Super Flower Power Supplies
  • japlytic
    • Oct 2005
    • 2086
    In a computer used for video editing, there is a Super Flower 500W power supply inside it. During heavy CPU loading, the 12V rail drops to about 11.4V. From the ventillation holes, I can see a JP (Jen Pan - www.jpcon.com) electrolytic capacitor.
    Does anyone have a bad unit with photos of the internals?
  • Newbie2
    • Sep 2005
    • 885
    Re: Super Flower Power Supplies
    JPCON caps spell trouble! I'm guessing the JPCON caps are doing part of the 12V rail voltage dropping when the Super Flower PSU is under heavy load. I do not have a picture of the internals of a Super Flower 500W PSU. Is this a computer at the place where you work or it's your computer?
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • japlytic
      • Oct 2005
      • 2086
      It is at home (not mine). The power supply is still under warranty, with the seal intact. Anyone else with a picture of the internals?
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Bad cap(s) is a possibility. Also, if a VRM draws power from the +12V O/P, and if the P/S doesn't use a shared regulation scheme for the +5V and the +12V (i.e. the +12V isn't regulated), the extra current demand from the +12V may just be dragging it down. A concurrent light load on the +5V would make this worse; crap-caps would make it worse, too.
        Haven't heard of Super Flower.
        PeteS in CA
        • Newbie2
          • Sep 2005
          • 885
          If you don't mind getting into trouble, you can try cutting the middle of the warranty seal with a knife. I have tried that and it's very hard to notice that the warranty is void! I recommend Enermax power supplies, they don't have a warranty seal to rip off or cut!
          My gaming PC:
          • japlytic
            • Oct 2005
            • 2086
            I can see all of the caps through the vent for the large fan, without opening the case. None were bulging, and there were two 1000uF 200V electrolytics in the primary - I think this is adequate for a supply of this wattage.
            I guess the 12V rectifiers may be inadequate - a good power supply of such a high wattage should have a separate power transformer for each rail (+12V, +5V, +3.3V), so a change in load on one of the rails woudl not affect the other. I have seen such a supply, which was out of a server.
            • PeteS in CA
              • Aug 2005
              • 3581
              Using separate converters like that would be expensive - in $$ and space. It would require extra power transformers (custom parts), extra switch devices and more heatsink space, extra PWM ICs (which would have to be synchronized to prevent O/P noise problems) probably separate O/P inductors for each converter (PC P/Ss usually have a coupled inductor, one core with separate windings for each O/P; with proper turns ratios, this improves regulation of the various O/Ps). PC-grade P/S are too inexpensive to do this, though, properly implemented, it would solve the problem.
              O/P rectifiers typically have forward drops of ~.5V for Schottkies, ~1V for ultrafasts, with variation due to load current of .2V-.4V. Unless the +12V is 11.6V-11.8V under light load, I don't think a marginally rated 12V O/P rectifier is the cause of the voltage drop. And the rectifier may be marginal, but the problem would show up as extra heat and shorter life. There are a several ways to improve the regulation of the +12V. One is thru the use, noted above, of a coupled inductor. Another is to use the +5V tansformer winding as part of the +12V winding. A third is by including the +12V in the the feedback of the main regulator. You give up a little regulation in the +5V, but gain regulation in the +12V, and this is accomplished by adding a resistor, making the sample of the O/P provided to the error amplifier a combination of the +5V and the +12V, rather than just a sample of the +5V. A technique I've seen used for the +3.3V O/P is a sense wire added to one of the ATX connector +3.3V pins, so that the regulator compensates for some of the voltage drop in the O/P harness wires.
              My guess is that Super Flower either didn't include the +12V in the main regulator feedback or messed up the turns ratio of the coupled inductor, or both.
              "Stupid" question time, are all P/S O/P connectors properly seated? Another "stupid" possibility is that the solder joint on the P/S PCB for the +12V wires could be bad. A third "stupid" possibility is bad connector socket crimps.
              PeteS in CA
              • arneson
                • Sep 2005
                • 1267
                Forrest Gump always said, Stupid is as stupid does.
                I've seen all three of those issues in power supplies,
                but I've also seen them fly across the lania.
                Jim
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  Yep, those are all common Oh-S__ts. One time a company I worked for had O/P harnesses made by a division of a major connector mfr. After making 10K-12K P/Ss with those harnesses, the customer, a major computer mfr was experiencing a rash of failures in test (not at end-users' sites, thankfully). When it got down to the root cause, that division of a major connector mfr used the wrong crimping tool on the major connector mfr's own product.
                  PeteS in CA
                  • arneson
                    • Sep 2005
                    • 1267
                    I was doing life safty systems in hospitals years ago.
                    It was Edwards fire alarm controle panels, totally loaded with Molex, 12 and 16 pin, hundreds of them interconnecting panels. There's nothing quite like troubleshooting a panel full of molexes.
                    Jim
                    • japlytic
                      • Oct 2005
                      • 2086
                      A multimeter reading on each rail corresponded with the readings on a monitoring utility, which ruled out any problem realted to the connectors. I do not think there would be a bad solder joint inside the supply.
                      www.super-flower.com.tw - They were established in 1991.
