Toshiba P855 only works with battery
  • zioricci
    • Jan 2023
    • 125
    • Italy
    I have a Toshiba satellite P855 that was previously stuck on the Toshiba logo and I couldn't enter the BIOS with F2 and then, thanks to the 2 original bios files that hardware1 gave me, yesterday I was able to boot it up to Windows 11. I deduced that the fault was the corrupted bios. So all the hardware works, hard drive, graphics card, RAM etc. The problem is that everything works if I power it with only the main battery, as soon as I take it out and put the charging cable in, the laptop, although it always succeeds entering bios with F2, hangs on Toshiba logo. I tried doing the CMOS reset but nothing changed, I tried putting a discharged main battery that can no longer be recharged, thinking that the battery was the go-between, and after the Toshiba logo I get a row of pixels at the top of the screen and nothing more. Here, these are the symptoms, so in summary ... with the main battery Windows starts and all the hardware works, while with the cable the laptop does not even finish the POST phase. What can it be ?
    Thanks you
  • mon2
    • Dec 2019
    • 14551
    Re: Toshiba P855 only works with battery
    See attached.
    Attach the official power adapter. For now, disconnect the battery.
    Meter in DC volts (20V or higher is ok) mode.
    Carefully measure the voltage to ground of the charger IC pins of interest.
    Start with:
    ACN
    ACP
    ACDRV
    REGN
    VCC
    ACOK
    Post each measurement.
    • zioricci
      • Jan 2023
      • 125
      • Italy
      Originally posted by mon2
      See attached.
      Start with:
      ACN
      ACP
      ACDRV
      REGN
      VCC
      ACOK
      Voltage power adapter 19.30 V
      ACN 18.50 V
      ACP 18.50 V
      ACDRV 24.23 V
      REGN 6.08 V
      VCC 18.16 V
      ACOK 3.35 V
      Edit:
      I want to try again, it doesn't add up that ACP and ACN have the same voltage
      With Power Adapter 20.06 V no load, the exact values are as follows:
      ACN 19.85 V
      ACP 19.86 V
      ACDRV 25.66 V
      REGN 5.88 V
      VCC 19.64 V
      ACOK 3.36 V
      • mon2
        • Dec 2019
        • 14551
        These are all good readings.
        ACN should be very close / equal to ACP. This is the voltage going IN and OUT of a local current sense resistor. The charger IC will monitor BOTH pins and measure the very small voltage drop to gauge the current consumption of this power rail.
        With the posted details, the ACDRV pin is being boosted OK to ~25 volts so the 2 x DCin mosfets are being enabled.
        The next suggestion is to proceed to measure all of the pins on this charger IC. This is to review what exactly the charger IC is reading when the power adapter is mated to the logic board.
        Post the list with the pin numbers of the charger IC for a review.
        • zioricci
          • Jan 2023
          • 125
          • Italy
          ACN 19.85 V
          ACP 19.86 V
          ACDRV 25.66 V
          REGN 5.88 V
          VCC 19.64 V
          ACOK 3.36 V
          on the other pins the values are
          3 = 19.86 V
          6 = 3.36 V
          7 = 0.22 V
          8 = 3.36 V
          9 = 3.36 V
          10 = 0.67 V
          11 = 3.16 V
          12 = 3.16 V
          13 = 3.16 V
          14 = 0 V
          15 = 0 V
          17 = 5.89 V
          18 = 3.16 V
          19 = 3.16 V
          • mon2
            • Dec 2019
            • 14551
            Need to run but at a quick glance - looks good on the charger IC. Remove all power and review the many threads in this forum re: shorted mosfets. Read the thread by @Piernov above on charger ICs.
            In summary, there must be a leaky mosfet that is fighting between the main DCin power path and the battery mosfet.
            Often, the 2nd DCin mosfet driven by the ACDRV signal is leaky. You can confirm this condition by checking the resistance of each mosfet.
            Check:
            source & drain
            source & gate
            gate & drain
            Checking for a low resistance which on a mosfet is bad. Often will be a defective component.
            Remove all power / battery and then check the resistance of each mosfet that is surrounding the charger IC.
            Download the charger IC datasheet and review a typical configuration of how TI wants the engineer to apply the chip. Yours will be 99.999% the same.
            Post the measurements...
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Does it have NEC-TOKIN type capacitor in cpu vrm circuit?
              • zioricci
                • Jan 2023
                • 125
                • Italy
                If you're referring to this genre,
                no it doesn't have it and if you ask It me about the row of pixels, it's gone for the moment. In this regard I would like to ask a question: did it disappear because I changed from CSM boot to UEFI or because I soldered some choke coils
                that were missing on the hdmi port?
