Fake Teapo 680uF primary caps-470uF real capacity (Arctic A-430BX)
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    The label says it is 430W but the pcb says “HEC-250TN”. At least it has a full input filter, only the thermistor is missing. The primary caps real capacitance is 470uF. That makes me wonder if someone did fake Teapos.
    -Passive pfc
    -GBL406 4A bridge rectifier
    -UC3843B PWM controller
    -S2N60 N-Channel MOSFET for 5vsb
    -TPS3510P IC for psu protection
    -heatsinks only good for 350W max provided there is good airflow and high efficiency
    -main transformer is ERL 35 size. Not good for 430W in my opinion.
    -I was unable to read the main mosfet's marking. There is something like green glue attached to it. It is in small package and there is only one there. I bet it can't do more than 350W without blowing up.
    -psu fan is thermally controlled and "Hec" brand.
    -All caps are Teapo, DON and Su'scon
    -1x MBR3060 @ 12V
    -1x STPS3045C @ 5V
    -3.3V: I think current passes through an STPS3045C and then a 09N03LA Power-Transistor, I am not sure, I am not familiar with this design... Could someone explain this to me please?
    -Soldering is ok
    -Of course it is not dual rail as the label states. It is single rail psu.
    What do you think its actually wattage is?
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Re: Fake Teapo 680uF primary caps-470uF real capacity (Arctic A-430BX)
    Excuse the potentially stupid question: Is that what's called 'single transistor forward' topology?
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      It looks like the STPS3045C technically outputs the power for the 3.3V, and the 09N03LA acts as a voltage regulator to step the power down from the 5V rail
      350W seems about right.
      Yes
      EDIT: I've seen those fake Teapo's too! https://www.badcaps.net/forum/showpo...6&postcount=51 Are you gonna recap that? It doesn't look bad.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        I've seen that platform before. It's actually quite decent. Certainly worth a recap. I had the 350W version (and of course, labeled as 500W), brand was Rasurbo IIRC. Primary switching FET, UC3842 and gate resistor were blown on mine. The PSU will do well if that FET is replaced with something more beefy.
        A working TV? How boring!
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Yes
          The owner of the computer just wants it to work again. Unfortunately, it seems he destroyed something trying to clean PC from dog hair..
          The psu works without a problem.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            This is an independent linear 3.3V rail design. With this design, the transformer's 5V tap is taken and rectified (with the STPS3045C, in your case) and filtered. Then this voltage rail (which is separate from the main 5V rail) is stepped down in a linear fashion with a MOSFET (very inefficient at moderate-to-high loads, but very clean and stable voltage output). There's usually another cap after the MOSFET to further smooth power. You can recognize this design by the lack of torroid coils for the 3.3V rail.
            There's also the dependent linear 3.3V rail design. This design is usually found in very cheap PSUs because it uses very few parts (i.e. cheap). It's the same as the design above, except you don't have a rectifier. Rather, the MOSFET is few directly from the main 5V rail of the PSU, and the MOSFET simply steps it down to produce 3.3V. You still get the same clean output voltage, but the downside is that the 5V rectifier needs to be bigger since it is used for providing power to both the 3.3V and 5V rails (so the current rating of the 5V rectifier defines the combined power on 3.3 and 5V rails).
            Both of these designs are referred to as linear 3.3V designs. The other design is the one you're probably more familiar with - a small torroid coil for the magamp regulator and a bigger torroid coil next to the 5V/12V torroid coil.
            Depends on what the main MOSFET on the primary is rated for. The Thermaltake TR2-430W (XP550-NP) uses the same platform, and although rated at 430W by Thermaltake, it is only capable of 350W max (PSU has OPP if I remember correctly, so it shuts down if you try to pull more than that out of it).
            That may be. But it has a 2-transistor 5VSB design that DOES have a critical cap and is capable of being a motherboard killer (I think even someone on Badcaps posted about his/hers having a voltage on the 5VSB above 6V). So make sure to change that critical cap with something good.
            Confirmed
            My TR2-430W has two 680 uF Teapo caps as well, and both measured around 470 uF. See the chart at the end of my post here:
            https://www.badcaps.net/forum/showpo...5&postcount=57
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              Do you mean that there are two 5V outputs, in a way, in such a linear regulated design? I ask because I wonder if the Hipro units that use linear regulation to generate +3.3V actually do have a separate transformer tap for that rail or if it's just taken from +5V in the manner you mention (that would dissipate quite a bit more power... if it's taken from +5V, even 10A @ +3.3V = 17W of power dissipated [through the power transistor]! But if it's taken from a transformer tap that ultimately measures closer to +4V before it's stepped down, only 7W would be dissipated at the same load)... I guess the only way to find out for sure would be to unwind the transformer (without checking the rectified output through other means), but I don't know of anyone who's done that. There does 'appear' to be a separate transformer winding in the transformers, in those Hipro PSUs, but there appears to be one in these Thermaltakes as well, which is why I ask. I don't mean to derail the thread by asking.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                If there is a separate tap, then I would guess it's lower than 5V in order to increase efficiency.
                You don't really have to unwind the transformer to check the voltage - just solder a piece of wire to the rectified rail and measure voltage with respect to ground when PSU is on.
                I'm lazy, so I never gotten around to doing that.
