If you're looking for a solid 550W PSU, check this out.
  • gg1978
    • Dec 2004
    • 431
    I came across these PSU's looking for a couple of Delta's.. They're Sun Workstation pulls, that have the 24 pin main ATX connector, and the 8 pin +12V connector. They have two circuit boards inside, filled to the brim with big inductors and transformers, and plentiful output capacitance. The heatsinks are massive and one has a coppery bronze plate on it.. They have one 80mm Nidec Beta SL cooling fan and Active PFC. The output caps are OST, which obviously aren't as good as Nichicon or Rubycon, but i'd say they're better than Fuyjhyuiu or whatever the ones are that are frying the Antec PSU's right now.
    I was attempting to upload some pics, but it timed out. Stupid Dialup.. Anyway, just a heads up to the community if you're looking for a good 550W PSU for ~$30.. They're pulls from Sun workstations, i'd say probably dual Xeon ones..
    Ooops, almost forgot the link...
    http://www.hypermicro.com/product.asp?pf_id=PSAB001
  • Maxxarcade
    • Jul 2006
    • 973
    Re: If you're looking for a solid 550W PSU, check this out.
    Damn, wish I would have waited for your reply. That is exactly what I'm looking for, for a third of what I paid for the Zippy
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      So if you stuck some Panasonic FC's or something along those lines in there, you'd have something!
      -goes off to buy one-
      A man convinced against his will is of the same opinion still.
      • weirdlookinguy
        • Sep 2007
        • 1638
        Could you try making the pics smaller and then uploading, or telling us more about this PSU? I'm considering buying one for my next build - I won't have the money to build the PC for another few months, but I think I should grab one before they're gone. $30 for such a good PSU seems too good to be true though.
        • acstech
          GrumpyModerator
          • Jul 2007
          • 1432
          I've got one sitting over here, if I get some time I'll upload some pics, if the OP doesn't get around to it.
          • gdement
            • Jan 2007
            • 690
            Can the 8-pin EPS12V plug fit on a board with the 4-pin P4 socket, if you overlap the plug? It looks like I might have room for an overlap, but I don't know if that's keyed to work. Searching for info on 8-pin psu's to 4-pin boards is frustrating - everybody else out there is trying to do the opposite.
            • acstech
              GrumpyModerator
              • Jul 2007
              • 1432
              It did on the board I tested it with, which was a Biostar Tforce 7025-M2. The little snag is that the clip is in the middle, which is in the wrong location for a 4 pin plug. So you'll need to find another method for securing it.
              But yeah, if you've got room for it, it works.
              • weirdlookinguy
                • Sep 2007
                • 1638
                Are you sure these are pulls? They look new to me, they say they have 200 in stock and I don't think it'd be easy to acquire 200 working pulls.
                Anyway, you're saying replace everything but the hugeass filter caps with Pana FC's and you've have an excellent PSU?
                • acstech
                  GrumpyModerator
                  • Jul 2007
                  • 1432
                  Personally, I'd put Panasonic FM's in there as the unit is well cooled, as they have lower ESR. Probably the thing to do would be to look up the specs on the type of OST's in there, and find the Panasonic line that most closely matches that.
                  I have yet to try recapping one of mine (I bought 2) so I couldn't tell you how they work recapped. However, they do seem to work quite well the way they are. Of course, longevity is suspect, in my opinion, due to the OST's.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Are the OST output caps those stupid 10mm 4700uF craps?
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      And if so do they have room for 12.5mm caps there?
                      - Dr Seuss
                      • acstech
                        GrumpyModerator
                        • Jul 2007
                        • 1432
                        On the top PCB, we have 2200uF, 16v, and 3300uF, 10v. Those are all OST RLS. There's a couple JPCE-TUR 1000uF 10v units. The OST's are all 10mm diameter and pretty well bunched together. Also height may be a factor as they're getting fairly close to the lid. You've got probably another 8mm of height to work with, not much more.
                        See here for the OST data:
                        http://www.ost.com.tw/products_ec_list.asp
                        Then click on RLS.
                        Interestingly, the 16v 2200uF unit in 10mm diameter is not even on their data sheet.
                        Recapping this unit may be trickey.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          +1
                          fm are fine and easily gotten.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I have com across OST that aren't in the data sheets before.
                            Dunno if they are custom parts or counterfeits.
                            That's cool about the sizes.
                            10mm 3300uF and below in good caps aren't impossible to find.
                            - As in they at least exist...
                            - Dr Seuss
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              Probably have to go to Samxon though, no?
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                I have some in MBZ
                                - Dr Seuss
                                • Spacedye69
                                  • Nov 2005
                                  • 698
                                  • US
                                  The problem with 10mm in a power supply is you really should be using a longer life, non aqueous cap. I have a feeling 2000 hr ultra low esr aqueous caps, even good ones, are not going to last long. Finding a long life 2200uf 16v in 10mm is a bitch. You can get them in a Ruby ZL, but thats about it.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I have 22,000 MBZ
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      I don't think I'll run out of MBZ any time soon.
                                      - Dr Seuss
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        Originally posted by PCBONEZ
                                        I have 22,000 MBZ
                                        you hit the same deal i did.
                                        lifetime supply even after selling a load to other techs i deal with.
                                        did you get any 1800@16 mcz?
                                        • AJ847.63e
                                          A2338 Screen replacement - Clarification needed. What do you actually loose when replacing the screen with OEM Pulls?
                                          by AJ847.63e
                                          Hi All,
                                          Just wanted to get some clarification on replacing screens on M series machines (M1,M2,M3,M1pro,M2pro,M3pro) as there is so much conflicting information out there. Some say even when using OEM pulls you lose True Tone and only that, others say you lose that and webcam, others say you lose those two and also the lid sensor will not work, others say you lose nothing as long as you use OEM pulls.
                                          So, which one is it actually? Using original OEM pulls. That seems to be what has caused the confusion, people using cheap aftermarket than being surprised when it does not work...
                                          03-06-2024, 06:44 PM
                                        • peter21
                                          BeQuiet Dark Power Pro P10 550W PSU: Missing 5V Standby
                                          by peter21
                                          Hi there,
                                          a friend of mine gave me a BeQuiet Dark Power Pro P10 550W PSU.
                                          The problem: The PSU simply switched off during operation and never came back on.
                                          My observations / measurements:
                                          I opened the housing and checked for obvious damage -> negative. Visually, everything seems fine.
                                          Lowcost power supply tester (China):
                                          No result. The power supply does not turn on and the tester keeps off
                                          Next, I measured the 5V standby line (pin 4) on the ATX connector.
                                          Result: Not present (!).
                                          Obviously this seems...
                                          02-24-2024, 10:11 AM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                        • eccerr0r
                                          solid polymer electrolytic capacitor go boom?
                                          by eccerr0r
                                          Anyone had a solid polymer capacitor fail for whatever reason?
                                          How do they fail? Do they explode, go open, short out, ?
                                          How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
                                          Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
                                          07-25-2022, 07:12 AM
                                        • ChaosLegionnaire
                                          how do u use solid rosin flux?
                                          by ChaosLegionnaire
                                          i recently bought a block of solid rosin flux from aliexpress. i intend to use it for reflowing cold solder joints and cracked solder joints. but im not sure how im supposed to be using it? do i just break off bits and pieces of it with a knife and put the bits of solid rosin on the bad joint im soldering then bring on the iron?
                                          i tried asking google and they pointed me to a headphone forum and eevblog? and they said to just dip the soldering iron tip into the solid block. a small piece of flux will be attached to the soldering iron tip end and im supposed to use that to reflow...
                                          06-24-2020, 02:34 PM
