Samsung curved UE55H8005 no picture
  • PowerAmpFreak
    • 982
    • Sweden
    I got this curved Samsung LED model UE55H8005 which does not show a picture, sound and functions OK.
    Upon start-up, backlight turns on for one second (but no picture shows)
    Some tests done:
    Disconnecting T-CON either flatcable or connection between T-CON and PSU, the backlight will be on continously.
    Obviously something on T-CON doesn't want the backlight on.
    BL-ON signal is high whenever set is turned on, but PWM1-3 goes to zero and backlight turns off as a result.
    Blue control leds on T-CON is on.
    Question is: Is this a bad T-CON ?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung curved UE55H8005 no picture
    Backlights issue I suspect.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      pwm 1-3 i wonder if thats the dimming control budm was posting in a thread last night regarding this
        They are PWM dimming controls, it has three control lines for Zone dimming based on the scene of the image..
        There is small connector on the T-CON board which I cannot clearly see, that connector may be used to control the zone dimming. Need closed up pictures of the T-CON (shopjimmy does not seem to have anything on this TV model).
        http://www.samsung.com/uk/consumer/t...UE55H8000STXXU
        "Samsung's latest Micro Dimming Ultimate technology gets the most from your TV and shows your entertainment at its best. The advanced dimming process enhances the contrast as well as the colour and detail. This means you see deeper black and purer white shades, as well as a clearer and more vivid picture than ever. It pushes your TV to the limit to deliver the ultimate in picture enhancement and optimisation"
        So more circuits for more chance of breaking.
        • Diah
          • Feb 2013
          • 6565
          +1 2014 TV with 90-100 % backlight degree will never survive till now
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Guys read ! "Backlight stays on when mb is disconnected, something on tcon doesn't want bl on" so tcon has fault.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Haha Reece i was thinking the same!
              Curved tv and already dead. Unbelievable to be honest. Worst thing is that it's just a led tv with a lcd screen thats bend. Remove it and its just a lcd screen haha. Just a marketing trick , blegh.
              • Diah
                • Feb 2013
                • 6565
                both of you wrong... read blue indicator on on T-CON , T-CON concocted to the same dimming circuit on PWB. backlight level 1 at start up (Logo) all on (in this case not all line turn on ) step 2 signal sync ( LED give error = T-CON OFF indicator ON..
                • Diah
                  • Feb 2013
                  • 6565
                  in General after end 2014 begin 2015 new policy issued for LED Indicator on PWB and T-CON to mark issue when LED back light in use. just for your info.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Hmm interesting, wait and see what OP finds
                    • Diah
                      • Feb 2013
                      • 6565
                      haha. did the OP have courage to take curve out of set !! Samy neither do this .. its suck point to buy new one so the thought before,,, disposable TV for 3 years
                      • petehall347
                        • Jan 2015
                        • 4449
                        • United Kingdom
                        i would take it back and say not fit for purpose ..
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Lol ikr 3 years is just sad designed to fail
                          • Diah
                            • Feb 2013
                            • 6565
                            how long you would like to extended lol if user had backlight as it shipped to be 90% x 5 hours day ... or more... did you forget yours dad TV samy !! was ... you mentioned here before how much hours was on. after you repair it and looked to service mode.. LOL
                              What is the power supply P/N? BN44-?????
                              LCD panel P/N????
                              Also need good clear and focused pictures of the power supply board and the T-CON board.
                                Some tests done:
                                The LED driver circuit has its own local protection circuit to detect Over Voltage due to open LED circuit, over current if LEDs or output draws too much. So if the LEDs have problem, or bad wiring for the LEDs then the LED will not stay on when running the self test. The LED driver also generates the ERROR signal if there is problem in the LED circuit and sends that to the main board.
                                • Diah
                                  • Feb 2013
                                  • 6565
                                  just to look from the TV back hole to see there backlight never mean they are all fine. we remember at Toshiba 3D HD TV backlight one group get off. then all off, and when we plug out the 24V from PWB to LED driver board. the back light shining.. but still there are one group off.
                                  • PowerAmpFreak
                                    • 982
                                    • Sweden
                                    Hi guys, not much to tell at this point. But, mainboard send LVDS and PWM dimming info to T-CON and from a small connector on T-CON to PSU to control backlight dimming.
                                    If I disconnect this small connector, the backlight will be all on but still no picture whatsoever. It can either mean the mainboard doesn't send any picture data to T-CON or that T-CON is faulty.
                                    I would like to know if this T-CON can be put into testmode? (pattern generation or similair) then I could judge if the mainboard needs replacement or not.
                                    Set lost picture during operation, sound and functions all OK
                                      See post 15?
                                      I need to be able to read the pin labels of the connector of the power supply board that goes to the main board and also to the T-CON small connector so I can see what the wires from the T-CON to the power supply board are..
                                      • PowerAmpFreak
                                        • 982
                                        • Sweden
                                        Yes, budm, here's close up pics on both tcon and PSU.
                                        I turned it on again right now and fuse on tcon went and bad smell of nearby IC, so I think this case will be solved by changing tcon.
                                        PSU is BN44-00727A
                                        T-CON is BN95-01311A
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • shelby5041
                                          Samsung LCD TV no picture backlight on no 12v at tcon
                                          by shelby5041
                                          hi
                                          i have a samsung lcd tv
                                          it powers on with sound and backlight but no picture
                                          all voltages from PS are good 12v 3.3v and 5v
                                          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                                          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                                          no 12v at the tcon fuse
                                          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                                          the odds of having 2...
                                          10-08-2021, 08:21 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