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  Thanks for the advice. But I believe you once said in the another thread (I believe another one regarding a Thermaltake power supply, since that's the original topic at hand) that with the independent method, the DC output is usually higher than +3.3V and maybe even +4V. Coupled with the observation that there seems to be another tap in the transformer, I thought it was more or less stepped down from +4V. I guess that's possible, I know the magamp is used as a buck regulator of sorts to step down the higher voltages in the transformer taps after they've been rectified, for the other rails, besides cleaning up the ripple current... so I wonder if the magamp is used to any extent in the independent design, in terms of regulation, before the MOSFET finally regulates it down to +3.3V.
                  Another Thermaltake, a rather different unit, was reviewed several years back at Hardware Secrets. It also uses linear regulation to generate +3.3V and its efficiency never went below 70% (the +3.3V rail was loaded to 16A in the last test... it managed 350W with good voltage regulation but shut down at 430W), so maybe there is another tap.... but that could just be a byproduct of a higher duty cycle at lower loads (higher duty cycle = less conduction losses and higher efficiency). Or it could be the fact that it uses a FET with a very good ON resistance rating to regulate the voltage down to +3.3V, or maybe just that it has both an exhaust and intake 80mm fan for augmented airflow. That power supply performed very poorly otherwise, though, especially for a unit that appears to be single switch forward... the ripple voltage on all rails, especially as the load increased, quickly started touching the ATX spec limits and beyond. Something is definitely amuck with it.
                  I believe Pentium4 has a very similar PSU and stated that it only has a single 2200uF 16V Teapo SC capacitor and no ferrite coil for the +12V rail, so it doesn't really have a proper or complete output filter.... that might be why... yet in the review, the +12V ripple voltage jumped to 680mV when they try to overload it even a bit. Then again, the +3.3V rail is shown to be outputting an unusual amount of ripple voltage in the review, so it might not even be linear regulation in these PSUs. Goodpsusearch's PSU looks to be similar in terms of light output filtering.
                  • senz_90
                    • Aug 2013
                    • 328
                    • Indonesia
                    geez. i think this teapo 680uF attach to my psu too!!
                    unfortunately, i don't have caps meter to measure it.
                    "There is no shortcut to be successful. No pain, no gain."
                    Best Regards
                    Rudi
                    Thank You
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      This power supply belongs to me now and I am planning to do a recap.
                      I was able to read the marking on the main mosfet. The Arctic psu uses an STP10NK60Z (TO-220 package) in a single transistor forward configuration
                      Drain Current (continuous) at TC=25°C ID=10 A
                      Drain Current (continuous) at TC=100°C ID=5.7 A
                      Drain Current (pulsed) ID=36 A
                      RDS(on)=0.65Ω
                      Total Dissipation at TC = 25°C Ptot=115W
                      I have some STW9NB90 (TO-247 package, RDS(on)=0.85Ω) available from dead Antec SmartPower psus.
                      Is it worth to replace STP10NK60Z with STW9NB90 or should I order something better from http://gr.rsdelivers.com/?
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        lower rdson is better
                        • c_hegge
                          • Sep 2009
                          • 5219
                          I thought you said earlier that the PSU worked. If the switcher isn't blown, then I wouldn't worry about replacing it. I would just recap the PSU and keep it as a 350 watter. It would do fine in a basic home or office PC.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            The psu works but I thought I could get some extra juice from it if I replace the TO-220 STP10NK60Z mosfet with something better as Th3_uN1Qu3 suggested.
                            For example this psu you have reviewed was able to output more than 400 watt using 1x FQA10N80 MOSFET (RDS(on)=1.1Ω) in a single transistor forward topology.
                            I am also going to replace the fake Teapos with real 680uF primary capacitors.
                            • Heihachi_73
                              • Jun 2012
                              • 713
                              The Teapos I have of that shape are blue 560uF SK series dated 07/03, and are still in spec at 499uF and 505uF respectively.
                              Get rid of anything which has "VENT" or "TEAPO" on it and your trouble should go away.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                I partially recapped that HEC OEM power supply. I used Panasonic, Sanyo, Nichicon, Rubycon and Teapo capacitors.
                                I also tweaked the fan controller. The psu still remains one of the most silent I own and it doesn't overheat.
                                I replaced the fake 680uF primary caps with real 680uf caps (measured capacity 725uF & 690uF).
                                I replaced STP10NK60Z with STW12NK80Z. More info about that operation here:
                                https://www.badcaps.net/forum/showthread.php?t=45884
                                Do you think it can do 350W without blowing?
                                  MSI Trident 3 Arctic 9SI-618EU Trident 3 Arctic i7-9700F Specification for Upgrade or Repair
                                  This specification for the MSI Trident 3 Arctic 9SI-618EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 9SI-618EU boardview and Trident 3 Arctic 9SI-618EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-12-2024, 03:28 PM
                                  MSI Trident 3 Arctic VR7RC-281 Trident i5-7400 Specification for Upgrade or Repair
                                  This specification for the MSI Trident 3 Arctic VR7RC-281 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic VR7RC-281 boardview and Trident 3 Arctic VR7RC-281 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  MSI Trident 3 Arctic 8RB-092UK Trident i5-8400 Specification for Upgrade or Repair
                                  This specification for the MSI Trident 3 Arctic 8RB-092UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 8RB-092UK boardview and Trident 3 Arctic 8RB-092UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                • bauto601
                                  KDM 480W PSU upgrade succes! (opinions?)
                                  by bauto601
                                  Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                  A "nice" YoungYear unit? - Badcaps
                                  The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                  12-26-2023, 03:05 PM
                                • iMic
                                  IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                  by iMic
                                  Hi folks,
                                  I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                  The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                  11-29-2023, 06:44 AM
