Computer is slower after upgrading CPU
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #41
    Re: Computer is slower after upgrading CPU
    If there was something wrong in the clock generator the computer wouldn't have started.
    A working TV? How boring!
    • lti
      • May 2011
      • 2551
      I was thinking that it was still producing a clock signal, but a bad component caused the clock frequency to be lower than it should be.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        #43
        The BIOS reads the actual frequency of the CPU. If the POST screen reports the correct frequency then the CPU is running at that frequency.
        • Wizard
          • Mar 2008
          • 2296
          #44
          THe help is useless if one can't face the reality that mainboard is very poor on CPU support. Also the SiS chipset is not best at most with hardware support.
          I had problems with it, noisy audio, performance not best etc.
          The problem you have is not found in bios actually the hardware might had failed or bad documentation for the board. In the era of socket 7 boards were still setup with jumpers. By the way, the best I can get SiS to run is 75MHz FSB, 83 FSB resulted in dead PC.
          The PII 300-450 slot 1 on BX board or socket 370 board PIII 500MHz with one stick of 256MB SDRAM all on 815 chipset mainboard is much better and more reliable for DOS box and still have floppy drive. DOS era relied on floppies for installing software.
          PS: What the main reason you are keeping trying with the sick board? I had share of clock generator failures on socket 5,6,7 boards because these clock generator chips ran real hot. Literally hot that almost burned your finger. I did check with my scope and they were outputting off-frequency and many cases weak output even no output.
          Cheers, Wizard
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            DOS on Intel Chipsets runs fine up to the i815 chipset.
            AFAIK that was last chipset where Intel provided a DOS INF and drivers for the chipset integral video.
            Contrary to popular belief having more RAM in the box than DOS can cache doesn't give you a performance hit.
            [That idea was debunked years ago but unfortunately only after it was repeated a billion times in the Internet so the outdated info persists.]
            It simply doesn't -use- the extra RAM because it isn't mapped by DOS.
            Same idea as installing 8GB physically then running a 32-bit OS that can only map 4GB.
            Won't hurt, just won't get used.
            I know this is true.
            I have an i815 based DOS box running a 1.4GHz P-IIIS Tualatin.
            This board:
            http://oldweb.gigabyte.com.tw/products/6ieml.htm
            Lasted BIOS takes P-IIIS and drives over 137GB [48-bit addressing] with no mods/work-arounds needed.
            I have over 20 of that mobo left with various Cooler, CPU & RAM options.
            [Have crap caps but none bloated [yet]. Replacement caps would be included.]
            If anyone is interested let me know and I'll post an ad.
            Mann-Made Global Warming.
            - Dr Seuss
            • Agent24
              I see dead caps
              • Oct 2007
              • 4977
              • New Zealand
              #46
              Well what brands are the capacitors and are any bulging?
              -David VanHorn
              • mockingbird
                • Dec 2008
                • 5484
                #47
                Originally posted by lti
                Do any of those VMs and emulators support 3D graphics at a reasonable speed? I remember hearing that DOSbox emulated a Voodoo card, but it required a faster CPU than anything currently available.
                Yes! Virtualbox has better support for 3D than VMWare Workstation (And Workstation isn't free, you'll have to obtain it through "creative" means) but Virtualbox' floppy support was broken the last time I checked, though it worked perfectly in VMWare.
                If you *absolutely* need floppy support and want to use Virtualbox and not VMWare Workstation, then you can always copy the floppy as an ISO and then mount it as a virtual floppy in Virtualbox. Keep in mind, VirtualBox' 3D support has to be installed seperately.
                • lti
                  • May 2011
                  • 2551
                  I know the board sucks, but until I replace my laptop I won't have a computer fast enough to run any programs under an emulator or VM.
                  The BIOS does not display the frequency. It only displays the CPU type. Windows programs do display the frequency, and the frequency they show matches wgat the jumpers are set to. However, all software tools and the BIOS detect the CPU as a K6-2/400 and think the CPU is overclocked. There are no BIOS updates, so the only way to get the BIOS to detect the CPU properly is to extract the data from the ROM and modify it. The BIOS ROM might be a read-only chip.
                  The caps on the motherboard are I.Q brand, but none appear bad. I posted images of the PSU here.
                  The only Windows 9x disc that I have is the system recovery disc that came with this computer. I don't know how well that would work in Virtualbox.
                  • mockingbird
                    • Dec 2008
                    • 5484
                    #49
                    Should be fine in Virtualbox. Set it up and play around with it. It takes a little to get it working properly.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4977
                      • New Zealand
                      #50
                      I.Q. don't sound like they would be high quality, and Teapo, G-Luxon, Su'scon as you said are in your PSU aren't great either.
                      Perhaps you need a recap? If you don't have an ESR meter it might be worth it to make one - there are some pretty good and cheap designs posted on the forum.
                      Someone else posted this: http://kripton2035.free.fr/esr-repository.html which links to what look like some pretty nice designs...
                      -David VanHorn
                      • lti
                        • May 2011
                        • 2551
                        I tried running Virtualbox on my laptop and now Windows is completely screwed. Windows Media Player's color scheme has been changed to bright red and the optical drive won't read any discs. The disc takes an extremely long time to open in and Windows claims that the disc is not formatted properly. Everything worked perfectly before installing Virtualbox. Running System Restore and restoring to a point before installing Virtualbox did not change anything.
