Toshiba P855 only works with battery
  • mon2
    • 14685
    Re: Toshiba P855 only works with battery
    Ok. So the battery is charging? Is there a fault?
    Does the unit operate with only the adapter?
    • zioricci
      • Jan 2023
      • 125
      • Italy
      on the contrary, as I wrote in the title, it only works with the battery and not with the adapter
      • zioricci
        • Jan 2023
        • 125
        • Italy
        While hunting for shorts in the vicinity of the IC charger, I found this capacitor circled in green on the figure with a resistance of 0.4 Ohm...maybe a little low in value. Could this value explain the exclusion of the adapter as a power source?
        • mon2
          • 14685
          It is ok since you are measuring the resistance of pr225 which is a low value current sense resistor.
          • zioricci
            • Jan 2023
            • 125
            • Italy
            I read @Piernov's trhead, very interesting and as he suggests I also measured the resistance connected to the CMSRC output and it's ok, the mosfets are all ok... as an electronics hobbyist though to think that the adapter doesn't deliver enough current but I tried 3 of them and the current comes out in abundance.
            Is there something that prevents the adapter from not having priority when connected together with the battery.
            • mon2
              • 14685
              Remove all power. Meter in lowest resistance scale.
              Measure the resistance between the ACP and ACN pins directly at the charger IC. This is important to measure at the pins of the IC.
              Post the reading.
              • zioricci
                • Jan 2023
                • 125
                • Italy
                #27
                it is not stable, it fluctuates between 2.5 and 6 Ohm
                • mon2
                  • 14685
                  Post a close picture of this area. This is of concern.
                  Still with no power, measure the resistance from ACP pin to the one side of the current sense resistor. Is it stable?
                  Should be ~0 ohms and stable.
                  Repeat to test the pcb trace resistance from ACN to the other side of the current sense resistor. Same expected reading.
                  • zioricci
                    • Jan 2023
                    • 125
                    • Italy
                    #29
                    0.5 the first and 0.6 the second. Both stable.
                    But I realized that I have not removed the RTC cmos, does it change anything?
                    • zioricci
                      • Jan 2023
                      • 125
                      • Italy
                      #30
                      I enclose pictures of the internal BQ24725 taken from the datasheet
                      • mon2
                        • 14685
                        Remove the noted battery and test again. I do not believe it should change this measurement.
                        So to confirm, the reading that is not stable is when testing across the current sense resistor?
                        Test the resistance directly at the current sense resistor as well. Is it stable?
                        It is rare for current sense resistors to fail but that may be the issue for this case. Any sign of corrosion / liquid damage in this area?
                        You can try to flux and reflow this part but be careful to not apply heat to the LCD display. Often this resistor is under 1 ohm.
                        • zioricci
                          • Jan 2023
                          • 125
                          • Italy
                          #32
                          Correction, before I measured wrong maybe the tip didn't touch well and was unstable, now I'm sure that between pin 1 ACN and 2 ACP there are 0.8 Ohm stable
                          These 2 pins correspond to the two sides of the sensing resistance, if I measure directly on this resistor I find 0.2 Ohm, probably the extra 0.6 more will be due to the traces (?)
                          • zioricci
                            • Jan 2023
                            • 125
                            • Italy
                            #33
                            pcb photo
                            • zioricci
                              • Jan 2023
                              • 125
                              • Italy
                              #34
                              the PD202 zener diode that looks like it burst works, it's just dirty
                              • mon2
                                • 14685
                                Is PD202 with a chipped topside ?
                                Concerned about why there is a voltage @ BQ24725_LX when the battery is removed.
                                With the battery removed, PQ201 & PQ202 should be OFF so expecting 0v @ BQ24725_LX.
                                Suggest to remove PQ201 off the logic board.
                                • zioricci
                                  • Jan 2023
                                  • 125
                                  • Italy
                                  #36
                                  it wasn't chipped, a little flux a little more
                                  What voltage, at what point of BQ24 ?
                                  on the gates of the mosfet ?
                                  this operation worries me because I have already tried to remove some mosfets with hot air but I didn't want to insist because it seemed to me that too much time had passed and it would not come off-
                                  But by measuring I see that PQ201 with the red lead on the source and the black lead on the drain is open and on the contrary I have the threshold voltage of 0.51 V, can it be deceiving?
                                  • mon2
                                    • 14685
                                    See attached. The voltage @ PHASE pin #19 to me is of concern.
                                    This is the voltage created by both the high side mosfet (PQ201) and low side mosfet (PQ202) working together to lower the high adapter voltage that is fed into the drain pin cluster (5-6-7-8) of PQ201.
                                    When the adapter only is connected I would not expect a voltage to be present on pin #19 that monitors the lower voltage.
                                    For now, test the following ideas:
                                    Remove the 0 ohm resistor @ PR217. This will remove the gate voltage on PQ201.
                                    Then measure again the voltage to ground of BQ24725_LX. You can measure at the BATT+ battery connector pin. Do not have the battery connected.
                                    What voltage do you read now ?
                                    In summary, we want to disable PQ201 from the circuit.
                                    • zioricci
                                      • Jan 2023
                                      • 125
                                      • Italy
                                      #38
                                      ok i'll try now
                                      • zioricci
                                        • Jan 2023
                                        • 125
                                        • Italy
                                        #39
                                        I wanted to let you know that having also the motherboard of the P850, identical to this one, also on this one the voltage is the same, that is 3.08 V, when there is only the adapter, the same also on pin 18 of BQ24725_LX
                                        • mon2
                                          • 14685
                                          Is the other motherboard a working board? If yes, it will help to troubleshoot this unit.
                                          Same adapter works with the other motherboard?
                                          You can measure the voltage to ground of each pin on the charger IC under the same conditions -> add the adapter & battery. Post the list.
                                          Then let us compare the values from the known good motherboard against this one.
                                          You mentioned earlier that you were attempting to remove a mosfet. Was it on this board?
                                          Which one?
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • bykanovm
                                            Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                            by bykanovm
                                            Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                            If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                            If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                            even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                            Also, the laptop does not turn on without...
                                            04-02-2025, 02:45 AM
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            09-14-2023, 11:10 PM
                                          • ZixuTech
                                            Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                                            by ZixuTech
                                            Hi Guys, a weird case here.
                                            This laptop came with damaged hinges, but no liquid signs.
                                            It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                                            I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                                            I have replaced bq24780S battery charging chip, no difference.
                                            With a connected new battery,...
                                            04-03-2022, 04:03 AM
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
