I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
10-character number and 4-characters string on USB Standard-A, "male" plug? Meaning and usage?
Assuming...7 Photos -
by sikocanI believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
SN: PF3G1REP
MODEL: 20KW-00J1AU
PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
Channel: BIOS Requests ONLY!
by DevonavarI have a Vizio M43-C1 stuck in a reboot loop with no backlight.
I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
So, I've ruled out the PSU for now.
The reboot loop... -
by sew333Hello. I will be buying new apartment to live. But fuse box is older. Not the newest.
And my question. It will be fine to plug pc in this new apartment with that fuse box,i think it is aluminium,right?
PC WILL BE: Rtx 4090,14900K,1600W PSU
It looks like this ( screen from internet ). Looks like this,not sure i dont take a pic from there. Can i plug pc with that one?
screen of this:
room:
Someone said this to me.
1
"I would get advice from a local electrician... -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
- Loading...
