Sony KDL-40V4100 inverted picture
  • tibimakai
    • Jan 2012
    • 3680
    Last night, I have picked up this TV and I was told by the owner that a technician told him, that the mainboard is the issue.
    I think the same thing, but I would like to ask you too, since I have never had this problem before.
    I haven't opened up the TV yet.
    I have did a basic TV reset, with arrow up and power button, which didn't help.
    I have tried changing picture settings, again did not help(doesn't have contrast).
    I have tried to download the newest firmware, thinking that maybe it would fix the problem, but with the TV's serial number did not show any available firmware.
    I have tried switching two numbers in the serial number and I have managed to get the firmware, but I'm hesitant about using it. It is wise to flash it?
    Any input would be appreciated.
    Re: Sony KDL-40V4100 inverted picture
    I am pretty sure this is an LVDS setting problem. The format is set wrong. Are there any options in the service menu for LVDS modes or formats?
    • tibimakai
      • Jan 2012
      • 3680
      I haven't played with the service settings yet, when I get home I will look at the pdf and I will play with it.
      I never worked on a Sony service settings yet, only Samsung.
      • tw2005
        • Oct 2011
        • 6458
        That looks so much like this chinese cheapie i had which had corrupted eeprom data. I thought I'd share an example where it was a mainboard issue.
        https://www.badcaps.net/forum/showth...&highlight=mvm
        I did a reset within the service menu,fixed, but for Sony I have no idea if that's an option , never touched one.
        Here's some photos from back then, last is the fixed result
        • tibimakai
          • Jan 2012
          • 3680
          I managed to get into the service menu, but I'm stuck there.
          I don't know what to do there.
          Samsung is so much easier to use.
          I'm looking at the SM, but it's very limited on what can be done there and how to do it.
          Any help would be appreciated.
            Pictures of service menu?
            • tw2005
              • Oct 2011
              • 6458
              Copy of manual
              • tibimakai
                • Jan 2012
                • 3680
                Thank you, but I have this manual already and there is some very basic information.
                To me, is useless.
                Tom, I will take a picture with the menu in a couple of minutes.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Here it is:
                    Tried this?
                    While holding down (UP ARROW) the on the Remote Commander, press the
                    POWER button on the Front Panel of the set.
                    The set restarts and displays the initial setup screen. This may take
                    several minutes.
                    • kevinm34232
                      • May 2012
                      • 1884
                      This looks like it could be a bad AS15 chip on the T-Con board, check your board to see if it has this chip or give us some pics.
                        I would be surprised if the gamma IC would distort colours?
                        • kevinm34232
                          • May 2012
                          • 1884
                          Usually with a bad AS15 if you turn the contrast way down the pic will get better but not all the way. I've done about 6 of these in the last couple months and the picture varied on each but usually looks inverted or animated, yours looks pretty severe..
                            Usually the colours are good though. IMO, it looks more like the data format is wrong, like it is getting 10 bit data instead of 8 bit data or something like that.
                            • kevinm34232
                              • May 2012
                              • 1884
                              This is a Samsung I just picked up yesterday, suspecting the AS15-F chip. I had one before that had similar problem but was just a loose LVDS cable. Does this look similar to yours or no?
                                My Insignia that I try to fix turns out to be bad T-CON due to bad AIS15 IC.
                                https://www.badcaps.net/forum/showth...+NS-LTDVD32-09
                                I have spare T-CON so I did not replace the IC.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  Just replaced the AS15-F chip and that fixed this one.. It seems they are all set to go bad around this time of year
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Sorry guys, yesterday I was at the beach.
                                    On my way there I have picked up a nice 46" Samsung LED/smart TV.
                                    Keeps clicking, no backlight, no error code from the LED(it's just on).
                                    I will start another thread with this TV.
                                    Today, if I will have some time, I will open up this TV to see the LVDS cable if it's seated properly and I will check that IC on the T-con board.
                                    Thank you all for the help, I appreciate it a lot.
                                    Tom, I have did that reset, but did not do anything.
                                    I was hoping to find something in the service menu, some other reset option, but I don't know how to use that menu.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      LVDS cable cleaning and re-installing didn't to anything.
                                      I have the same IC on the T-con board.
                                      So you guys are saying that IC causing this symptom?
                                      There is a good source for these ICs?
                                      That will be a bit of a challenge re-soldering it, but I think that I will have to practice with my hot air station, on how to solder with it. I have done it only once.
                                        It's worth a shot, but I'm going to say I don't think it's the fault. I can't think of a way the gamma IC can cause the colour to change, especially in such sudden increments. I still haven't found any info on how to change panel settings in the service menu though.
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
                                        • joby91
                                          SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                          by joby91
                                          I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                          I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                          I found one chat about firmware on ************** forum but i cannot read the comments.
                                          https://**************/forum/108-114100-1#880537
                                          09-04-2024, 01:34 PM
                                        • tree5656
                                          diagnosing sony XBR-75X900H. NO PICTURE
                                          by tree5656
                                          This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
                                          11-09-2023, 04:55 PM
                                        • jason123
                                          Sony Firmware for XBR-70X850B
                                          by jason123
                                          Hello
                                          Help is much appreciated. I have a Sony XBR-70X850B with bad main board. I got a mainboard for it, but as you know I have to update the firmware on this TV for the main board to work.
                                          I went to the Sony website, and I can't seem to find the Firmware file. Sony is no longer making this available.
                                          Does any of you have firmware / software files for this TV that I can put on USB for update to make this main board work?
                                          Much appreciated.
                                          05-17-2022, 12:42 PM
