42pfl7422d/37 help
  • afrelientk
    • Nov 2011
    • 20
    42pfl7422d/37 help
    I have a Philips 42 inch 42PFL7422D/37 that I got from a friend. He said one day it just stopped working. There is no sound or picture. The little blue light does come on once I connect it to power but thats it. Turned all the lights off and there was no picture. I did connect a USB to it to try a firmware update and it definitely did read my USB because the USB lights flickered but that didnt help. I have checked all of the capacitors and have found no damage. The 820UF 250V capacitors were slightly bulged but the X imprinted on it was not. I have checked all the chips on it to see if any of them were burnt out but I found no damage. I have pulled this LCD apart and have not found any visible damage. Can anyone offer any advise for this? Thanks!
    -Kyle
  • PlainBill
    • Feb 2009
    • 7034
    Re: 42pfl7422d/37 help
    Check the voltage out of the power supply. Does the PS_ON (or equivalent) signal change when the power button is pressed? These inverters have a long history of problems.
    PlainBill
    • afrelientk
      • Nov 2011
      • 20
      I checked the voltage on all of the boards and they are all recieving power. I am attaching pictures of the circuit board after I connect it to power. Should all of the lights come on (of the 5 light set) Only three out of the five are lit. Any other suggestions? Thanks for the help!
      • afrelientk
        • Nov 2011
        • 20
        Also when I hit the power button on the TV the light in the upper right left hand corner turns off then all of the lights turn off.
        • afrelientk
          • Nov 2011
          • 20
          Any help with this would be awesome
            There looks to be a relay on the PSU board. Do you hear any clicks when the TV power button is pressed?
            • afrelientk
              • Nov 2011
              • 20
              When I plug the TV in the lights come on then they click off about 20 seconds later. When I press the power button they come back on. When I press it again, it does click and all the lights go off again. Is that normal?
              • afrelientk
                • Nov 2011
                • 20
                PlainBill
                I checked the voltage going into the capacitors on each invertor board. They both were reading 051 on each capacitor. Is this a normal reading?
                  What range did you have your meter on?
                  Do you hear any sound if you plug in a device to one of the inputs, or use the antenna?
                  • afrelientk
                    • Nov 2011
                    • 20
                    500V was the range. When I connect my laptop to the computer via HDMI my laptop detects the television but I get no sound. When i press the source button on my remote I can tell the TV is cycling through the sources and on one source(not sure which one because no picture) there is alot of muffling coming out of the speakers. It is kinda strange.
                    • afrelientk
                      • Nov 2011
                      • 20
                      the muffling happens whether or not anything is connected to the television.
                        The muffling is a potential symptom, but it seems more likely the case of the TV has some effect on the sound, or the speakers or integrated amplifier is faulty. Either way, it's a problem to fix later - the main problem is the lack of picture.
                        Try the 50V or a lower range. Decrease the range until the reading reads "1 ." or "OL", then use the range above. 51V is very high for an inverter, although I've heard of 48V inverters.
                        Can you post a closer picture of the inverter, and around the connector and capacitors?
                        • afrelientk
                          • Nov 2011
                          • 20
                          I had the meter on V~ 200 this time(in the picture). I am kinda a nuub to ohmmeters.
                            You want to set it to "V=", not "V~". V~ is for AC (like out of the mains plug); V= is for DC, like out of a battery or going to an inverter.
                            I was hoping to see a voltage rating on those caps, unfortunately there is not (it's probably on the bottom.) You might have to unplug the inverter board and take pictures of the underneath. But before you do that, measure the voltage using DC instead of AC. To avoid any doubt, set the meter to the range I've highlighted.
                              As I am going to bed soon (11.30pm here), here are a few other checks you can perform.
                              Both tests should be performed with the TV off. It's very important that it's off or you could damage your meter.
                              For the red circled fuse: set your meter to the diode/beeper range (highlighted in red on the meter image). Touch the two probes of your meter together. If you hear a beep, that's good. Then touch the leads on the fuse. Hear a beep? If so the fuse is good.
