TL494 PWM Controller Module Booard to control a SMPS switching power supply are they available for this purpose
    • Jul 2011
    • 6046
    I have seen some board on eBay and Aliexpress but I have not seen any for SMPS switching power board modules I would like to build one if I can not find one that is already made
    Dose anymore known if there is such a module and where would I find some
    While searching this topic on google I found this
    https://www.badcaps.net/forum/troubl...anything/page3
    I have read through this I have some switching power supplies that use the TL494 that if I can not find a readymade circuit board module then I going to breadboard one because I have several switching power supplies that have different voltage outputs i going to see what is different between each one plus look at application notes for this ic chip
    or dissection of a TL949 ic and its supporting components and make a board this way however this is my last choice
    • Jul 2011
    • 6046
    Here is a good explanation of the use of a TL4949 based smps switching power supply
    https://www.youtube.com/watch?v=y3KQmKr5ii4&t=0s
      • Jul 2011
      • 6046
      I going to do some very in-depth research on this topic and see what I come up with
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Don't know if this helps, but here is TI's paper on the TL494, https://www.ti.com/lit/an/slva001e/slva001e.pdf .
        PeteS in CA
          • Jul 2011
          • 6046
          Thank you for sharing this I had seen it earlier today while researching the topic
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • dkneyle
            LG VCR-DVD RC689D SMPS Switching IC identification
            by dkneyle
            After sitting in Standby mode for years(?) the owner decided to power up and play a CD. At which point the magic smoke emerged and it died.
            Upon opening I can immediately see the main charge capacitor has dropped its guts (literally). The switching IC is completely physically destroyed so I can't read any type number. I should be able to work my way through the other components; I can usually get a SMPS going. (I can see at least one bulging electro; they'll all get replaced.) But I'm hoping someone might be able to suggest the most likely six-legged IC that would be used?
            11-14-2021, 01:17 AM
            After all of...
            07-13-2024, 08:14 PM
          • dkneyle
            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
            by dkneyle
            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
            02-01-2022, 02:08 AM
