Toshiba P855 only works with battery
  • zioricci
    • Jan 2023
    • 125
    • Italy
    #41
    Re: Toshiba P855 only works with battery
    Originally posted by mon2
    Is the other motherboard a working board? If yes, it will help to troubleshoot this unit.
    Same adapter works with the other motherboard?
    You can measure the voltage to ground of each pin on the charger IC under the same conditions -> add the adapter & battery. Post the list.
    Then let us compare the values from the known good motherboard against this one.
    You mentioned earlier that you were attempting to remove a mosfet. Was it on this board?
    Which one?
    The other motherboard of the P850, has 2 problems
    With the adapter and the battery together, there is an exaggerated absorption certainly due to a short, while either the adapter alone or the battery alone does not cause the short but I have a black screen.
    • mon2
      • 14698
      So there is a leaky mosfet also on that board.
      Continue to remove the gate resistor on the first board.
      • zioricci
        • Jan 2023
        • 125
        • Italy
        #43
        Unbelievable, I tried taking out a stick of ram and it booted up to windows
        • zioricci
          • Jan 2023
          • 125
          • Italy
          #44
          More specifically, I have 2 sticks of Ram one of 4MB, present since the beginning of a laptop bought new, and the other of 8MB bought online recently because I suspected the Ram but I hadn't flashed the bios yet.
          After the flashing it started only with the battery and just now, by chance, I wanted to try only with 4MB of ram but I moved it by slot, then I added the 8MB one in the slot where there was the 4MB one, then in reversed positions and the laptop booted up.
          I try to reverse the positions, as they were before, and in fact it does not start and remains stuck on the logo.
          Question: but when the sticks are different, for example 4MB and 8MB, is it possible that the 8MB one has to fit in a specific slot to start the machine ? It's strange because the bios sees 12MB exactly equal to the total ram installed.
          • mon2
            • 14698
            Interesting observation. You will have to review the Toshiba laptop memory guide for this model to understand which permutations are permitted.
            I recall a similar bad experience from a motherboard vendor who offered a table of all permitted ram stick combinations. We wanted to expand to 32GB yet none of their approved vendor list sticks worked. Killed a day of trial and error and truly believe the fault was with their BIOS coding. Purchased a different brand (ASROCK I believe) which on the other hand, could not fail to recognize the many different sticks of ram we purchased -> each set allowed for a working 32GB configuration. The ASROCK bios actually came back with guidance that we could clock the sticks even faster than the defaults while the first motherboard would just not power up unless we went for a lower amount of ram.
            • zioricci
              • Jan 2023
              • 125
              • Italy
              #46
              Today i realized that laptop battery not charging , i checked the voltages on the 9 pins of the battery which starting from the ninth pin are
              12
              12
              x no connected
              0
              2
              3.3
              3.3
              0
              0
              and also the three mosfets PQ201, PQ202 and PQ205 which are good
              • zioricci
                • Jan 2023
                • 125
                • Italy
                #47
                I also measured the voltages on the charger IC, with battery and adapter together, these are
                1 20.06
                2 20.04
                3 20.01
                4 25.81
                5 3.4
                6 2.69
                7 0
                8 3.4
                9 3.4
                10 0.67
                11 12.59
                12 12.60
                13 12.60
                14 0.69
                15 0
                16 6.07
                17 18.77
                18 13.90
                19 12.58
                20 19.63
                • mon2
                  • 14698
                  Can you double check your measurements for pins #1, 2 and 3? The values are not logical as posted.
                  • zioricci
                    • Jan 2023
                    • 125
                    • Italy
                    #49
                    Even now I read those values. Doesn't it seem logical to you that they are all the same at 20V? The measurements are as in the first check on page 1, done with the adapter only connected.
                    I add more clues.
                    Assuming that the indicators are on, the 2 initial mosfets give regular values, but after a while it happens that the adapter is disconnected, its indicator goes off, the second mosfet from 0V and only the battery remains which obviously gets discharged without the adapter .
                    • zioricci
                      • Jan 2023
                      • 125
                      • Italy
                      #50
                      I was wrong, the battery is charging, it is Windows that considers it discharged, it tells me 8% autonomy but it has a voltage of 12.52 V and after a few charging cycles, the Windows indicator stops but it continues to charge.
                      Any suggestions to fix ?
                      • mon2
                        • 14698
                        Remove pq206 off the logic board. Power up again.
                        Measure the voltage to ground of pins #1, 2 and 3 on the charger IC.