                              For the blue circled pins. Test each separately. Set your meter to the "20000" ohms range, highlighted in blue. Test the resistance between the upper and lower pins. Record the result. Then, for the lower transformer, do the same. There should be very little difference between each measurement, if there is a difference, then one of the transformers is bad (usually the one with the highest resistance is bad); the good news is this is a cheap fix.
                              • electrodog
                                • Jul 2012
                                • 19
                                I'm a newbie, so I don't know if I'm posting this in the correct place, but here goes. I have a 42pfl7422d/37 no picture no sound. When I turn it on, the relay clicks, the blue power LED comes on but no picture or sound. After about 10 seconds the relay clicks again. Inside on the main board there are I think 2 blinking green LED's, one solid green, and looks like 2 that are not lit. When the relay clicks for the second time, all of the LED's go out. Then after about 20 seconds, the cycle starts over where the TV is trying to come back up, and just repeats, off, on, off, on. It is not the power supply, I replaced it, same problem. I normally don't like to shotgun troubleshoot, but I've been looking around on the internet for many hours and have not found a solution. The power supply only cost me $64. I just ordered the main board (SSB) for $59. For me, time is money, but if anyone can help it would be much appreciated. Thanks from a newbie.
                                  @electrodog, did you look real close at the two inverter boards to see if they have any damaged IC, fuses and MOSFET's on the Inverter boards since these boards are know to have blown IC and MOSFET's.
                                  They will require modification if they are not done also.
                                  • electrodog
                                    • Jul 2012
                                    • 19
                                    No, I have not gone that far removing the covers on the inverter boards, but can you tell me, will that cause the symptoms as I have described (no picture and no sound)? From what I have read so far, a bad inverter usually manisfests symptoms of no picture, but the audio is ok. Correct me if I am wrong, thanks.
                                      If the inverter board shorted out, it will cause the 24V (for backlights) and 12v (for sound) power supply to shutdown, the 12V and 24V power supplies are generated by the same circuits. Best thing to do when you try to fix anything is to do visual inspection first. There is no 100% sure what have gone out since more than one circuit can also cause the same symptom.
                                      • electrodog
                                        • Jul 2012
                                        • 19
                                        Yes, thankyou, I have done a visual inspection of the PS and main board looking for bad caps, burned components etc. As I mentioned, I haven't inspected the inverters, maybe while I'm waiting on my new main board, I'll check the inverter boards. Also, you provided me with an inverter modification II document. Should I assume this is something that needs to be done even if it is not the cause of my failure? What does the inverter mod fix? What is the failure mode that required this fix?
                                        • magik20
                                          Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
                                          by magik20
                                          Hi everyone,
                                          I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
                                          I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
                                          The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
                                          04-30-2025, 04:46 PM
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • An-klamm
                                          Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                                          by An-klamm
                                          Hello!
                                          I have a TV that I can't get any further with.
                                          It is a Samsung UE 55HU8590 with one connect box.
                                          When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                                          As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                                          Since the TV works without ocb, I assume that it can't be the PSU?!
                                          I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                                          Is there...
                                          12-04-2023, 01:35 AM
                                        • EazyBone
                                          Samsung The Frame TV no power indicator issues diagnosing the one connect box
                                          by EazyBone
                                          I got a qn65ls03ta from someone who stated shows no power at all. They said they bought a fully new tv (same one) and tested the one connect box from the old one onto the new one and said it worked.
                                          I have no reason not to believe them, so I crack open the TV and test for voltages on the main board. There are none. I can't get any voltage at all. (Power comes from one connect to Main board then sends power to additional power board for backlights I believe)
                                          While doing some digging I found the connection to the one connect cable ON the main board seems to be missing small...
                                          07-28-2024, 04:46 PM
                                        • jason123
                                          Samsung QN75QN95B with One Connect
                                          by jason123
                                          Hello all,
                                          I have a 75" QLED TV that I love. This morning ,as I'm watching a show, it shut off and no luck turning it on. Unplugged and waited an hour, and no activity. No clicking "On Relay" like it normally does.
                                          I see many have issues with the mammoth external one connect box. I was going to buy one, but used on eBay they're in the $300 range with no returns. Is there a way to know if it's TV or One Connect?
                                          11-15-2025, 11:45 AM
