LG W2442PA backlight blinks out for a few seconds
  • Freydnot
    • Aug 2014
    • 12
    I have a LG Flatron W2442PA (actually I have two but only one is acting up) that has been in use for a few years. Recently the backlight cuts out and then comes back after a few seconds. A few weeks ago when it started, it did it every day or two. Now it is doing it every minute or so (randomly). Occasionally the picture will have a bunch of lines for a split second but that isn't very often.
    This unit has two boards; a power supply board and a logic board.
    I'm guessing since the backlight wires connect to the power supply board, that's where the problem is.
    A visual inspection shows the caps look okay, but there isn't any way to be sure.
    I'm thinking the easiest thing to do is replace the electrolytic caps and see if that fixes it. (see the attached pics for component IDs) I'm thinking C203, C204, C205, C206, C212 for sure, probably C301 and maybe C103 and C105.
    C101 and C108 look fine and I'm guessing I would have bigger problems if they were going bad.
    Does this seem like a sound plan? If not, what would you recommend?
    I've attached a service manual.
    I've got a Fluke 79 meter, a soldering station and many years of experience soldering.
    I'll post more pics in the next messages.
  • Freydnot
    • Aug 2014
    • 12
    Re: LG W2442PA backlight blinks out for a few seconds
    Various pics of the power supply board.
    • Freydnot
      • Aug 2014
      • 12
      A few pics of the logic board...
      • dj_ricoh
        • 2073
        • uk
        can you do something hard? or do you wanna do something rly hard?
        check the lamps on the panel !
        don`t take them out just check them.
        if you got some spares that will be nice ^^
        I`ll say that this is the first thing that I will do.
        • Freydnot
          • Aug 2014
          • 12
          I could do that. What would I be looking for in the CFLs? A crack or something?
          It seems to me if one of the CFLs were going out, the display would only dim (since 1 of 4 lamps is out). In my case, it goes totally black.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Looking cracks or blackened ends burnt wiring.
            On most sets if one lamp fails protection kicks in to protect the inverters and ALL lamps switch off.
            As you have another monitor you could open it up and plug in the panel from that
            just as a quick test. Or build two test bulbs for 14w or less cfls
            • Freydnot
              • Aug 2014
              • 12
              Good idea. As soon as I get time I'll take the second one apart and swap power supply boards. That should tell me where the problem is (and I won't have to dig into the LCD assembly).
              • Agent24
                I see dead caps
                • Oct 2007
                • 5027
                • New Zealand
                In one monitor that had 3 dying lamps, I saw no issue with the picture at all. Lines through the picture might mean PSU problem causing both picture and lamp issue. Perhaps.
                Swapping PSU boards at this point will be a good test.
                -David VanHorn
                • Freydnot
                  • Aug 2014
                  • 12
                  Well. I swapped the power supply board and now the problem seems to have gone away. Both monitors are working properly.
                  Maybe the wires inside were just lonely and needed some attention.
                  Now the waiting game to see if the problem comes back.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5027
                    • New Zealand
                    If you prove it's the PSU...
                    Check the capacitors on the bad PSU. Su'scon aren't renowned for being high quality.
                    Check all the solder joints, especially in the inverter section and around the transformer\coils and driving transistors etc. This is quite likely, bad solder in LCD monitors happens often and the fact that the problem went away after moving the PSU could indicate an intermittent connection somewhere.
                    -David VanHorn
                    • Freydnot
                      • Aug 2014
                      • 12
                      Well, two days of use and they are still both going strong. I notice the "problem" monitor that I swapped the "good" power supply board into seems brighter. I had to crank the brightness way down to get a good match with the other monitor.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5027
                        • New Zealand
                        That could be an indication of the old PSU having an issue with low voltage in the inverter
                        -David VanHorn
                        • Freydnot
                          • Aug 2014
                          • 12
                          Today I noticed the upper left corner of the problem monitor (the one that now has the "good" power supply in it) is looking a bit bluish. It doesn't show in a photo, but my eyes notice it. I'm guessing this means I've got a lamp that is going bad and was probably the cause of my original problem?
                          Since I was placing an unrelated order at mouser, I ordered some new Panasonic caps for fun. I'll probably swap them as a precautionary measure the next time I have it open.
                          Any advice on the lamp? How does one go about replacing a lamp? Is it wise to replace a single or should you really do all 4 while you are in there? Are lamps expensive? Where does one get lamps anyway?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5027
                            • New Zealand
                            At a guess I would say there is something wrong with the phosphor coating on the lamp and the blue you are seeing is probably light in the near-UV spectrum coming out where it should not.
                            Likely the lamp is bad and the old inverter was shutting it down, the new one may not be as sensitive...
                            You can get new lamps on eBay and other places, quite cheaply. You need to know the dimensions of the old lamps. Replacing them is possible and not extremely hard, but you have to take care not to damage the panel or the lamps.
                            -David VanHorn
                              • 31169
                              or you can get an led upgrade kit.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5027
                                • New Zealand
                                https://www.badcaps.net/forum/showthread.php?p=477574 mentions having blue on his backlighting possibly due to a bad cable.
                                -David VanHorn
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • Pygo86
                                  Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
                                  by Pygo86
                                  Hey Folks,
                                  i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
                                  The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
                                  I can power it up again, but it's always the same Result.
                                  No Matter which Connection is used.
                                  I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
                                  The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
                                  So, i decided to swap that Logicboard....
                                  03-04-2024, 11:38 AM
                                • alpersen
                                  Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
                                  by alpersen
                                  Hello
                                  Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
                                  07-25-2024, 12:50 AM
                                • DanPoka
                                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                  by DanPoka
                                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                  02-15-2025, 05:05 AM
                                • Comp_Pro
                                  No Backlight Macbook A1990 820-01041
                                  by Comp_Pro
                                  Hello all,
                                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                  Tests performed:
                                  There is no backlight even with a good screen.
                                  Backlight IC is receiving the correct support voltages.
                                  Fuse F8400 ok
                                  Current sense resistor R8400 ok
                                  Backlight IC is receiving 3.3V on enable pin.
                                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                  Backlight IC receiving 5V from PP5V_G3S
                                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                  05-06-2024, 10:23 PM
