Philips 70PUS7505/12 - Contrasts in image are echoed vertically upwards
  • Maalobs
    • Jun 2016
    • 120
    • Sweden
    My mother's Philips 70PUS7505/12 TV suddenly began to display this kind of behavior:
    Contrast differences from a light area to a dark area above, become "echoed" vertically upwards.
    It's the same behavior with all colors as long as there is a relative contrast difference between them.
    There are no other issues; the backlight works fine, the Error code buffer is all zeros.
    I tried it on each HDMI-input, the result was the same.
    I tried in another resolution, still the same.
    I tried with three different sources; tv-decoder, media player, laptop, no difference.
    I tried fiddling all the picture-related controls on the TV, but nothing had an impact on the problem.
    The back label says:
    Code:
    Model:      70PUS7505/12
    Serial:     FZ3A2101052xxx
    Set Option: 016
    Chassis:    S TPN20.6E LA
    The service manual is available here.
    The troubleshooting flowchart in the service manual shows:
    The flowchart suggests updating to the latest software when experiencing a picture-related issue which is non-intermittent.
    There was an update available, so I installed that but the problem still persists without any difference.
    Does anyone have an idea what kind of problem this is even?
    Is it a known problem with this series of models?
    Is there a service notice about it from Philips or something?
    Thanks in advance!
  • nomoresonys
    • 12276
    • U.S.
    Re: Philips 70PUS7505/12 - Contrasts in image are echoed vertically upwards
    first make sure your connections are secure and clean, ie tcon ribbon cables and lvds cable from mainboard to tcon, can clean with isoprophyl alcohol, some use a pencil eraser, not too vigorously they can be delicate, if no joy, something to try, may have to play with width and location of tape: https://www.youtube.com/watch?v=Jt4myvliNow
    • nomoresonys
      • 12276
      • U.S.
      it could be a bad tcon, if the above doesn't work maybe heat up the tcon board with a hairdryer then try tv, see if there's any change.
      • Maalobs
        • Jun 2016
        • 120
        • Sweden
        Thanks for the reply!
        I contemplated something like that, but I was expecting the problem to be isolated to either half of the panel in that case.
        It's consistent across the entire screen, and there is no "glitching" in the artefacting, it's completely static and only follows changes in the video source.
        So the artefacting is completely still when the video is not moving, for example in menus.
        But this type of problem in the T-CON can appear in this "static" way too, you say?
        I remember reading a comment some time ago about what the tape-solution does, if I recall correctly it's a matter of feeding power simultaneously from both ends of (vertical?) lines across the entire panel to power the LEDs on those lines.
        If there is a problem with the power output from one side in that it can't maintain the voltage or supply enough current, this affects the entire line with interference.
        The tape is then used to mask away the power delivery from the detected bad side, so that the good side can supply power to the entire line without interference.
        Is my understanding correct?
        The T-CON board is not covered at all in the service manual.
        The best there is, is a description of the CN408 connector between the SSB and T-CON on page 9-4-8, but there is nothing about the connectors from the T-CON to the panel, where I understand the tape has to be applied.
        How do I find out which pins to mask on the connectors from the T-CON to the panel?
        Is there something that can be done on the T-CON board?
        For example is this type of problem originating from a voltage regulator issue, maybe it's a crappy capacitor that has drifted out of spec or something?
        This TV is 70" and in my mom's apartment so getting it out of there and to my house is out of the question.
        An on-site investigation is possible but it won't be easy.
        • nomoresonys
          • 12276
          • U.S.
          there was a thread not long ago where Diah helped someone, somehow he knew exactly which signals to block, but I don't know, i usually try one end or the other.
          • nomoresonys
            • 12276
            • U.S.
            had a similar problem with an old sanyo not long ago, seemed like tcon or panel problem, well It actually was panel related, it was one bad tab bond, shimmed it and got a good picture, was the usual tab, top right when looking from the front.
            • dskall
              • Oct 2016
              • 2905
              • usa
              Have you unplugged ribbon cables one at a time, and checked screen?
              • Maalobs
                • Jun 2016
                • 120
                • Sweden
                It is going to take a few days before I can go back there and mess around with the TV, so I'll collate all suggestions and work through the list when I am there at the TV.
                • First make sure your connections are secure and clean, ie tcon ribbon cables and lvds cable from mainboard to tcon, can clean with isoprophyl alcohol.
                  Yes, I can definitely clean all the connectors.
                • May have to play with width and location of tape: https://www.youtube.com/watch?v=Jt4myvliNow
                  I'd prefer not to experiment like that, surely there must be a way to identify which pins need to be masked off.
                • Heat up the tcon board with a hairdryer then try tv, see if there's any change.
                  Look for heat-affected issues, OK.
                  Maybe use freeze spray too I guess, to see what cold temperature does to it?
                • There was a thread not long ago where Diah helped someone, somehow he knew exactly which signals to block, but I don't know, i usually try one end or the other.
                  It sounds so random, do you professional repairers really have to work like that with this type of issue?
                  Surely the correct pins must be identifiable by measurement as a specific power rail or something, if the T-CON board lacks documentation?
                  I have a decent multimeter and I guess I can lug along the Rigol scope if it's relevant to find ripple on DC levels or similar.
