Philips 42PFL7422D/37 is dead
  • tibimakai
    • Jan 2012
    • 3680
    Yesterday, I had a couple of minutes and I looked at this TV and it's a weird one, never had one of these and I'm lost.
    It's the one with a small power supply on the main board.
    No light, no clicks nothing.
    I have measured the bridge and nothing comes out of it(0.056V). Input is 120V.
    I have removed it to be able to measure it and it checks out OK. That is weird.
    Fuses are OK on PS and on the main board PS also.
    The main caps( there are 4 of them) measure 0V. The connectors on the boards are those that are all covered and it's no way that I can measure the voltages this way. I will have to somehow raise the boards to be able to measure them from underneath.
    I have took some pictures, but those I can only provide later when I'm home.
    At this point I'm looking for opinions, where to start.
    Re: Philips 42PFL7422D/37 is dead
    Possible a relay or open fuse?
    • tibimakai
      • Jan 2012
      • 3680
      I don't understand how does this PS works with relay and a secondary PS on main board. I never even had a power supply with a relay yet.
        Relay is for inrush current limit (so it won't blow fuses or trip breakers) or for switching main PSU on or off.
        In the first case there's an NTC or resistor in series which limits the current. The TV can't run properly with this resistor so the relay shorts it after a short period of time and the TV works.
        In the second case the relay just turns the power off or on to part of the PSU.
        Sometimes the two are combined using two relays.
          I s there a chassis number pirnted on the model numbe label?
          http://elektrotanya.com/?q=showresul...oria=&kat2=all
          • tibimakai
            • Jan 2012
            • 3680
            If I remember well is Q523-1ULA.
              OK, I did download the correct service manual then.
              • tibimakai
                • Jan 2012
                • 3680
                I have it too, but no time to really look into it. I have a 4 year old daughter
                  Can I see the picture of the board? I have two versions, one is power-inverter board combo, another version is just power supply.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    The inverters are on the side of the TV.
                    Soon I will be home and I will post them.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Here are the pictures:
                        Do you get anything on that large black cap on the main board, it should have 170VDC on it the minute you plug power cord into the outlet.
                        Also check R3318 to see if it is open.
                        • Dgtech
                          E. Technician
                          • Apr 2009
                          • 1462
                          • Steeler
                          Replace the bridge rectifier just to take a cheap stab at it. If it were shorted it would take out the main fuse. It may be open. Change it out and go from there. This problem shouldn't be too hard to find. There should be only a few components that power hits before the bridge schematically.
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            Famous last words?
                            • Dgtech
                              E. Technician
                              • Apr 2009
                              • 1462
                              • Steeler
                              Yeah , I hear ya. My boss is always saying stuff like, " Here. Do this job. It should only take you fifteen minutes." Two hours later, I'm pissed.
                              Here is a copy of the schematic from that PDF. As you can see here, theres a handful of components in the bridge rectifier section. That transformer could possibly need the leads reflowed. It may be open all toghether.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Bud, that resistor is good.
                                I had a bit of time and I have look at the TV.
                                I have noticed that one of the ~ pins of the rectifier goes to the relay. There is no 5V stby voltage and the relay doesn't kick in. This is the reason that I don't have any voltage at the main caps.
                                Now why I don't have the STBY voltage? Where is created this voltage. Next step is finding this issue.
                                  Th circuits as shown in post15 is the one you need to check, that is where the standby power supply is located, that is I ask you to check the voltage on the large cap of the MAIN board, not on the power supply board.
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    Am I missing anything? The problem states that he has 120 in to the power board's bridge rectifier and nothing coming out from the bridge rectifier. CHANGE THE RECTIFIER - or did you measure this wrong?
                                      I think he has been measuring the voltage on the bridge rectifier on the MAIN POWER SUPPLY board, the rectifier will not get get any AC feeding it until the relay is turn on by the main board. The standby power supply is on the Main board which creates the standby power for the main board (SSB), that is where he needs to check and see if the standby power supply is working or not.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        On the main board the capacitor measures 2.69V, but it reaches that very very slow. Goes up in tenths at a time. That is weird.
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Hi everyone,
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • kew1701
                                          Philips taw6205 ambilight speaker STM32 mcu dead
                                          by kew1701
                                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                          04-09-2025, 03:59 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
