32" sceptre x322bv w/ psu mp116a
  • john98103
    • May 2011
    • 20
    My tv turns on and displays the brand name momentarily and then fades out and disappears; back lights stay on, on/off indicator light stays on and remains blue (this light is orange on standby). I have checked the voltages on the power supply; All the 24V pins are 23.3V. the 12V pin is 11.9V.
    Connector 2 has some voltages that deviate from expectation. in the second attached picture Con2 is at the far left (all stranded pink). I will list pin voltages left to right: 0, 0, 5, open, 4.5, 5, 5, 5, 0, open, open, open, 11.9. counting from left to right, pin 5 SHOULD be 5V and pin 9 should be 5v.
    Please advise as to what may be the problem.
  • john98103
    • May 2011
    • 20
    Re: 32" sceptre x322bv w/ psu mp116a
    looking on the back of the power supply I discovered what I'm calling pin 9 is actually labeled a ground not 5V; so now the only thing that seems to be wrong is pin 5, which is labeled PSON and has a voltage of 4.5. I've read that PSON is either 3.5V or 5V; I wonder if 4.5V is an issue.
      " All the 24V pins are 23.3V. the 12V pin is 11.9V" PS_ON is fine otherwise you will not have the 24v and the 12v.
      You need to check and see if the voltage to the T-CON board is present.
      Read my basic troubleshooting guide to get basic idea how LCD TV function.
      • amxman
        • Nov 2013
        • 21
        I too have a sceptre 32" tv that is not working. I'm unable to start a new thread yet so I'll just hang here for a few post's.
        My TV is X320BV-HD. The psu is also a Megmeet MP116 RVE:1.4 which makes me believe that my psu is a newer version than the one picture you posted, looks like yours is a 1.0.
        My TV powers up (blue light)to the startup screen and then clicks off, but when it does so the standby light is lit(red) unlike yours. After it shuts off a few moments later I hear another click... almost like a reset?
        I found two CAP's that show failure(bulge), at the row of 4 in a line. I'm planning on replacing all four in that line. They are close to that heat sink.
        Any thoughts? Again I do plan on starting a new thread but for some reason I'm unable to do so right now.
        • amxman
          • Nov 2013
          • 21
          Here is my thread, I think my problem is just a bit different.
          https://www.badcaps.net/forum/showthread.php?t=33144
          • BruceLeeRoy
            Sceptre x322bv No Backlight
            by BruceLeeRoy
            I have a Sceptre x322bv with no backlight, trying to find the pinout on the LED supply cn5 red wires have 12v and blue wires have 1.23v Does anyone know what voltages I should be getting on this connector?...
            10-24-2021, 02:00 PM
          • karatzdi
            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
            by karatzdi
            I know some might say... just buy another one. Sell it as parts..!
            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
            Spent some time downloading the Service...
            06-11-2024, 08:38 AM
          • Pinky Deepak
            Vizio M60-C3 Left Edge problem
            by Pinky Deepak
            I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
            Here's a video of both the issues: https://youtu.be/hMqc760nB3o
            09-27-2024, 05:11 PM
          • armoured_smiler
            Panasonic Tx-40cx400b top left half screen not displaying correct
            by armoured_smiler
            Trying to work out if this is TFT problem or TCon issue.
            The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
            Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
            04-08-2024, 03:40 PM
          • Sik_6ty_Sixx
            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
            by Sik_6ty_Sixx
            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
            02-18-2025, 05:06 AM
