Could this be a bios issue? i took the bios out, try to read it and it says its BLANK, therefore my suspicion. x551ca rev 2.2. this is the bios i got from the website but its in .211 format and its too large when i try to use it
does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then nothing
Re: does anyone has X551CA Bios dump ? laptop power gets to the first mosfet then not
Could be, from another forum:
You might need to inject form old dump sn,mac,win key
from address 21048d to 2330ff to this one.Attached Filesif you find these attachements useful please consider making a small donation to the site
first two mosfets are driven by charging ic.Comment
Thank you soo much my friends but you lost me at "You might need to inject form old dump sn,mac,win key
from address 21048d to 2330ff to this one". AS MY OLD CHIP SAYS IS BLANK.
Would this work if i use it just the way you sent it?Comment
Yes it should work without these numbers, but you might have windows license problems, network card problems...
If old chip was all blank, then you have nothing to copy from there.Comment
Im using CH341A programmer but it wont let me use this type of file, it says supported files are .Bin and .HEXComment
Hi
Yes fixable the only way is get a donor bios and rebuild the me region ...if you just use a donor fans will be full speed or reboots all caused by me region once a intel computer boots it's married to that computer ....not the case for amd plateform .
i could do it when i'm not so busy
techman1025Comment
hi here is a new file if laptop boots then i will rebuild me region and you will be set to go.
Techman1025Attached Filesif you find these attachements useful please consider making a small donation to the site
thanks a million techman2015..im going to try it out and ill keep you updated.Comment
Bad bios chip?
Bad contact with chip?
Bad programmer?
I am not familiar with this programmer software - does the chip get id-d correctly?
I have used many times dumps from donors without rebuilding the image.Comment
this chip is a Windbond 25Q64FVS1G but the software detects a 25Q64BV, this might be the reason why. Couldnt find it manually either.
Would you recommend a good software that is compatible with this programmer?Comment
my friend , if voltage is not passing true first mosfet , then lift second mosfet , and inject 19 volts again and chek if you now got voltage on the outher side of the mosfet .. and also if gate voltage is correct . if so replace the mosfet you lifted and simply is fine to turn on .. alltough and one member sayed , first mosfet are controler by charger IC ,, so i believe you got a bad FET or could have something wrong with charger icComment
alltough if you reading a dump that is empty could be causes due to incompatibility with your rom flasher (time to times you have to install new firmware for you hardware (it will also add new chips to the system read) i had problems with a few samsungs , bad reading etc etc , after firmware update , all good now
but in any case if you bios is dead Techman is a great HEXA guy he will fix you this for sure .Comment
Thankx a bunch guys. I found two other boards with the 25Q64 bios chip, but i dont know if they are compatible. i got a 25Q64FWS1G from a Toshiba C55 and a 25Q64FVS1 from a dv6-7000.Last edited by Blacktek; 08-18-2015, 11:04 AM.Comment
Can i use a different software for my hardware? If so which one, im using the CH341A programmer but it doesnt really work for all 24x,25x chips.alltough if you reading a dump that is empty could be causes due to incompatibility with your rom flasher (time to times you have to install new firmware for you hardware (it will also add new chips to the system read) i had problems with a few samsungs , bad reading etc etc , after firmware update , all good now
by AhariHi all,
I...-
Channel: BIOS & Schematic Requests!
by mkdjDear all,
I have a ASUS ZenBook UX480F with the following symptoms:
I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
Troubleshooting Attempts:
Channel: Troubleshooting Computer Displays
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
The charging red LED lights up, but the charging screen doesn't show any indication.
When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
(I've tried removing the battery and resetting the device, but the issue persists.)
NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
S/N : 5RNK9FFT70...-
- Loading...
- No more items.
