Learn about LCD panel and T-CON board
    This will help explain what you see on the screen.
  • jkb242
    • Mar 2012
    • 175
    Re: Learn about LCD panel and T-CON board
    Budm, good information.
    Tried to find a replacement IC for the defective audio output of the Sharp I have been working--seems forever. The no sound issue is due to two IC's, a TA2024 and a AK4586VQ. The latter IC provides one L/R output for the monitor output which works fine and another L/R output for the power amplifier, to drive the speakers which doesn't work. The TA2025 power amp is also bad, voltages are too far off and when the monitor oitput is bridged to the input of the TA2024, there is no out.
    Can you advise if you know where I could find these parts. Neither Mouser or Digikey list either IC. Otherwise, will just install a generic audio stage and drive it from the monitor outputs and reconnect the internal speakers to this amp. former IC.
    • Mike95inNJ
      • Feb 2011
      • 18
      Thanks for this info. Very useful.
      Take care, MikeinNJ
      • retiredcaps
        • Apr 2010
        • 9271
        http://www.ebay.com/itm/110851974901
        http://www.findchips.com/avail?part=TA2024
        shows Quest has them in stock.
        --- begin sig file ---
        --- end sig file ---
        • advant
          by advant
          02-03-2020, 12:25 AM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
