While searching this topic on google I found this
https://www.badcaps.net/forum/troubl...anything/page3
I have read through this I have some switching... - Loading...
- No more items.
