Computer is slower after upgrading CPU
  • Wizard
    • Mar 2008
    • 2296
    #61
    Re: Computer is slower after upgrading CPU
    A failing HD will absolutely corrupt anything and is NOT to be trusted, and time for DATA recovery NOW.
    Hot CPU will cause corruptions when it is on the edge of overheating this also affects internal chipsets and cause problems.
    In the nutshell, notebook have to be retired NOW. Boot into safe mode and save the data that you made (documents, bookmarks etc) Reinstall OS on your main computer and live with it for now till you get good quality notebook without nvidia chipset or nvidia video. AMD or Intel based chipset with AMD video chipset in a notebook is real good one and have to be brand name like Asus, Dell, any good brand (chime in with known good ones).
    Cheers, Wizard
    • lti
      • May 2011
      • 2551
      Everything is backed up, and the laptop is my main computer. I never even used it as a portable computer, so I am looking for a desktop computer to replace it and the Compaq. I have another laptop that doesn't have as many problems.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4974
        • New Zealand
        #63
        Surely all you need is a new hard drive for your laptop?
        You should be able to get it fairly cheap, maybe even free (try your local freecycle group)
        -David VanHorn
        • lti
          • May 2011
          • 2551
          Look at my earlier posts. This laptop has so many problems that it would be cheaper to buy a new computer than to repair it. It was made in 2002, and it was the bottom of the line when it was new.
          • Wizard
            • Mar 2008
            • 2296
            #65
            Iti,
            "I have another laptop that doesn't have as many problems."
            Still doesn't feel good about that myself personally. What is the problems with this one? Might able to help us to suggest fixes to help with remaining notebook.
            Cheers, Wizard
            • lti
              • May 2011
              • 2551
              The plastic case keeps cracking and chunks keep breaking off.
              • lti
                • May 2011
                • 2551
                I finally got Virtualbox working, but I don't have a Windows 98 CD. The Compaq system recovery CD would not install and just gave me a message saying that it can only be installed on a Compaq PC.
                I want to get this computer running so I can use it until I get a real Windows 98 CD. Today I noticed that the cache memory chip has a dark spot on it, but the chip doesn't get very warm. The clock generator chip is a W148H and doesn't get warm at all.
                I have posted three images of the board. The first is an identical board that does not work. Next, there is a picture of the cache memory chip. Finally, there is a picture of the clock generator circuit.
                I would like to get this board working. Reinstalling Windows did not help.
                • Wizard
                  • Mar 2008
                  • 2296
                  #68
                  That generator clock IC of this maker logo mark is a problem I had with many different boards that used it. Runs hot (some warmer some hot) than should be and signal and voltage quality fades away.
                  Better to find a good socket 7 (dual voltage, switching regulators) based on HX chipset someday.
                  Cheers, Wizard
                  • lti
                    • May 2011
                    • 2551
                    I was thinking that was the problem. The computer keeps getting slower every time I use it, and it was doing this before I tried to upgrade the CPU. The extra clock speed of the K6-2 must have stressed the clock generator and caused it to produce a bad clock signal. I can't find any information about the chip, and I don't have the skills to swap the chip with the other board. That chip might be bad on the old board as well.
                    None of the chips on the board are very warm. The clock generator is only slightly above room temperature.
                    I would like to know how Compaq managed to run the SiS 5598 chipset on an 83MHz FSB.
                    There are way too many design flaws on this board, just like everything Compaq makes. I had to modify the board to get sound to come from the built-in amplifier at a reasonable volume. I had to turn all the volume controls in Windows all the way up and put my ear against the speaker to hear anything. Now the amp might be the only properly working portion of the motherboard. If they couldn't get a simple audio amp right, what did they mess up on the rest of the board?
                    I just need Windows 98 to run old software and support my old Zip drive in case I need to open files from a Zip disk. My second laptop (not the one with the bad hard drive) has Windows 98 on it and has a parallel port, so the Zip drive will work fine on it. It is not fast enough to run some of my games, but if I get a Windows 98 CD I can run those games in VirtualBox on a new computer.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4974
                      • New Zealand
                      #70
                      Probably not a design issue, probably just broken like the clock generator.
                      If you need a new board, you can probably get one on eBay for $1 or for free: just ask someone nicely or check your local freecycle group... in fact you can probably get something even better like a P4 or Atlhon XP for free if you look around.
                      -David VanHorn
                      • lti
                        • May 2011
                        • 2551
                        The amp wasn't broken. The board designer left out two resistors and had direct connections instead. After cutting the traces and putting resistors across the cuts, the amp worked properly.
                        I won't need this computer when I buy a new one that is capable of running VirtualBox properly and find a Windows 98 CD.