                      (Many utilities do not monitor the negative rails, since they are rarely used).
                      • japlytic
                        • Oct 2005
                        • 2086
                        Today, I opened up the supply (nothing was bulging!)
                        The SBL3040 (2 in parallel) (+5V) and SBL4040 (+3.3V) rectifiers have a foward voltage of 0.55V, while the F30D20 (+12V) has a foward voltage of 1.3V. So that's why the 12V rail is 0.6V lower than normal during high CPU usage, but this is not causing any problems .
                        Acutally, the capacitors were Jenpo CE-WG (1000uF 200V 85C - at this temperature rating) in the primary, with the "JP" units (often called PCE-TUR)
                        The capacitors (JP) were:
                        3300uF 16V (TUR) on the +12V rail (none before the primary inductor)
                        2200uF 6.3V (TUL) on the +3.3V rail (one before and after primary inductor)
                        4700uF 10V (TUL) on the +5V rail before primary inductor; 2200uF 10V (TUR) after primary inductor on the +5V rail.
                        1000uF 10V (TUR) on the +5V standby rail.
                        470uF 16V (TUR) on the negative rails.
                        There is a 10 ohm, 10W wirewound load resistor on the +5V rail (2.5W, 0.5A load)
                        The X2 and Y-class capacitors are approved by various safety agencies.
                        The SMPS chip is a KA7500, and there is a custom chip; which is a SFB03B24A2U1.
                        http://www.0759.com/products/ecap/ecap_e/16-17.htm (TUL Series)
                        http://www.0759.com/products/ecap/ecap_e/14-15.htm (TUR Series)
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          We-e-e-elllll ... that may not be a problem. The +5V and +3.3V rectifiers are schottky types - 30A@40V for the +5V and 40A@40V for the +3.3V. OTOH, the +12V rectifier (possibly 30A@200V) will be ultrafast recovery types. Schottkies have a V(F) of .4-.7V; ultrafasts' V(F) are 1.0-1.3V - two different technologies (and max reverse voltage available for a schottky is 100V, IIRC).
                          PeteS in CA
                          • japlytic
                            • Oct 2005
                            • 2086
                            The custom chip is acutally a WT7512, used for the PowerGood signal, which is in the same position in a similar model on http://terasan.info/dengen/no083/index.html
                            WT7512 datasheet:
                            A 14cm fan blows air over the heatsinks from inside the case.
                            Since two SBL3040 rectifiers for the +5V rail are in parallel, the voltage drop would be 0.275V.
                            I forgot to mention that the primary transistors are 2SC3320s, with ratings of 500V 15A having a maximum dissipation of 80W.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              sounds like a "mad dog" unit i have on the scrap pile.
                              the molex burned up on +3.3.
                              the fan says super flower on it and has the big resistor on the heatsink.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                vf stays the same regardless of how many are in paralel.
                                current handling doubles though as long as one doesnt have a lower vf and hogs all the current.most semi's are pretty consistant nowadays so you are not likely to have that problem.
                                • larrymoencurly
                                  • Oct 2004
                                  • 960
                                  Is it possible that the second chip is actually an LM324 quad op-amp? I've seen them in some PSUs, including one with a KA7500 chip in it.
                                  • Chris1992
                                    • Apr 2005
                                    • 561
                                    btw @ kc8: mad dog are usually decent power supplies. wonder how the molex got burnt on 3.3.
                                    The great capacitor showdown!
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      all 3 +3.3 were burned.
                                      maybe just a bum molex?
                                      iirc its an abit ka7.replaced the molex on it and its running fine.
                                      been running it in my testbed just to beat it up and see if it does anything stupid.
                                      customer replaced the maddog with a seasonic.
                                      havent seen any other reports.
                                      the maddog has crap caps though.
                                      • Rainbow
                                        • Aug 2005
                                        • 1375
                                        ATX connector usually burns as a result of bad contact. The board probably draws a lot of power from 3.3V (although KT7 does not, it has its own switching regulator that runs from 5V - so 3.3V is adjustable, don't know about KA7).
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          Hi everyone,
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Joe24
                                          2070 Super with crazy power consumption numbers
                                          by Joe24
                                          Have a Gigabyte 2070 Super with some bonkers power draw readings. Card runs fine, other than some GPU throttling because of the power numbers. But GPU power always reads too high, more than the power reading for the entire card. And VRAM power always reads way too low, along with PCIe and 6-pin power readings. The 8-pin reading seems plausible.
                                          Typical readout while running 720p Furmark, 8x AA:
                                          GPU clock: 1590 MHz
                                          Mem clock: 1750 MHz
                                          GPU temp: 58.8 °C
                                          Hot spot: 71.8 °C
                                          Fan speed: 33% / 1000 rpm
                                          Mem used: 454 MB
                                          GPU load: 97%
                                          02-03-2023, 02:07 AM
                                        • iMic
                                          Vintage AT Power Supplies - Selecting Capacitors
                                          by iMic
                                          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                          02-19-2023, 06:45 PM
