I recently aquired a 37 inch magnavox lcd tv, was told tv shut down after about 5 minutes of running and would not come back on. It has a chirping sound coming from the back. So i pulled the back cover to find a 25v cap bulged on the main board, replaced it, still chirping. Im pretty sure the sound is coming from the main board. Anyone had this issue?
Magnavox LCD 37mf437/37 chirping
Tags: None
Re: Magnavox LCD 37mf437/37 chirping
Replace ZD902, ZD904, D925. Common fault.
Part codes in schematic:
Last edited by tom66; 07-18-2013, 12:33 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I replaced all the diodes tom66 mentioned, chirping issue is still there. How is a zenor diode supposed to measure on the diode test, I get o.574 one way on all of them on board, even new ones from digikey.Last edited by topfli8979; 07-19-2013, 07:25 PM.Comment
Also when main board is disconnected from power supply the chirping is gone.Comment
Check 12V & 24V outputs, are they stable or bad?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
When PS disconnected from main board there will be no PS turn on signal, hence no chirping.
When no 12v or 24v is the main board connected to the PS? Or is that when it is connected?
Which 25v cap did you replace?
Add a photo of the solder side of the board.Last edited by notallbad; 07-30-2013, 12:48 PM.Comment
I replaced 25v cap C131 on main board, it was bulging. I have no 24/12v comng out of power supply with, main board connected.Comment
OK, did you power the tv up yourself to see what the fault was and what happens. You cannot always believe the 'customer'!
Backlights won't be switched on unless theres a 3v signal, blon which comes from the main board.
Power on the tv, ok so its in standby only, list the voltages you get from CN902, CN903 and CN905.
Have you seen this? It lists 3 diodes as you have done and 6 caps
http://www.ebay.com/itm/715T2484-2-P...B:STORE:US:101Last edited by notallbad; 07-30-2013, 05:02 PM.Comment
Yes I powered on the tv, it only chirps. Buttons do nothing when pressed. I will measure the voltages across those components.Comment
@topfli8979: OK, since you are not getting the 12v/24v, you need to find out if the PFC voltage booster circuits are working or not since the 12v/24v power supply section requires the PFC to be working.
Carefully check the DC voltage RIGHT AT THE TWO LEGS of that large 450vdc filter cap in the primary side, check it when the TV is off (should be about 160~170vdc) and when the TV is on (should be about 370~380vdc). Do not touch anyhting on the board with your hands since you are working in the HOT side of the circuit.Last edited by budm; 07-30-2013, 08:18 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
Why? PFC circuit capacitor will have around 380 to 400V DC on it. In standby 320V or 160V maybe.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
Channel: Troubleshooting Audio Equipment
06-11-2024, 08:38 AM -
by nicktasiosI had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...1 Photo12-22-2024, 05:07 AM
by PlasMattI have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 02:30 PM
- Loading...
- No more items.