                        The above readings are not making sense to me as when the adapter is mated with the board, pin #3 voltage comes first and should be a higher voltage than pin #2 and pin #2 should be higher than the voltage on pin #1.
                        Post the measurements.
                        • zioricci
                          • Jan 2023
                          • 125
                          • Italy
                          #52
                          I thought it was the gate i.e. pin 4 that had a higher value, in fact it is, about 25 V.
                          Another clue.
                          Tonight before going to sleep the battery was 100% charged (12.52V), I switched it off and this morning it was at 12.25V, with the charger LED off.
                          Why does it turn off? I imagine that at the output of the first two Mosfets there are 0 V.
                          • mon2
                            • 14698
                            Did you review post #51?
                            • zioricci
                              • Jan 2023
                              • 125
                              • Italy
                              #54
                              Yes of course I read, I forgot to say that I tried to remove PQ206 but I can't eradicate it, even by increasing the hot air, nothing won't come off.
                              With the multimeter, however, it seems to work.
                              • zioricci
                                • Jan 2023
                                • 125
                                • Italy
                                #55
                                Sorry I got confused, in fact the voltage of pin 3 exceeds that of pin 2, even if by only 0.01 V. Do you think this is caused by PQ206 and above all, it could be the reason why Windows sees low battery even when not it is ?
                                I might not worry if Windows didn't take the initiative to shut down my computer suddenly when it deems that the battery drops below the critical level, even when charged, but I haven't done this test yet.
                                • zioricci
                                  • Jan 2023
                                  • 125
                                  • Italy
                                  #56
                                  A curiosity about the battery charging process, is it normal that during charging, the current supplied by the adapter decreases over time ?
                                  • mon2
                                    • 14698
                                    Measure the voltage to ground of each pin on pq206.
                                    Post each measurement.
                                    The pq206 device is a sot-23 package and should be simple to remove with enough hot air temperature and with the use of flux. Spin the hot air in tight circles over the part. Keep any such heat away from the sensitive lcd display, keyboard, etc parts. Practice on a donor board if available.
                                    For now, just measure the voltage to ground of pq206.
                                    Also consider to check the resistance again of the 2 * DCin mosfets. Remove all power. Meter in resistance mode.
                                    Measure the resistance checks like before.
                                    Source & drain
                                    Source & gate
                                    Gate & drain
                                    Yes, it is normal for the current charge profile to decrease as the battery charges to full capacity.
                                    • zioricci
                                      • Jan 2023
                                      • 125
                                      • Italy
                                      #58
                                      Drain 25 V
                                      Source 19.35 V
                                      Gate 4.7 V
                                      Source & drain
                                      Source & gate
                                      Gate & drain
                                      -----------------> 1 mosfet - 2 mosfet
                                      Source & drain---> 4Mohm - Infinite
                                      Source & gate---> Infinite - Infinite
                                      Gate & drain ---> 36 Mohm - Infinite
                                      thx
                                      • mon2
                                        • 14698
                                        Measure the resistance of pr210 resistor. Is it a stable reading of ~10 ohms?
                                        Next, meter in diode mode.
                                        Red meter probe to vin pin #3 of diode at pd201. Black meter probe at pin #1 of pd201.
                                        What is the reading? Then swap the probes. Post this measurement.
                                        Repeat with testing the 2nd diode at pd201 using the same process.
                                        In reviewing this thread, the voltage drop from Vin to the VCC pin is too high for some of the measurements.
                                        • zioricci
                                          • Jan 2023
                                          • 125
                                          • Italy
                                          #60
                                          The two diodes look good, the measurements are:
                                          in reverse bias (red on cathode and black on anode) the first diode does not conduct and in forward bias I have the junction of 0.335 V. Same measurements for the second diode of PD201.
                                          Yes, PR201 is 10.1 Ohm stable.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • bykanovm
                                            Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                                            by bykanovm
                                            Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                                            If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                                            If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                                            even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                                            Also, the laptop does not turn on without...
                                            04-02-2025, 02:45 AM
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            09-14-2023, 11:10 PM
                                          • ZixuTech
                                            Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                                            by ZixuTech
                                            Hi Guys, a weird case here.
                                            This laptop came with damaged hinges, but no liquid signs.
                                            It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                                            I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                                            I have replaced bq24780S battery charging chip, no difference.
                                            With a connected new battery,...
                                            04-03-2022, 04:03 AM
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
