Computer is slower after upgrading CPU
  • lti
    • May 2011
    • 2558
    I have been trying to upgrade a Compaq Presario 2286 to run software that only runs on a DOS-based version of Windows. The original Cyrix MII CPU was replaced with an AMD K6-2/500, which caused performance to decrease. The FSB and multiplier are set to the maximum supported by the motherboard (83MHz, 6x multiplier). I even reinstalled Windows and nothing improved.
    Is there a component on the motherboard that could have failed and caused such poor performance? I reinstalled the old CPU and the computer became even slower.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Computer is slower after upgrading CPU
    No, they're both just crap processors. Hunt down an Intel 233MMX, and give that a whirl. If you can find one, you won't have to pay more than a buck or two for it... That was the holy grail of the socket 7 realm. They are default @ 66 FSB, but with some good cooling, a good PSU, and good caps, they do have some decent overclocking potential. I've never seen one that wouldn't run @ 75MHz FSB (which POST's it at 266MHz), and would stomp any K6.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Wizard
      • Mar 2008
      • 2296
      Yes, I second the Topcat's What I also suggest is if board supports 100MHz with AGP slot at 66MHz, is find a *unlocked* 233mmx CPU and set it to 2.5 for 250MHz. I did that as a trial years ago.
      Cheers, Wizard
      • lti
        • May 2011
        • 2558
        I have a Pentium MMX 200 and its performance is the same as the factory 250MHz Cyrix. After installing the K6-2, every CPU I put into that motherboard gives much lower performance than it does in another board. The Cyrix is even slower now than it was before the attempted CPU upgrade. Before the "upgrade," the performance was similar to other computers with the same CPU.
        The motherboard has no AGP slot and only supports an 83MHz FSB. The board has two PCI slots and an empty location for an ISA slot.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Maybe the board doesn't have external cache installed. Back then, level 2 cache was on the motherboard not on the CPU. Check for unpopulated sockets. A processor without level 2 cache is very, very slow.
          A working TV? How boring!
          • lti
            • May 2011
            • 2558
            Why did it give good performance before upgrading the CPU and now it runs like shit? I can only guess that something has failed on the motherboard.
            There is a 256K cache chip on the motherboard.
            • mockingbird
              • Dec 2008
              • 5488
              I wouldn't run a K6-2/500 on a motherboard that wasn't designed for it. The VRMs on those motherboards are too weak to handle this chip. That's probably why it's not performing as fast as it should. In Integer applications, K6-2/500 would wipe the floor with anything in its class.
              • lti
                • May 2011
                • 2558
                It is slow even when underclocked, and all CPUs I have tried in the board since installing the K6-2 are slower than they should be.
                When I first installed that CPU, I had it underclocked to 400MHz. Setting the clock speed to 500MHz was only an attempt to make programs run slightly faster after it was discovered that the "faster" CPU was actually slower and the old CPU had lower performance than it did before.
                The board was designed to support a K6-2/400, even though the FSB won't go above 83MHz.
                • mockingbird
                  • Dec 2008
                  • 5488
                  Which board is it and which chipset does it use?
                  Did you install the chipset drivers?
                  • lti
                    • May 2011
                    • 2558
                    It is a custom motherboard, part number 387610-001. It has an SiS 5598 chipset. I reinstalled using the Compaq recovery CD, so it should have chipset drivers.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      excuse me, is this a serious conversation from 1999? have I walked into a time warp from my freshmen year in high school? hmm, no I don't feel my penis shrinking so I guess not.
                      dos performance issues and overlocking pentium MMX's? its 2011, and i'll freaking give you a damn pentium 3 slot motherboard with a 667 chip and we can be done with this. i'll even include a whopping 128M PC-133 stick, on the house
                      • lti
                        • May 2011
                        • 2558
                        I don't have the room for more computer junk.
                        If you think this is useless, you can name a virtual machine or emulator I can use to run all of my old software that will not run under Windows XP, even under compatibility mode. It must be a free program.
                        The performance issue has nothing to do with DOS. There is a fault with the motherboard.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16959
                          I was thinking the same thing actually.....but to each his own.... I know a gal still running a celeron 266, she will not upgrade.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            I knew a lady who was running a 486 /w windows 95 for years
                            she bought a compaq with an athlon 64 3500+ and she had it sitting in the corner of her room unopened for 4 years (included monitor) and printer
                            finally she called us to come install it and transfer her few pictures over
                            • lti
                              • May 2011
                              • 2558
                              I do have a newer computer. I have a lot of old software that won't run on a newer computer. Most of the programs are 3D games. Everything else has a newer version that works properly on a newer version of Windows.
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5045
                                • US
                                I would imagine you could run Dos without issues on like a pentium 3. this was way before AHCI and advanced hard drive features. that could create an issue
                                hell run it on a pentium 2. I have one of those too, used to run pfsense in a wireless -> Lan bridge for a friend of mine
                                • lti
                                  • May 2011
                                  • 2558
                                  I could, but I don't want to until I verify that there is no chance of getting this computer running properly.
                                  Also, I'm not using DOS. This computer is running Windows 98, which could run on a newer computer.
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    How much memory do you have in it ?
                                    I think the SiS 5598 chipset caches up to 128mb - anything over that will hit performance
                                    • lti
                                      • May 2011
                                      • 2558
                                      Really? This computer has always had at least 160MB of RAM, even before the CPU upgrade. It curently has 256MB. I never noticed a performance hit. I am currently experiencing a CPU/graphics performance issue. It doesn't seem to be related to memory.
                                      • lti
                                        • May 2011
                                        • 2558
                                        My reply seems to have disappeared.
                                        I am having an issue with the CPU/graphics performance. The computer always had 160MB of RAM in it until I installed the maximum 256MB of RAM that the motherboard supports. This was a long time before I tried to upgrade the CPU, and it always ran fine.
                                        Another problem is that the computer is slower every time I use it.
                                        Edit: Now my first reply shows up after I post this.
                                        • TuanTongbadcaps
                                          Change CPU multiplier through BIOS editing
                                          by TuanTongbadcaps
                                          Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                          07-22-2024, 07:57 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • kotel studios
                                          Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                          by kotel studios
                                          Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                          Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                          So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                          What I've tried so far:
                                          replace the original N-MOSFETs with beefier 60V ones for testing
                                          Resolder the resistors near the Vcore Jumper block
                                          Short Vcore...
                                          05-25-2025, 01:46 AM
                                        • eccerr0r
                                          AMD AthlonXP multipliers on old motherboards...
                                          by eccerr0r
                                          Is there a way I can get higher multipliers on old AMD motherboards?
                                          Was looking at an old socket A board that does not support AthlonXP's. It has a BIOS multiplier limit that's not quite high enough, which is fine for the old clock unlocked Athlons. What happens if I stick an AthlonXP that needs a higher multiplier?
                                          If I'm stuck at the highest BIOS set multiplier, is it possible to get a higher multiplier than the limit, or would it work like Intel boards that automagically use the chip locked multiplier regardless of what the BIOS is set?
                                          02-22-2021, 02:13 AM
                                        • GardevoirForEver
                                          Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                                          by GardevoirForEver
                                          I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                                          Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                                          The motherboard of my ASUS...
                                          11-15-2025, 04:30 PM
