Magnavox 37" LCD 37MF337B/37 PS: 715T2484-4 Chirping after cap/diode replace/check
  • LeviathanEnt
    • Jan 2014
    • 8
    • US
    Greetings Everyone, Thanks so much for the wonderful insight I've found here so far. I've found quite a bit of information on this topic, however mostly centered around replacement caps and diodes.
    Problem: For years this TV has had a problem powering up. Sometimes the power light would go green but no picture, requiring me to plug and unplug it till it worked. More recently I started hearing a whining noise (which later turned into chirping) when it would power up. Then a new problem started, turning on for a short time and then turning off after a few secs/mins. Upon powering back on the power light would flash repeatedly very fast, then either power off or power on. Now after a couple weeks of that, it simply went off. Leaving me with only the chirping noise. And no reaction from the power button.
    I have read through the following 3 posts I found here:
    https://www.badcaps.net/forum/showthread.php?t=11962
    https://www.badcaps.net/forum/showthread.php?t=17378
    https://www.badcaps.net/forum/showthread.php?t=30171
    And the service manual:
    http://www.tgohome.com/ServiceManual...&Search=Submit
    I have replaced the following caps:
    C921,952,953,955,956
    I have tested the following diodes successfully with the following readings:
    ZD901:0.544/OL
    ZD902:0.540/OL
    D925:0.481/OL
    D907:0.498/OL
    D912:Reads 0 in circuit due to resistors as stated in threads above, I tested it out of circuit previously and it gave a reading similar to those above although I don't remember the exact reading.
    Still get chirping when connecting power to the power supply. (outside of LCD)
    Voltage across C907: 167V
    Note: I can read schematic symbols and have a general understanding of components. I have a DMM and a regulated soldering station and can use it fairly well.
    Thanks again for all the help I have already found here and thanks in advance for what may come.
  • mmartell
    • Oct 2013
    • 3189
    Re: Magnavox 37" LCD 37MF337B/37 PS: 715T2484-4 Chirping after cap/diode replace/chec
    Did you replace caps with high quality ones or from Radioshack ?
    • LeviathanEnt
      • Jan 2014
      • 8
      • US
      Indeed the 3 - 1000 uF 35v caps came from the Shack (all that's open today). The others came out of my parts box. As for the others being higher quality, not sure. I did upgrade the 2200uF 15v to a 35v, otherwise nothing. And I understand you probably meant a better brand not a higher voltage.
      For what it's worth, C955 was the only cap that seemed to have any visual abnormality, that is a bit of a peaked top.
      Thanks for the quick response.
        I'm afraid that the capacitors you just installed could well have been worse than the originals, even if one were failed! General purpose "rat shack" capacitors are NOT suitable for switchmode PSU.
        • LeviathanEnt
          • Jan 2014
          • 8
          • US
          Fair enough. I can put an order in with Digikey or whomever for higher quality parts. Just figured I'd throw some parts at it over the weekend. Most of the caps came out of other salvaged known good power supplies and I happened to be passing the Shack, so I grabbed the 3 I didn't have.
          Though it seems most of the people discussing these issues had some obvious visible problems; burns, leaking/puffy caps. And several people had the chirping continue after replacing these items, some of which were solved by diodes, which seem to be good.
          So perhaps there is something else to look at? A few more voltages to verify or something? I'm not too good at deciphering the schematics as a whole, so I really don't know where to test for 12 and 24v or whatever it should be.
          PS: Is the Radio Shack stuff "not suitable for a switchmode PSU" because of the tolerance or the ESR? Or just the build quality or all of the above?
          • LeviathanEnt
            • Jan 2014
            • 8
            • US
            So I guess the consensus would be to get new stuff from digikey or otherwise. I don't think I actually saw a consistent list of components to replace, Certainly, the caps I mentioned but some people talk about replacing all the caps on the board, some even beyond just the "can" style (electrolytic?). Not to mention the Mosfet and diodes. I don't mind buying new stuff, I just would like to get enough to hopefully be in the clear and get the right parts. Also when ordering, do any parts that match the specs on the components work or do I need to be more specific than capacitance and voltage?
            Or I could buy a kit like this from eBay, but he mentions less parts for the chirp:
            Repair kit #1 contain: 6pcs Nichicon high quality capacitors and 3 zener Diodes. fix chirping sound.
