Philips HTL2160 soundbar NO power problem
  • DjKrish
    • Oct 2012
    • 354
    • SG
    This soundbar has a blown AC/DC Offline Switcher IC which is top257en. I replaced it, power restored, can on the unit and sound works fine. After a while, turn it off, and turn it back on again by pressing the power button, the IC blows again Replaced it again, it blows again after playing with the power button ON and OFF a few times. If the power board is not connected with the main board, its not blowing. It only blows when in operational mode. I suspect it could be the ceramic caps and possibly the electrolytic caps as well. Any suggestions? 19V present (according to service manual) on the output pin that's connection to the main board which states 18V. I believe the AC side is working fine as the fuse is not blowing. Its definitely something to do on the DC side thats blowing the IC.
    Already tested all the diodes, all in good order
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Phillips soundbar NO power problem
    On both the Top and Bottom sides, test all the semi-conductors . Test the e-caps ESR and capacitance and NP caps capacitance. Test the resistors for open or high resistance ohms. Do not take for granted nothing is wrong on the ac side. Test all the components on the ac side as well. Report your findings.
      • 31305
      my distant past involved a lot or repairs with topswitches,
      99% of them died because a small electrolytic capacitor had dried up.
      • DjKrish
        • Oct 2012
        • 354
        • SG
        I will pop out all the electro caps and check them all
        • DjKrish
          • Oct 2012
          • 354
          • SG
          Ok will test all the components tonight and revert back.
          • DjKrish
            • Oct 2012
            • 354
            • SG
            https://www.youtube.com/watch?v=whF0jGZeNHs
            Changed the TOP IC, changed 2 ceramic caps thats connected to the IC. Tested all electro caps and they are fine. Right now if power up as standalone, the power supply is fine but im afraid to hook it up to the main board afraid of blowing up the last TOP i have See the video, the voltage is not constant, it moves up and down
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              That's where I put my money too, or a cold solder / improper solder joint somewhere.
                Check the snubber cap C531 and the snubber diode right next to the C531 to make sure they are OK.
                  • 31305
                  how did you test the caps?
                    master hoarder
                    • May 2008
                    • 12176
                    • Bulgaria
                    Test with an incandescent bulb in series with the line - that way, if something goes too out of whack, the TOPswitch shouldn't blow up. Details how to wire the incandescent bulb here:
                    https://www.badcaps.net/forum/showpo...4&postcount=70
                    • DjKrish
                      • Oct 2012
                      • 354
                      • SG
                      With a cap meter
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        Already replaced C531 and C536. The diode is fine no short.
                        • DjKrish
                          • Oct 2012
                          • 354
                          • SG
                          Will try this and update here later
                            It looks like you have blown snubber resistor R565.
                            That snubber cap C531 should be rated at 1KV, you have 400V rating on that replacement cap.
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              The original snubber cap is rated as 2200 J 400. What you see in the picture is actually original according to Phillips schematic diagram
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8352
                                good eyes budm
                                  Well, they are not following the IC manufacturer advice.
                                  the schematic shows two 22 Ohms resistors in parallel so one is not going to handle it, your board only has one, cutting corner to save money on parts. The snubber diode is rated at 1000V too.
                                  • DjKrish
                                    • Oct 2012
                                    • 354
                                    • SG
                                    So i should change the Cap and add one more 22 Ohms? Should that be ok?
                                    Update: After replacing the burned resistor, the main cap is discharging pretty quick upon switching off. Before this nah, wasn't discharging at all. The voltage seems stable as well. The schematic says 19V, the board says 18V. Weird.
                                    2nd update : Fixed everything and installed the full unit. So far nothing exploded yet as its working fine, fingers crossed
                                      I would change the cap to 1000V, the 22 Ohms should be higher Wattage otherwise it will probably burn up again. That snubber circuit is design for reducing the Ringing/Overshoot based on the circuit as a whole, so the only way to find out is to use the scope and a differential probe to analyzing what is going on.
                                      • jazzie366
                                        • May 2016
                                        • 304
                                        Are those caps on the board branded, "ZHN"? They look to be questionable.
                                        Also, I've seen all the other replies, but just because of the branding im concerned.
                                        Popcorn.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • _AcE_
                                          JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                          by _AcE_
                                          I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                          There's no physical damage...
                                          08-10-2025, 09:27 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