                        • Wizard
                          • Mar 2008
                          • 2296
                          #72
                          This SiS on yours chipset were specificed to run up to 83MHz. True on one of ASUS boards with this chipset and were good boards and sold by large numbers but not great on performance-wise but it is enough for public.
                          If was 386 or 486 Asus boards with 461 or 471 SiS chipsets they were lightning fast. I had a generic board with 460 SiS that was no trouble that took 486 and used a AMD 486DX 40, overclocked to direct 50MHz and STB Tseng ET4000w/p VLB card. Great machine for Doom gaming.
                          Cheers, Wizard
                          • lti
                            • May 2011
                            • 2551
                            I decreased the RAM to 128MB and the POS is faster! I didn't think the performance drop would be big enough to notice. It will probably be slow again the next time I use it, but it is running better today. It can almost keep up with my old Gateway Solo 2500 laptop with a 333MHz PII and the worst video chip I have ever seen.
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              Now to convince you to download disk diagnostics from the manufacturer of the HDD that's in it, and run their drive verification tool as well
                              better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4974
                                • New Zealand
                                #75
                                I'd recommend HDAT2, it runs on all drives and is better than most manufacturer's tools for testing (doesn't ignore SMART errors and actually tells you things, unlike Seatools which will pass a drive as OK even if it has 400 reallocated sectors, because the threshold is 500 for example)
                                -David VanHorn
                                • lti
                                  • May 2011
                                  • 2551
                                  I should try a diagnostic tool. I would also like a SMART monitor that can run under Windows. This computer has a Seagate hard drive.
                                  I'm downloading HDAT2 now.
                                  • lti
                                    • May 2011
                                    • 2551
                                    I can't get the computer to boot from an HDAT2 disk. I just get a "Non-system disk or disk error" message.
                                    • lti
                                      • May 2011
                                      • 2551
                                      I got HDAT2 to load by booting from a Windows 98 boot disk, replacing the disk with the HDAT2 disk, and then loading HDAT2. What should I look for?
                                      • lti
                                        • May 2011
                                        • 2551
                                        The only test I could find looked for bad sectors and there were none. I have attached the SMART log. The read and seek error rates seem unusually high. Also, there are zero reallocated sectors, but that attribute is listed as "pre-failure."
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4974
                                          • New Zealand
                                          #80
                                          It's listed as Pre-failure because it means that the attribute is linked to predicting failures. (high numbers of reallocated sectors means the drive is failing)
                                          Some are linked to old-age, like 'power on hours' etc
                                          Seagates always show apparently high numbers for seek and raw read error rates in raw data, this isn't necessarily a cause for concern.
                                          If you want something that can check SMART within Windows, I suggest Speedfan. It also has an online tool for analyzing your SMART logs, which can probably interpret them better than I can, especially the error rate values.
                                          All up though, at least going by SMART, your drive seems pretty good...
                                          Is DMA enabled for your HDD in Windows and BIOS?
                                          -David VanHorn
                                          • TuanTongbadcaps
                                            Change CPU multiplier through BIOS editing
                                            by TuanTongbadcaps
                                            Is there a way to change the CPU multiplier through editing the laptop's BIOS. I have a Latitude 7300 using Intel core I7-8665U CPU which has default multiplier settings between x4.0-x48.0. The problem with the device is that as soon as Windows boots up, the processor temperature is always high (usually in the range of 97-100 degrees Celsius), the multiplier is in the range of x46.0 - x48.0 even though no applications enabled. On a desktop we can change many things related to core voltage, multiplier or base frequency. but on laptop models using U suffix processors this is not available. I would...
                                            07-22-2024, 07:57 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • kotel studios
                                            Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                                            by kotel studios
                                            Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                                            Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                                            So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                                            What I've tried so far:
                                            replace the original N-MOSFETs with beefier 60V ones for testing
                                            Resolder the resistors near the Vcore Jumper block
                                            Short Vcore...
                                            05-25-2025, 01:46 AM
                                          • eccerr0r
                                            AMD AthlonXP multipliers on old motherboards...
                                            by eccerr0r
                                            Is there a way I can get higher multipliers on old AMD motherboards?
                                            Was looking at an old socket A board that does not support AthlonXP's. It has a BIOS multiplier limit that's not quite high enough, which is fine for the old clock unlocked Athlons. What happens if I stick an AthlonXP that needs a higher multiplier?
                                            If I'm stuck at the highest BIOS set multiplier, is it possible to get a higher multiplier than the limit, or would it work like Intel boards that automagically use the chip locked multiplier regardless of what the BIOS is set?
                                            02-22-2021, 02:13 AM
                                          • _AcE_
                                            JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
                                            by _AcE_
                                            I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
                                            There's no physical damage...
                                            08-10-2025, 09:27 AM