                • zioricci
                  • Jan 2023
                  • 125
                  • Italy
                  Check:
                  source & drain
                  source & gate
                  gate & drain
                  The ACDRV is the gate of PQ204 and do you think it could be the mosfet that could create this problem? When I had measured it with the multimeter it was not shorted and I also had the threshold voltage by reversing the test leads. However, I will repeat in a while the measures you mention. Thanks for your help
                  • mon2
                    • Dec 2019
                    • 14551
                    Remove all power. Meter in resistance mode.
                    Check the resistance of the high side mosfet at PQ201.
                    Also check the same detail of the battery mosfet at pq205.
                    Post each list of measurements.
                    Source (1-2-3) & drain (5-6-7-8)
                    Source (1-2-3) & gate (4)
                    Gate (4) & drain (5-6-7-8)
                    • zioricci
                      • Jan 2023
                      • 125
                      • Italy
                      For pq201, in diode mode, no short and the threshold is there, 0.51 V
                      in resistance mode:
                      Source-drain : 8Mohm
                      Source-gate: infinite
                      Gate-drain : infinite
                      For pq205, in diode mode, no short and the threshold is there, 0.52 V
                      in resistance mode:
                      Source-drain : infinite
                      • mon2
                        • Dec 2019
                        • 14551
                        Is the battery attached or disconnected?
                        When you checked the charger IC pins, was the battery connected or disconnected?
                        What is voltage to ground of the battery?
                        • zioricci
                          • Jan 2023
                          • 125
                          • Italy
                          I removed all power supplies as you told me to do, I also removed the RTC.
                          disconnected
                          0V. Are you asking me for some short/leakage current ?
                          • mon2
                            • Dec 2019
                            • 14551
                            Does the removed battery have enough charge to power the logic board?
                            If yes, remove the adapter and connect the battery.
                            Then power on and measure the charger IC pins again.
                            Measure at the charger pins so we can review exactly what the charger IC is reading.
                            Also interested in the voltage to ground readings of the DCin mosfets while powering with the battery only.
                            • zioricci
                              • Jan 2023
                              • 125
                              • Italy
                              ADAPTER ----------->BATTERY (11.10 V)
                              ACN 19.85 V------>10.99
                              ACP 19.86 V------>10.97
                              ACDRV 25.66 V------>25.66
                              REGN 5.88 V------>0
                              VCC 19.64 V------>10.5
                              ACOK 3.36 V------>0
                              3 = 19.86 V------>0.02
                              6 = 3.36 V ------>0
                              7 = 0.22 V------>0
                              8 = 3.36 V ------>3.32
                              9 = 3.36 V ------>3.32
                              10 = 0.67 V------>0.67
                              11 = 3,16 V------>16.98
                              12 = 3,16 V ------>10.8
                              13 = 3,16 V------>10.8
                              14 = 0 V------> 0
                              15 = 0 V------> 0
                              17 = 5,89 V ------>10.40
                              18 = 3,16 V------>10.65
                              19 = 3,16 V------>10.65
                              PQ204 drain 11.08 V
                              PQ203 all 0V
                              • zioricci
                                • Jan 2023
                                • 125
                                • Italy
                                I put the arrows to separate otherwise attacked everything
                                • mon2
                                  • Dec 2019
                                  • 14551
                                  To confirm, the LEFT side of the table is with the ADAPTER ONLY.
                                  Right side of the table is with the BATTERY ONLY?
                                  ACDRV remains @ ~25v with only the battery connected?
                                  • zioricci
                                    • Jan 2023
                                    • 125
                                    • Italy
                                    yes
                                    yes, left side adapter only and right side battery only
                                    my mistake, ACDRV with battery only is 0V
                                    • zioricci
                                      • Jan 2023
                                      • 125
                                      • Italy
                                      Today I noticed that the battery usually reaches more than 12V, now it's 11.16V but the charge indicator is off and not charging even though windows says it's 100% charged, while with a completely empty battery the indicator turns on.
                                      • zioricci
                                        • Jan 2023
                                        • 125
                                        • Italy
                                        Now it's loading... I'm writing from Toshiba but powered by battery, with the adapter acting as a charger and not as a power supply
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • bykanovm
                                          Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                          by bykanovm
                                          Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                          If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                          If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                          even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                          Also, the laptop does not turn on without...
                                          04-02-2025, 02:45 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • ZixuTech
                                          Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                                          by ZixuTech
                                          Hi Guys, a weird case here.
                                          This laptop came with damaged hinges, but no liquid signs.
                                          It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                                          I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                                          I have replaced bq24780S battery charging chip, no difference.
                                          With a connected new battery,...
                                          04-03-2022, 04:03 AM
                                          ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                                          The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                                          configurable for operating as either a Hybrid Power Boost (HPB)
                                          charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                                          4-cell batteries. Both configurations allow the battery to work with
                                          the adapter together to supply the system load when it exceeds
                                          the adapter capability, referred to as system Turbo mode. HPB
                                          charger configuration reverse-boosts battery energy to the system
                                          bus to help the adapter provide the system power in Turbo mode.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
