VIZIO e701i-a3 LFTRNXAP1002583 No video No sound , Just Backlights
  • maiden790
    • Nov 2014
    • 94
    Hey guys I was poking around the forum for an answer and still dont have a clear answer as to what could be the cause the video and audio not to work on this Vizio Model # e701i-a3. Serial # LFTRNXAP1002583
    My suspicions are either Main Board or T-CON .
    What I've done so far...
    Tested the power supply for power with meter and seems to be in good working condition.
    No signs of bad Fuses
    No signs of bad caps.
    No signs of bad Diodes.
    Tested each HDMI port on the Main Board for audio/video and nothing.
    Unplugged one ribbon from each side of the T-con at a time and no change was seen.
    Disconnected the ribbons going to the power buttons and to the IR sensor one at a time and vice versa and no change
    I dont think the T-con would be responsible because I know the T-con isnt responsible for audio issues.
    I've heard about the recall with the 70" Vizio's however the one I have doesn't fall under the ones recalled, however its almost doing the same thing as those other ones.
    All in all, im suspecting a bad Main board.
    Any input at all would be helpful
    Thank you,
    one mans is another ones treasure
  • nomoresonys
    • 12328
    • U.S.
    Re: VIZIO e701i-a3 LFTRNXAP1002583 No video No sound , Just Backlights
    maybe try a firmware update, if possible.
    • maiden790
      • Nov 2014
      • 94
      cant do a firmware update with no picture on the screen.
      also i should mention the only button that seems to work is the power button
      • nomoresonys
        • 12328
        • U.S.
        so whats the recall relate to?
        • sgeorge
          • 16
          most likely a bad lcd panel. i just worked on one friday reolaced the t-con and main board. it turned out to be a bad panel. vizio had a recall on a lot of these. steve
          • nomoresonys
            • 12328
            • U.S.
            ok, now I see why they would hesitate to include more models, since it basically means they would have to replace the tv, and we all know they want to get out of it.
            • triplefour
              • May 2014
              • 1747
              i think in this case, jumping to the "bad panel" conclusion is premature, as a bad panel, just like the tcon, would not be able to cause any audio issues. verify that you truly cant change input's till you hear sound coming out of one of them, and then most likely it has to be bad motherboard. i wouldnt assume a bad panel until i knew i had a good motherboard and tcon and still was having the same problem.
              Don't fear the repair...
              • DonDuck
                • Oct 2015
                • 1
                I replaced motherboard and no change in symtoms : no pix, no audio, just backlight.
                I can see where it could be t-con with no video but no audio also points to motherboard.
                So does Vizio tvs have something different that t-con board is interconnected to mainboard circuit that if t-con board goes bad than audio is disconnected ?
                • freakaftr8
                  • Oct 2012
                  • 3743
                  You may want.to have a look here. Mine I have successfully made operational. Still running strong. It does require some modification to the panel as a "last resort " option. There is to date only one other person besides me that has done this operation with success on a sharp model tv. Same beast with the panel failure although different tv.
                  https://www.badcaps.net/forum/showthread.php?t=49281
                  And
                  https://www.badcaps.net/forum/showthread.php?t=48477
                  • budwich
                    • Jul 2015
                    • 3097
                    see other thread on this tv. Likely that the panel is taking out the tcon board.... actually a component on the tcon board which is shutting down part of the tv.
                    PS> freakaftr8 beat me... :-)
                    • ajshoe
                      vizio E60-E3 backlights, sound, no video
                      by ajshoe
                      Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                      Does this mean remove right side (from front of TV) tabs ?
                      Like a second opinion before possibly destroying set....
                      04-07-2023, 01:59 PM
                    • soeren
                      A2442 - No sound over internal speakers and no video playback
                      by soeren
                      I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                      All happened after the battery ran out of power overall several days when I was on vacation.
                      I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                      07-26-2024, 01:24 AM
                    • JRade
                      Audio video receiver KENWood KR-V990D,no sound
                      by JRade
                      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
                      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
                      I replaced the capacitor C303/0.047F, nothing changes.
                      I'm asking for help, what should I do next?
                      Thanks in advance!...
                      08-05-2025, 10:23 PM
                    • FrancescoV
                      Onkyo HT-R390 no sound output, video output ok
                      by FrancescoV
                      Good morning everyone,
                      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                      The firmware reported is the following:
                      M:1.00/11107BLP
                      D:?.??/????????
                      O:1.00/11107AL
                      The DSP firmware given the question marks seems corrupt.
                      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                      05-11-2025, 02:59 AM
                    • mecha1166
                      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                      by mecha1166
                      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                      11-25-2024, 05:22 PM
