Sanyo DP40142 No backlight
  • Herbssat
    • Sep 2011
    • 194
    Hi gurus. I have this Sanyo set at the moment with no backlight at all. All the voltages have been checked at P802 and P803 and are within spec. 24v is going to the inverter and the voltage for bl on is 3.2v as well as the pwm voltage of 2.5v. The panel for this tv is the LTA400HM23. I could not find a detailed datasheet but i did see that the led driver for this panel is embedded. Maybe some of you guys can shed some light on this set. Your help is appreciated.
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Sanyo DP40142 No backlight
    Show photo the led driver
    • Herbssat
      • Sep 2011
      • 194
      Thanks for the response. Do not have a photo of the led driver. I looked at some of the specs of the panel on another site. P803 plugs directly into the back of the panel in the upper right corner.
      • kasfamily
        • Aug 2014
        • 774
        • Russia
        Seen information that the led driver is inside the panel LTA400HM23
        • Herbssat
          • Sep 2011
          • 194
          Hello Guys. Still looking for a response on this particular panel with the embedded led driver. Would only like to tear this set down as a last resort if possible. I can get some pictures up if needed. Thanks.
          • Herbssat
            • Sep 2011
            • 194
            Screen is torn down to the led driver board. Jumped power supply with main board disconnected. Simulated Bl on signal with 3.3v battery supply. Still no boosted voltage at vout of led driver board. The driver board is a Ssl400 0d5a. I cannot find one anywhere. I did disconnect the led string while testing. The driver ic is a tr10e1. I cannot find a data sheet. All mosfets and boost diodes test good. Need ideas on this one.
            • Herbssat
              • Sep 2011
              • 194
              I have narrowed the problem down to the led driver board. All 43 leds in the screen light up when tested. The forward voltage is 2.5v so i presume about 108v should be powering this array. Here is a picture of the board if anyone can help. 2 mosfets and 3 boost diodes. No datasheet at all on the pwm driver ic. Thanks.
              • kasfamily
                • Aug 2014
                • 774
                • Russia
                http://www.kenotrontv.ru/forum/uploa...1407958929.jpg
                • Herbssat
                  • Sep 2011
                  • 194
                  Many thanks to you Kasfamily for your help. This gives me a good general idea as to what kind of voltage i should be seeing at the various points on the board. The only voltage i recall seeing is the 24v at both mosfets and the 3.2v or so near the connector on a smd capacitor or two. Why are parts so hard to find for this panel? The bottom line is i will have to rework the board just to get the backlights working again.
                  • kasfamily
                    • Aug 2014
                    • 774
                    • Russia
                    Must carefully check all the plugs on the led string, typically there is burnt contacts.
                    • Herbssat
                      • Sep 2011
                      • 194
                      I will check for that but everything seems to be fine as far as the leds and strips are concerned. I did get a little aggressive and cracked one of the strips. I will have to see if i can run a jumper from one side of the strip to the other on both sides. I assume it does have copper like most boards.Reminds me of the old tv days. Does this led driver board have a shutdown circuit when it senses no load or should i be able to see the boosted voltage without the leds plugged in. As i mentioned before there is only 24v at vout. Thanks for your help.
                      • Herbssat
                        • Sep 2011
                        • 194
                        Would like to expedite the process of repairing this set. I have 11.3v at the collector where 5v is shown. A transistor next to it checks bad in circuit. Also where is the 3v bl on signal going to on this board? A theory of operation would be helpful. Thanks.
                        • Herbssat
                          • Sep 2011
                          • 194
                          Need help identifying a component. Looks like a transistor marked with W1 and the number 30 is under it. The board location is Q005. This is on the inverter board. Thanks.
                          • kasfamily
                            • Aug 2014
                            • 774
                            • Russia
                            Show foto
                            • Herbssat
                              • Sep 2011
                              • 194
                              Hi Kasfamily. You already sent a picture of the led driver board with the voltages. What i can tell you is that both the base and emitter of Q00t4 and Q005 are tied together.Q004 is the transistor with the 5v.Q005 is also tied to pin 3 of the dual op amp that shows 16v.
                                The photo from the other site is not clear enough to see the components and how they are connected together.
                                We need good closed up pictures of the both sides of the board and also in sections to be able to see the traces on the board.
                                • kasfamily
                                  • Aug 2014
                                  • 774
                                  • Russia
                                  Hi Herbssat. Need photo marking Q005. Here's what I found on this driver, it is not my
                                  • Herbssat
                                    • Sep 2011
                                    • 194
                                    Thanks Kasfamily and Budm. Here are some pics. Hope these can help you to help me. Q005 is off the board. i presume it is a transistor also. It checks bad.
                                    • kasfamily
                                      • Aug 2014
                                      • 774
                                      • Russia
                                      Picture quality is poor, but where are the photos Q005 ?
                                      • kasfamily
                                        • Aug 2014
                                        • 774
                                        • Russia
                                        Q004 maybe 2SD1664 marking DA
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
