17IPS20 No Led Voltage Solved With Video :)
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hi all I know theres alot of issues with these supplies and no backlight, today the symptoms of the issue with this one were the following:
    No backlight
    0v on Led output
    Q502 and D504-Led output boost devices not shorted
    0v on D303-D314 which are 6 diodes in parallel for Led output meaning Q301 transistor for Led output is not turning on enough or at all
    Found only 330v across main caps meaning Pfc mosfet Q100 not turning on
    Pfc controller U101 starts then shuts down Vcc drive voltage meaning issue is in the primary side
    Things to check:
    Q301 for S/C
    Q101 for S/C note both these can blow and if their resistors fail open quick enough the mains fuse will not blow and Psu likely will start with no backlight
    D506 for leakage current, this diode does not normally fail S/C but leaky acorss the cathode to anode so check that
    What I found:
    U300 check if its sending Vcc now I found it did but then shut down too meaning issue with either U101 or U300 or related parts
    Checked U101 found low resistance across pins 1 and 3
    Checked C127 (near U101) 50 ohms across it meaning theres a short acorss that cap, removed and checked however cap is fine out of circuit
    Then checked C525 (under Q301) which is in parallel with C127 and both U101 and U300
    C525 had lower resistance across it
    Removed C525 and its shorted
    Checked controllers again and low resistance gone
    Replaced C525 which I believe is a 1uf 50v multilayer ceramic cap-MLCC stole one off a scrap IPS20 which is not worth fixing and replaced resistance still good
    Put the Psu back into the Tv and the set now works. Hopefully help someone out, remember to check that cap if your Led section is totally dead with no output
    Video coming tomorrow or Tuesday.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17IPS20 No Led Voltage Solved With Video
    I also forgot too add, the motherboard (17MB95) was also totally dead the standby Led would flash then die flash then die, swapping the Mb for a similar one sorted the issue. So I wonder if the Psu cap shorted killed the Mb at the same time ? Or the set got hit by a surge ?
    • comptek
      • Aug 2013
      • 606
      • uk
      another great fix
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Cheers buddy, got that board yet as well ? Also yes saved me £ again
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Link to video chaps, hopefully help someone:
          https://m.youtube.com/watch?v=uPI1QBE0CxI
          • diif
            • Feb 2014
            • 6978
            • England
            Nice work as always mate.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Cheers matey, keep these Vestels out the land fill
              • diif
                • Feb 2014
                • 6978
                • England
                Yep, working on a 17PW20 at present.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Cool cool, whats the issue mate ?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    TV powers on for a second giving the blue screen before going back to standby.
                    I disconnect the inverter and the TV stays on. No shorts on the inverter or the spare I have, the two poly caps have been changed and other electrolytics checked.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Hmm seems like the Pfc is low to me, this can cause 24v shut down which crashes the set. Whats the pfc running at ?
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        That is pretty informative and i am sure will come in handy to newbies. Thank you!
                        A working TV? How boring!
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Cheers mate
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Just to add an addition comment when repairing this power supply.
                            Thanks to ReeceyBurger123's video on this supply I found C525 (10uf 50V) was faulty and reading 90 ohms out of circuit.
                            The minimum working voltage for U101 (FAN7529 is 14.5V) and VCC on the chip measured only 10.5V so was still to low.
                            On checking through the circuit I finally found a collector - base short circuit on Q216 (BC327).
                            Replaced and PFC voltage now up and running.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Nice work matey, as I said before that device can fail too. Unser what causes these just random issues on Vestels though just crappy designs I guess.
                              • Wroxall Tony
                                • Sep 2016
                                • 5
                                Hello guys, this is my first post so please don't be cross if I'm asking this in the wrong place or the wrong way! I'm stuck with a duff 17IPS20 for a Hitachi 42HXT12U, with a board no. 23145840. I can't find a replacement board, but there are plenty of 23145828 available for this model TV. Does anyone know if this will work as a replacement for 23145840, please?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Welcome, also what is the issue with your board for a start ? Also you can use any IPS20 that works for a 42" size screen dont bother watching all the number BS up dont let it confuse you. Got an image of the board yours uses and I will find one as the only thing different they do for the 42" sets is sometimes use a different Led connector ?
                                  • Wroxall Tony
                                    • Sep 2016
                                    • 5
                                    Thanks for such a quick reply. There's zero voltage on the output to the LEDs, and rather than spend ages trying to identify the failed component I thought I'd just slap in a new board. I've looked at images of the 23145828 board and it looks identical to mine, so with your very helpful advice I'll go for that. I can always change the LED connector. If it doesn't work it's only a few quid and worth it for the experience! Thanks again!
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Have you watched my video ? Might be as simple as that also no problem keep us updated.
                                      • Wroxall Tony
                                        • Sep 2016
                                        • 5
                                        Well, progress (sort of!). The new 17IPS20 board behaves exactly like the original - no LED output. So not an instant fix. However, probing deeper, I have the following symptoms (on either board):
                                        1. Pd between + LED output and ground: settles to about 115V (after an initial 190V or so)
                                        2. Pd between - LED output and ground: about 5 V (measured at the same time with a second meter)
                                        3. but pd between + and - LED output is close to 0 V! Is this strange result due to the circuit detecting the impedance of the meter across the output terminals? Results are the same whether or not the LEDs are connected to the output.
                                        4. Meter shows an "infinite" resistance across the LEDs when detached from the supply board (meter connected either way round) - but surely a load of LEDs should offer a measurable resistance? Diode setting on meter gives the same result.
                                        5. On switchon the screen briefly (less than 1 second) shows the "Hitachi" logo, so the LEDs can't be completely dead I guess.
                                        so.... should I be pursuing a dead string of LEDs, and dismantle the screen completely to get at them, or worry some more about the power supply to them? I have watched your videos, and checked easy things like diodes but this is my first venture into flat-screen TV repair so I'm starting from base camp! Thanks....
