Samsung LNS3251DA won’t power on, no sound, no standby light-power board problems
  • cspiddler
    • Aug 2011
    • 15
    When the power cord is plugged in, the standby LED flashes once and goes out. The set does not power up. This model uses power board BN96-03775A. To provide a search reference for others with similar problems, this power board is also listed for models LNS3251D, LNS3251DX, LN32B530FXZA, LN40B530FXZA, LN3241D, LN3241DC, LN3241DX, LNS3238DX, LE32S73BDX, LES3251D, LES3251DA, LES3251DX, LES3251D, LES3251DX. There is an “XXA” suffix after many of these models on a second tag on the back of the set.
    The power board appears to be the problem. With the main board disconnected, the only output voltage is 6.02 VDC at what appears to be one of the power-on pins. There is no 5.4, 12 or 13 volt output. On the inverter side, there is no 24 volt output. There is no voltage to any of the “cold” side components except for the single pin noted above. This power source comes directly from the “hot” side and is not associated with the transformer that feeds the other components. There was one swollen capacitor which I replaced, but did not fix the problem. Close examination with a magnifying glass showed no signs of excess heat or other damage. I could not find any cracked solder joints on the back side of the board. There is AC power to the board and voltage to all components on the “Hot” side. Jumpers and most components have an input voltage of ~78.5 VDC. A few pins that appear to feed the power-on circuit have “hot” side voltages in the 40-60 range and outputs to the “cold” side of 4 to 6.02 VDC.
    I could use a schematic, parts list, and some ideas of where to look next. Possibly the 5.4 VDC standby circuit might be out so the board won't start. I doubt the absence of the standby light has much meaning because the set could have died while powered up and the mainboard thinks it's powered on. Could be a bad transformer, but am hoping it's a fuse or diode-something easy to purchase locally. A few pictures are attached. Thanks for any help you can provide.
    Re: Samsung LNS3251DA won't power on, no sound, no standby light-power board problem
    To get a schematic, I need the "BN44" number, does this set have one?
    • awyatt2
      • Feb 2012
      • 407
      • america
      hav you checked the pico fuse located around the two large filter caps? had one of these a while back, if i remember correctly a diode close by shorted and blew the fuse. dont remember the number location by part number designation but it is close to the two large caps. thee set was totally dead as far as power light or turn on. dont remember but two fuses the agc one and the pico.
      • cspiddler
        • Aug 2011
        • 15
        Sorry, practically every component has a BN#, but didn't see anything starting with BN44. There is a model number, LN-S3251D A, and a model code, LNS3251DX/XXA. A second label on the back has the model code, serial number and a version number AM03. No stickers inside the case. Thanks for the quick response.
        • awyatt2
          • Feb 2012
          • 407
          • america
          just pulled my notes this is bn96-03775a power board. the a version uses one main cap . a brown rectangular fuse fd0025 near main cap and a pico fn831 near the detect pin plus the agc type so three fuses on the supply. i had to cross ref one a while back bridge shorted and blew traces the older one and newer one are 03755 nnd newer one the a rev.
            Got it.
            http://www.tgohome.com/ServiceManual...&Search=Submit
            • cspiddler
              • Aug 2011
              • 15
              Thanks, response has been amazing. Tom66, followed your link and got the schematic. Very helpful.
              Awyatt2, couldn't quite match the numbers you provided. Still no trouble finding the first two fuses. Both have full contenuity with zero resistance. The pico fuse was more of a problem. Thought they were small fuses that looked like resisters without the stripes. None of those on the board. I have no FN831 location. However, do have a location FM851 (see picture), Part actually looks like kinda like a ceramic capacitor, and board shows a resister symbol, but checked DigKey and they had some similar pico fuses. Multimeter shows contenuity with zero ohms. Location is as you described. So looks like the fuses are OK. Will start checking diodes in the morning and post the results. Would appreciate any additional thoughts.
                That does look like a pico fuse to me too.
                  That looks like auto-resettable fuse
                    Good point, it is probably a PTC fuse. Pico fuse is permanent blow for through hole, but often auto-reset for SMD. Go figure.
                      Since this board does not have built-in pull up resistor for the ON/OFF pin, he needs to use 1K resistor between ON/OFF PIN1 CNM801, and PIN2 (6VSTBY) CNM801.
                      Also "There is AC power to the board and voltage to all components on the “Hot” side. Jumpers and most components have an input voltage of ~78.5 VDC. A few pins that appear to feed the power-on circuit have “hot” side voltages in the 40-60 range and outputs to the “cold” side of 4 to 6.02 VDC. "
                      That means you are not using correct ground ref point when measuring the DC voltages on the HOT side, you need to use the neagtive leg of the Capacitor CP812 as your ground ref. The secondary side use the chassis as the ground ref.
                      The voltage on CP812 should go up from 170VDC to around 380vdc (PFC kicks on) when the ON/OFF signal is applied.
                      Please see components to be checked in red circles.
                      • Xmaster722
                        • Jan 2015
                        • 2
                        • Usa
                        Hi: i have a BN96-03057A power supply dead in my LN-S3251D Samsung tv. Found a bad capacitor, one Zener and an opticoupler. Need information of opticoupler and service manual of power supply unit. Working blind here with circuit. Thanks in advance for any help.
                          @Xmaster722, see PDF (provided by tom66).
                          • Xmaster722
                            • Jan 2015
                            • 2
                            • Usa
                            Thanks budm for your help.
                            • 5thgear
                              • Nov 2015
                              • 2
                              • Republic of USA
                              My Samsung LS-S3251D would not power on due to failing capacitors on the power supply. Failing capacitor location numbers were CM858, CM860, CM861, CS852, CS802. My TV works great after replacing all of these.
                              • Shane711
                                • Dec 2014
                                • 493
                                I was working on a Samsung LNS3251DX today. I found the power supply to be at fault. Right away I noticed four bad capacitors so I changed those out. But still no power. After extensive testing of the board I noticed a popped resistor RM801. My Power Board is BN96-03057A. I cut the resistor and tested for ohms but it was an open circuit no matter what. The value is 0.22 Ohms. Tested all the fuses to be good. So I ordered some replacement resistors and I think the TV will be up and running when I change that out.
                                  That is the fusible resistor so more likely you have have shorted IC 801S, or cap CM801. You also need to check RM803 to see if it also goes open circuit or not, something is drawing too much current.
                                  • Shane711
                                    • Dec 2014
                                    • 493
                                    You did it again budm. You are right. You sure do know your stuff. Well I tested everything you said and found RM803 to be shorted. 00.0 Ohms and it says R2K so I am pretty sure that means 2000 Ohms and not 0. Now the only problem is finding a replacement
                                    • Shane711
                                      • Dec 2014
                                      • 493
                                      I guess I can use any ceramic resistor that is 2K Ohms and 5W to 10W. Correct me if I am wrong.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        It's unusual for resistors to go short circuit. Open circuit is the norm.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
