Super Flower Power Supplies
  • japlytic
    • Oct 2005
    • 2086
    Re: Super Flower Power Supplies
    Originally posted by larrymoencurly
    Is it possible that the second chip is actually an LM324 quad op-amp? I've seen them in some PSUs, including one with a KA7500 chip in it.
    This 8-pin chip is for controlling the PowerGood signal, as I said earlier.
    • japlytic
      • Oct 2005
      • 2086
      (and max reverse voltage available for a schottky is 100V, IIRC).
      There are schottky rectifiers with a reverse voltage (Vrrm) rating of 250V e.g. MBR40250 - 250V, 40A (!) - this is only available in a TO-220 package.
      • PeteS in CA
        • Aug 2005
        • 3582
        • USA, Unsure of Planet
        Interesting. Looks like the parts were released in 2004 and 2005.
        PeteS in CA
        • Destroyer-Br
          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
          by Destroyer-Br
          I'm working on an Acer Nitro 5 unit with the following specs:
          • Motherboard: LA-J871P Rev: 1B
          • Model: Acer AN515-55-59MT
          • S/N: NHQ7JAL00403906A973400
          • SNID: 03902728734
          Initial Issue
          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
          04-17-2025, 08:18 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Joe24
          2070 Super with crazy power consumption numbers
          by Joe24
          Have a Gigabyte 2070 Super with some bonkers power draw readings. Card runs fine, other than some GPU throttling because of the power numbers. But GPU power always reads too high, more than the power reading for the entire card. And VRAM power always reads way too low, along with PCIe and 6-pin power readings. The 8-pin reading seems plausible.
          Typical readout while running 720p Furmark, 8x AA:
          GPU clock: 1590 MHz
          Mem clock: 1750 MHz
          GPU temp: 58.8 °C
          Hot spot: 71.8 °C
          Fan speed: 33% / 1000 rpm
          Mem used: 454 MB
          GPU load: 97%
          02-03-2023, 02:07 AM
        • iMic
          Vintage AT Power Supplies - Selecting Capacitors
          by iMic
          Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
          The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
          02-19-2023, 06:45 PM