                        Now I have two broken computers.
                        • Wizard
                          • Mar 2008
                          • 2296
                          #52
                          This is why I'm so cautious on yes or no on dos emulators till forum know what your hardware is for notebook and the computer since OS emulators requirement is very severe.
                          Also when you said till you can replace the notebook instantly I was very concerned. That might had the underlying problem that caused the corruption. Even underspecified hardware can cause problems.
                          Time to start up the notebook in safe mode and get data backed up then reinstall the OS on the notebook. And rebuild a better DOS computer.
                          Did the notebook have problems for awhile that caused you to work on replacing it, do you? I was wondering.
                          Cheers, Wizard
                          • lti
                            • May 2011
                            • 2551
                            Virtualbox doesn't support Windows XP! The latest version worked until I tried to install Windows in the VM. Version 2.2.4 will not load and immediately gives me a message stating that the version of Windows I am using is not supported. Virtualbox seems to only work under Windows Vista and 7, and I don't have a computer that is capable of running either version of Windows.
                            The laptop has many hardware problems. The CPU runs extremely warm, the hard drive has almost 400 bad sectors, the display is very difficult to open and close, the optical drive will not burn a CD (the burn process succeeds with no error messages, but the disc is unreadable), the battery won't charge, the screen flickers unless I run the display at full brightness, and both the keyboard and touchpad have failed. It would cost less to buy a new computer than to repair the laptop, especially considering that the CPU has the performance of a 1.4GHz P4.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              #54
                              I don't know where you got 2.2.4 from because here it says that the latest version is 4.0.8. http://www.virtualbox.org/wiki/Downloads
                              For the compatibility thing it could just be a stupid bug, i find it really hard to believe that it won't work on XP anymore. I think you should do yourself a favor and toss that laptop.
                              • lti
                                • May 2011
                                • 2551
                                I tried the latest version as well.
                                If I get rid of the laptop, I lose the best computer I have. I am looking at buying a new computer soon.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4977
                                  • New Zealand
                                  #56
                                  Your screwed up media player settings sound like the kind of thing that can be caused by faulty RAM or a bad hard drive.
                                  I would run memtest86+ and check the HDD SMART with something like Speedfan or HDAT2
                                  Or it's possible the virtualbox software did it for fun...
                                  -David VanHorn
                                  • lti
                                    • May 2011
                                    • 2551
                                    The hard drive is bad in the laptop, but the memory is still good.
                                    Everything was fine until I installed Virtualbox.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4977
                                      • New Zealand
                                      #58
                                      Maybe it was the hard drive that caused the problem, could have done something to the registry.
                                      -David VanHorn
                                      • NxB
                                        • Feb 2009
                                        • 1595
                                        #59
                                        Did you try uninstalling it? Install latest version?
                                        With so many bad and slow sectors on your hard drive anything can happen. I've seen windows come up with no task bar, display glitches, registry corruption and all kinds of other mess from failing disks. 400 sectors is pretty far along into failed.
                                        You could get a desktop with better specs for next to nothing. If you really have no money for a PC go craigslist or dumpster dive. When I was broke and in this situation, I did the latter. Ironically it was right at the time that your dos mobo was still decent. I had a k62-450 and the celeron 500 out of the garbage kicked its ass.
                                        • lti
                                          • May 2011
                                          • 2551
                                          I could find a newer computer and run Windows 98 under a VM.
                                          I tried the latest version of Virtualbox and the first version that supported 3D acceleration. Both gave me messages stating that the program was not designed for Windows XP, but the latest version was able to open. When it tried to read the Windows 98 CD, I received a "Disk I/O Error" message. After that, no discs could be read in the optical drive.
                                          The problem with the Compaq is that all CPUs give poor performance, not just the K6-2.
                                          • TuanTongbadcaps
                                            Change CPU multiplier through BIOS editing
                                            by TuanTongbadcaps
                                            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                            07-22-2024, 07:57 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • kotel studios
                                            Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                            by kotel studios
                                            Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                            Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                            So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                            What I've tried so far:
                                            replace the original N-MOSFETs with beefier 60V ones for testing
                                            Resolder the resistors near the Vcore Jumper block
                                            Short Vcore...
                                            05-25-2025, 01:46 AM
                                          • eccerr0r
                                            AMD AthlonXP multipliers on old motherboards...
                                            by eccerr0r
                                            Is there a way I can get higher multipliers on old AMD motherboards?
                                            Was looking at an old socket A board that does not support AthlonXP's. It has a BIOS multiplier limit that's not quite high enough, which is fine for the old clock unlocked Athlons. What happens if I stick an AthlonXP that needs a higher multiplier?
                                            If I'm stuck at the highest BIOS set multiplier, is it possible to get a higher multiplier than the limit, or would it work like Intel boards that automagically use the chip locked multiplier regardless of what the BIOS is set?
                                            02-22-2021, 02:13 AM
                                          • _AcE_
                                            JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                            by _AcE_
                                            I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                            There's no physical damage...
                                            08-10-2025, 09:27 AM
