Some info i dug up on the web.
Plasma tv Panasonic GPF15DE Chassis can cause not powering on & standby LED lit, can be very intermittent
At a certain sequence of events, the TV does not turn on
and the standby LED is not lit. For example, after disconnecting
of power, then after you turn
within 3 minutes. This modification applies to all
PSU with serial number earlier than below:
42” N0AE6JK00005 **-2550001
50” N0AE6JK00006 **-2560001
TCZAA6755U IC ref (U203)
Not 100% if datasheet is correct device or proprietary for Panasonic by Fairchild.
Does look like FAN6755UW going by the format in the sheet.
Translated some other info.
Some links for the IC
http://www.ebay.com.au/itm/PANASONIC...-/160971382674
http://www.ohmsupplies.co.uk/TCZAA67...42X50-TXP50X50
http://www.notobsolete.co.uk/index.p...oducts_id=1209
http://www.chsinteractive.co.uk/elec...-panasonic.htm
Some models possibly applicable to.
tx-p42x50b ,tx-p50x50b, tx-p42x50e. tx-p50x50e ,tx-p42xt50b, tx-50xt50b, tx-p42xt50e, tx-p50xt50e, tx-p42xt50y, tx-p50xt50y,tx-pr42x50, tx-pr50x50 tx-pr42xt50, tx-pr50xt50, tc-p42x5, tc-p42xt50, tc-p50x5, tc-p50xt50.
PSU models: N0AE6JK00005 , N0AE6JK00006
If anyone tries this info and solves the problem, please validate by reporting results.
