Nintendo DS Lite
  • maybenever
    • Dec 2010
    • 158
    Nintendo DS Lite
    My granddaughter's DS game stopped working on the lower screen. It has a back light, and you can hear some sound, but no video. Got it apart and found a cap that looks bad. It is next to the data ribbon going to the lower screen. There's corrosion on the cap and the connection. I can't tell what this cap is other than C14. I can't find a diagram or parts list. I've not worked with anything this small. It appears to be a surface mount and half the size of a match head. Thanks for any help identifying this little devil.
    The second pic is the backside of the board, it's a pot, I found something on it in an older thread.
  • ComputerGeek
    • Oct 2011
    • 262
    Re: Nintendo DS Lite
    Just my 2cents but I would try a new screen before the capacitor. Did you also try reseating the connector?
    • maybenever
      • Dec 2010
      • 158
      No, I haven't tried to reseat cable yet. If I can't get this part identifyed, I will. It's not worth a new screen probably. Kids are pretty rough on these things. Found one on e-bay for $50, screen are $35.
      • Newbie2
        • Sep 2005
        • 885
        Parts for the DS Lite are a lot cheaper on Dealextreme from Hong Kong:
        NDS Lite lower screen - $7.40 USD: http://www.dealextreme.com/p/tft-lcd...er-screen-3175
        NDS touch screen module - $2.40 USD: http://www.dealextreme.com/p/touch-s...-nds-lite-3245
        Dealextreme has free shipping through Hongkong Post Airmail (or $1.70 for tracked airmail), however they can take 1-2 weeks to process and package your order before sending it off. Hongkong Post is very slow at sending items out of Hong Kong as well, so it might take around a month to get your order.
        I purchased the NDS Lite touch screen module before from Dealextreme to replace a scratched up one on a Nintendo DS Lite I was preparing to sell on Kijiji about two years ago, and it worked perfectly. If I remember correctly, you have to carefully peel the black plastic border from around the old module however without damaging it, and stick it on the new one before installing.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • maybenever
          • Dec 2010
          • 158
          Thanks for that info. Any idea how I can identify this cap? I don't think replacing the screen will do any good if I've got other problems.
          • ComputerGeek
            • Oct 2011
            • 262
            DO you have a meter that reads capacitance?
            • maybenever
              • Dec 2010
              • 158
              No I don't. But this one looks fried and shot, could I get a reading from it? I've looked the board over, and I don't see another C14.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                C14 is a multi-layer ceramic capacitor. These ceramic caps normally short out if they are bad. Measure the resistance across it with a multimeter. If it doesn't read less than 30 Ohms, it's probably fine. If it does read less, remove it and check it again out of circuit.
                If it is bad, normally I just find a junk board and pull one off that's the same size. So far, I haven't had a case where this doesn't work.
                Be careful with those ribbon cables and connectors - they are very easy to break! After opening a few of these DSs, I find them not worth my time to repair now.
                • maybenever
                  • Dec 2010
                  • 158
                  Thanks MONAKA, I'm going to clean this thing up now and do some checking. You're right, if too much is wrong, they are not worth the time, but I'm trying to learn. I used to be green, after months of reading and building test circuits, now I'm 'not so green'. A small step up a very tall latter. I love reading this forum, you guys are the best. I'll get back.
                  • maybenever
                    • Dec 2010
                    • 158
                    Update
                    I removed connector and cleaned everything up (cap C14 doesn't look so blown up now) put it back together & same results, no lower screen display. I probed around on that cap and got no readings, there are a couple of other tiny caps on that board, I got some readings from them. So now, I'll find a lookalike on an old board and try to replace it. This will be like tyring to solder under a flea's wing.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      Well, if its for a learning experience, then it is worth trying to fix it. Now I see that you actually mentioned this in post 1.
                      I doubt the problem is with any of the ceramic caps. The whole area around the connector looks like it has some corrosion/water damage to it. But perhaps, that's just how the picture came out.
                      Can you post a full picture of the board? There might be some fuses. I know the game card slot has quite a few of them.
                      Did you really remove the connector (as in desolder it) or did you just remove the ribbon cable from it? Also, how did you clean it and what did you use for the cleaning?
                      I would suggest cleanning the connector with 90% (or higher) alcohol. If you can, gently try cleaning the pins inside it as well. Like I mentioned earlier - BE VERY CAREFUL! Those connectors and ribbon cables are extremely fragile.
                      And for the sake of peace, do not take appart the upper screen. The connector for the upper screen runs in one of the hinges. It's made to rip if you excert even a tiny ammount of force on it. Very bad design IMO.
                      • maybenever
                        • Dec 2010
                        • 158
                        Yea, this is a learning experence. I learned this cap is too mirco sized to mess with. I took one off an old MB that was close to the size of that one. When I removed the one from the DS, that thing looked the size of a grain of sand, OOPS.
                        I did get the cap replaced, finally, but that wasn't the problem. After i got it off and looked at it under a 60x scope, it was clean. Gave me a bad feeling.
                        So, this one is bagged for future parts ( the kids have 5 of them in service )
                        Thank You for your time.
                        • b700029
                          Banned
                          • Sep 2010
                          • 640
                          If you plan to go on in electronics, either as a hobby or professionally, I suggest investing in a decent 'scope. With one you could determine if the signals are getting through to the screen or not.
                          • maybenever
                            • Dec 2010
                            • 158
                            What decent scope would you say is the best for the money?
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • reformatt
                              Macbook Air M2 A2681 Kernel panics after screen replacement
                              by reformatt
                              Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                              It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                              07-31-2025, 08:37 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • Tomylee
                              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                              by Tomylee
                              Hi everyone,
                              Sorry for the person who’s going to read all this !
                              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                              07-11-2025, 11:52 AM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
