Rookie mistake - I know.. I'm hoping one of you Gurus can help me out.. I was working on the SC board (TNPA5335 SC) of a Panasonic TC-P50GT30, and the soldering iron slipped and I accidentally knocked 2 small resistors off the board.. I found one, but I can't find the other one. I would be grateful if some one can tell me the value of Resistors R588??? or just read off the numbers?
Panasonic TC-P50GT30 - Resistor Value on SC board
Re: Panasonic TC-P50GT30 - Resistor Value on SC board
Thank you so much tw2005. I couldn't find the service manual / schematic for that board. I was replacing the Transistors above that area and one was stubborn and I pushed it with the soldering iron a bit too much and knocked off these resistors.. Thank you again
Originally posted by jason123 View PostThank you so much tw2005. I couldn't find the service manual / schematic for that board. I was replacing the Transistors above that area and one was stubborn and I pushed it with the soldering iron a bit too much and knocked off these resistors.. Thank you again
yeah, I'd avoid force;. Will end in tears when you start destroying tracks.
not sure what you're using but I get away with a 40W iron, medium chisel, I cut the legs and flow fresh solder onto the tab and let the heat soak. it'll start bubbling on the sides and when molten it'll come off quick.
If you got hot air that could assist in heating the area as the tabs soldered to the board act as heatsinks so patience. Once the board gets hot around that area the other two are generally easier.Last edited by tw2005; 10-15-2016, 07:29 PM.