            Repair kit will come with Locations of each components. PC BOARD # 715T2454-1 and 2
            Symptoms; DEAD POWER SUPPLY. SOME OF YOU ALREADY REPLACE CAPACITORS BUT HAS Chirping sound. you need Kit #1.
            Symptoms; DEAD POWER SUPPLY. If F901 fuse open and Q901 bad. you need repair kit #2.
            Repair kit #2 contain:
            1; 7 capacitors
            2; 3 zener Diodes
            3; 1 mosfet
            4; 1 ic
            5; 1 resistor
            6; 1 fuse 6.3 amp.
            http://www.ebay.com/itm/715T2484-2-P.../200948803931?
            Or here's a complete refurbished power supply for about $100, though this is a 715T2484-1 and I have a 715T2484-4 (looks the same, different revision, prolly just as bad?):
            http://www.ebay.com/itm/PHILIPS-37PF...item19e7864249
            Thanks again for the quick responses.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              sounds like bad startup cap to me with the chirping?,id replace that one,and output caps with panasonic fm series.and see how you go from there
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • tvrepairguy
                Brdcst Engineer
                • Jun 2014
                • 15
                Its the ZD906...its the chirping sound. Spray and air can upside down on it. It will change the temp of the diode and the chirping will go up and down. This tells you that the diode is the one thats bad....spray rhe others and nothing happens....good. just fixed mine today and its up and running again ....took me a year to figure it out.
                • tvrepairguy
                  Brdcst Engineer
                  • Jun 2014
                  • 15
                  I believe the part i used to replace th diode is NTE4892
                  • tvrepairguy
                    Brdcst Engineer
                    • Jun 2014
                    • 15
                    Start spraying one by one the diodes labled ZD followed by 3 numbers. The chirping will change when sprayed with the co2 from the aircan and will reveal the problem diode
                    • tvrepairguy
                      Brdcst Engineer
                      • Jun 2014
                      • 15
                      nte4982.....sorry
                      • orgwood
                        • Apr 2013
                        • 39
                        Originally posted by tvrepairguy
                        nte4982.....sorry
                        I have fixed 2 42" flat screen TVs so far - one LCD & one Plasma and trying to work on my son's version of this set Philips. I bought a cap kit with 2 zener diodes but the chirping continues...it's faster with the boards/cables unplugged. The area to the right of the big center transformer looks discolored especially around ZD908. I can't find a link to the schematic for this PS so I'm in the dark about values, etc. Any help would be appreciated.
                        Dave
                        • orgwood
                          • Apr 2013
                          • 39
                          I found the schematic and with budm and his help I was able to buy replacements for the FETs and the small IC and get this working. If anyone needs any help with theirs, please send me a message or post here and I think we can work you through your problem.
                          • orgwood
                            • Apr 2013
                            • 39
                            https://www.badcaps.net/forum/showth...t=17379&page=3
                            Here's the link to the Philips SMPS thread since they basically are the same.
                            • iMuhtaseb
                              A2681 Keyboard, trackpad and sleep?!
                              by iMuhtaseb
                              Wow it's been a while since I posted!
                              This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
                              A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
                              It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
                              Tested another locked logic board on customer's top case and it posted with keyboard and...
                              05-22-2025, 09:59 AM
                            • NicRac
                              monowheel repair,Is the diode the problem?
                              by NicRac
                              Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                              First of all, I am new here. Therefore I will shortly introduce myself.
                              I am Nico and currently I study Physics.
                              In my freetime I like to build and repair stuff. Especially big battery's.
                              A few years ago I got myself an electric unicycle, monowheel or however you call that.
                              The battery bms was broken so I replaced and resolder that. Nothing big.
                              I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                              07-26-2024, 06:13 AM
                              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                              by sam_sam_sam
                              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                              I bought this from an eBay seller but unfortunately they only had one
                              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                              I bought three of from them to also make battery packs with this output power limit in mind
                              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                              04-23-2025, 05:50 AM
                            • SuperAman
                              PS5 HDMI port diode reading?
                              by SuperAman
                              I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                              02-03-2024, 10:16 PM
                            • badcappo
                              Compatible diode replacement "V6 18" ?
                              by badcappo
                              Hi there, looking for a compatible replacement for a diode type labelled "V6 18" from a dead Panasonic plasma TV power source. Possibly a V6 600 volts diode as seen here: https://electronics.stackexchange.co...nt-diode-v6-88 ?
                              Thank you ...
                              03-16-2025, 06:39 AM
