Hello, I an new to this forum and want to thank you all for the incredible jon you do. I am a novice/ intermed. with electronics.. my experience is mor with computers. Okay my problem, much like many others. I replaced 3 bad caps. However, when I out the power chord in the red LED goes on then I get what I would best describe as a CHIRP. Any thoughts. beseides caps model #47MF437B/37
MAGNAVOX no picture powers LED 47MF437B/37
Re: MAGNAVOX no picture powers LED 47MF437B/37
I think I may have worked on one of these once. If you've already replaced all four caps (whether visually bad or not) then list the voltages that you get on the output of this supply.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
If you type in the model number "47MF437B" on the site below, you can get a service manual for this set. This should help you out a great deal with this problem. Just remember, the caps may have took something out with it.
http://elektrotanya.comThe strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Power board schematic taken from the service manual PDF. You're really gonna want to download the manual if you need it clearer. This site has a limit for posting pdf files for attachments.Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by Dgtech; 11-13-2011, 05:28 AM.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
Thanks for posting that for me. However, being a novice to all this. The picture I see is one VERY VERY difficult to decipher. Any suggestions on where to start. I get the red power LED to light up,
- then press the power button and I get the chirp, chirp chirp. Strange though even though I replaced my bad caps. That same sound happened before I replaced them.
So , the three ne caps changed nothing.
VanComment
A 'chirping' sound usually indicates a bad startup cap, a shorted diode on the secondary of the transformer, or an excessive load. Because of the usual design of these power supplies, it's probably not a startup cap.Thanks for posting that for me. However, being a novice to all this. The picture I see is one VERY VERY difficult to decipher. Any suggestions on where to start. I get the red power LED to light up,
Van
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
<rant>
Damn, and I used to think of Philips as good.
I opened up a 37PFL7662D/05, not that old. Full of Rubycon and Nichicon. A 32PFLxxxx (forget the full number) had Rubycon, Nichicon and Chemicon... all very good caps.
That power supply looks like they put caps on it that they found in the bin or on the factory floor. Why is one of the three 2200u/35V caps larger?
Ugh, I suppose even good engineering goes to the wayside when bean counters get involved.
</rant>
I have several working supplies that chirp when power is lost, I think it's possibly to do with the frequency of the switcher changing to keep the voltage stable as the bulk cap discharges. But the chirping when trying to turn on is definitely a problem.
There is a startup cap on this model C957 bottom center.Last edited by tom66; 11-14-2011, 09:29 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I will try to replace all caps. Just to see what up. Although if I can get a picture of it the LARGE YELLOW TAPED piece in the middle looks like it horrible corrodided at the bottom. Guys anything else? Thanks for the help thus farComment
Can anyone help me make heads or tales out of this?
http://www.scribd.com/doc/68245090/5...-0u-la-sm-ET-1
ThanksComment
You said that you replaced three caps but there are four on the board. Did you replace all four or just three? That green cap looks like a capxon capacitor. I would not skip changing this one.The strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
I dont know if you've seen this thread but check it out if you didnt. Similar power board from Magnafraud.
https://www.badcaps.net/forum/showth...light=MAGNAVOXThe strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
hey, I have managed to get my hands on a repair manual. This is great news!! It would be even better if i could figure out what is what in it. Sorry guys I am really a novice. I can tell you the voltage something is running but I dont know thats a good or bad thing.
Any help would be greatly appreciated!!
SVComment
Hello again from the STRUGGLING NEWB!!!! I have noticed that the T907 Trans (PIC ATTACHED....ALSO PLEASE CONFIRM OR SUGGEST A MODEL NUMBER TO THIS PIECE SO I CAN BUY IF AVAILABLE.
Thanks you for you help
PICTURE 1 is my entire PSU with TRANS BLOCKED IN YELLOW
PICTURE 2 CLOSE UP OF ITEM IN QUESTION
PS PLEASE HELPAttached Filesif you find these attachements useful please consider making a small donation to the site
by csmithI replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
issue. Set will power up with remote but not power off.... -
by sergio_avHi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...1 Photo -
by KYBOSHSaved this beast from the landfill this weekend.
Manfactured July 2013 in Mexico.
I love working on plasma TVs.
Its been a while but I was lucky enough to find 2 this week.
The TV powers on and stays on but no picture. Havent checked for sound yet.
No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
Will start troubleshooting tonight.
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... - Loading...
- No more items.