                • [...]similar problem with an old sanyo, it was one bad tab bond, shimmed it and got a good picture, was the usual tab, top right when looking from the front.
                  By "bad tab bond", do you mean the flex cable connections from the panel to the long narrow PCB at the bottom edge of the TV?
                  By "shimming", what do you mean, did you put something in there on the other side of the flex cable to apply force to the connection?
                • Have you unplugged ribbon cables one at a time, and checked screen?
                  No, I haven't opened it, but I will unplug, clean and re-seat all ribbon cables one by one.
                  I was by my mom to fix an internet issue after the ISP got changed and she said "oh and while you're here, the TV picture looks wierd"
                  I had the laptop with me and did everything I have described in the first post.
                Anyways, I have in fact watched RepairAllTV videos before, and now I went back through his collection and looked for videos that covered this type of problem.
                He has solved this type of problem in different ways.
                As in the video that nomoresonys linked to, here are two other where he also fixes the issue by applying unexplained tape masking:
                https://www.youtube.com/watch?v=XCJAx92JwPs&t=1010s
                https://www.youtube.com/watch?v=vV3FCTAC1no&t=318s
                Here the issue was a short-circuited capacitor on that long, thin PCB that I guess is part of the panel assembly:
                https://www.youtube.com/watch?v=Ij3sReZjpAY&t=1031s
                Here he uses a piece of thermal pad to put pressure on the flex cable connection that goes to the panel:
                https://www.youtube.com/watch?v=ITHprEQhyL0&t=312s
                Here (or actually in the part 2 video) he replaces the T-CON PCB:
                https://www.youtube.com/watch?v=HT5akVxopmY&t=590s
                I'm open to concrete suggestions.
                I'll never hear the end of it if I go there and create chaos with that big TV in pieces and then don't end up fixing it.
                • Diah
                  • Feb 2013
                  • 6437
                  why you don't use the guarantee right and contact Philips since this model 2020 series..!!
                  • nomoresonys
                    • 12276
                    • U.S.
                    Done
                    • nomoresonys
                      • 12276
                      • U.S.
                      +10, if under warranty or guarantee it should go back.
                      • nomoresonys
                        • 12276
                        • U.S.
                        "Here he uses a piece of thermal pad to put pressure on the flex cable connection that goes to the panel:
                        https://www.youtube.com/watch?v=ITHprEQhyL0&t=312s" that IS it, it's called a tab bond and not as useful with the newer tvs that pretty much have NO frame holding them together.
                        • nomoresonys
                          • 12276
                          • U.S.
                          this one dives deeper: https://www.youtube.com/watch?v=pfrRhw7-ZII
                          • nomoresonys
                            • 12276
                            • U.S.
                            what you need to understand is there are at least a few different issues that will make a tv display in that manner, if you can find someone that can tell you exactly what is wrong from a picture, I'd like them to help me pick some lottery numbers.
                            • Maalobs
                              • Jun 2016
                              • 120
                              • Sweden
                              Yes, this guy explains it to some extent in a two-part video:
                              I fixed a broken 4K 55” TV with TAPE | How to fix a TV with a blank screen
                              Repair Hack Explained | How to Fix TV Horizontal Lines - Part 2
                              https://www.youtube.com/watch?v=SbGAkRgaZhs
                              He first measured all the ceramic SMD capacitors on the long, thin PCB to make sure there wasn't a short circuit on any of them.
                              He explains that the pins that are masked off on the ribben cable are clock signals on the horizontal plane, and in his case there appeared to be a short circuit in a subpixel on a single horizontal clock line on his panel after he tried reducing the block of masked off pins one by one.
                              The consequence of the masking is a possibly lower brightness on lines on the panel at the half where the masking is done.
                              He had to research a patent application to fully understand the technical implementation.
                              • Maalobs
                                • Jun 2016
                                • 120
                                • Sweden
                                I did in fact report this TV to the retailer and from there to Philips last week.
                                The support ticket was delegated to an outsourced service vendor in Sweden and the initial message I got from them was that they replace PCBs until the TV starts working again.
                                They hinted that spare parts would take a long time to get hold of and might not be available anymore for this model.
                                That's when I thought I'd better prepare for the worst and see if there is a reasonable way of handling this myself.
                                I wrote them a message in the ticket asking them what part they were expecting to replace and got no answer back, so no help from them and they certainly don't do any component level repairs anyway.
                                Maybe they'll come through and solve this, but if the issue is in the panel, I guess that basically means replacing the entire device.
                                • William1967
                                  • Nov 2017
                                  • 215
                                  • Netherlands
                                  The service vendor is right, for this model several parts are not available. I read the following at a mayor Philips parts supplier: "This item is currently unavailable due to delivery problems at the manufacturer/supplier."
                                  It's best to ask for another tv / leniency.
                                  • Diah
                                    • Feb 2013
                                    • 6437
                                    this is not your problem if there are no parts.. you will get new TV or complete money back.. so dont miss this chance.
                                    • nomoresonys
                                      • 12276
                                      • U.S.
                                      Indeed, don't let them off the hook, they need to be held responsible for selling junk.
                                      • nomoresonys
                                        • 12276
                                        • U.S.
                                        I would go with refund if possible, they do not make philips like they use too.
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
